1. Re: New CS6 is crashing and now my old CS2 is crashing too.
Curt Y Dec 18, 2012 8:33 AM (in response to heyhon)Font managers help but are not foolproof. If it best to make your fonts unavailable to PS. If it works then add in 1/2 of them. If that works add in half of the remaining. Continue this until you find the batch that causes the problem. Then start adding them in one at a time until you find the culprit.
2. Re: New CS6 is crashing and now my old CS2 is crashing too.
Mylenium Dec 18, 2012 9:27 AM (in response to heyhon)Crash reports can be provided via Pastebin or otehr sites. You can find them in your Application Support:Logs or Library:Logs or the System folder as XML/ text files.
Mylenium
3. Re: New CS6 is crashing and now my old CS2 is crashing too.
Michiharu ArizaDec 20, 2012 2:17 AM (in response to heyhon)
How to find a crash log:
Run "Console" application. This is located under folder Applications/Utilities.
In its window, application crash logs are listed under the group "User Diagnostic Reports". Click on the triangle to reveal logs if it is pointing to the right.
Click on the last Photoshop CS6 crash log to show its contents to the right.
You should be able to copy the log contents at this point, but if for some reason it doesn't let you, look for a line that reads "Crashed Thread: (number)". The number is often 0, but may be different.
Then look for a line that reads "Thread (number) Crashed:" corresponding to that number.
Following lines prefixed with a number starting with zero indicate where the application crashed. This is the most informative part of the crash log. Type out a few lines in this forum.
If you get Adobe (not Apple one) crash reporter dialog soon after a crash, clicking on "Crash Data" on the lower left also reveals the crash log. Sending a response with your e-mail address helps us diagnose the problem too.
4. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 7:59 AM (in response to Michiharu Ariza)still not letting me copy and paste out of the console but here is that line:
crashed thread: 0 Dispatch queue: com.apple.main-thread
application specific information:
***error for object 0x107b08408: incorrect checksum for freed object - object was probably modified after being freed
Photoshop crashed just by opening it and scrolling to open a file, this is typical.
5. Re: New CS6 is crashing and now my old CS2 is crashing too.
Michiharu ArizaDec 20, 2012 8:16 AM (in response to heyhon)
Do you see names like CoreText, HIToolBox, or ATS soon after that line, like the one discussed here?
http://forums.adobe.com/message/4921680#4921680
In that case, crashing within the OS code. I have no idea what's causing it.
Reducing the number of active fonts may help if it is caused by a particular font.
If you have 800 fonts, cut in half to 400, and so on.
6. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 8:27 AM (in response to Michiharu Ariza)I don't see any of those in the crash log. Since it crashes just by scrolling to find a file, I was able to use Bridge yesterday to find the file and open it that way and it actually let me work on something basic without crashing - any thoughts on that?
7. Re: New CS6 is crashing and now my old CS2 is crashing too.
gator soup Dec 20, 2012 8:35 AM (in response to heyhon)three standard tips
1) Run Disk Utility> Repair Disk and Repair Permissions
2) Run a utility like Cocktail OSX (especially Caches> User all)
then reboot, still no joy
3) try creating an admin New User Account (System Preferences> Accounts) and test (this rules out preferences and user settings by restoring defaults in the new account)
after that you are probably looking at a bad system install, but you may also want to at least double your ram for CS6...
8. Re: New CS6 is crashing and now my old CS2 is crashing too.
Michiharu ArizaDec 20, 2012 9:18 AM (in response to heyhon)
No idea, but since you can't copy from console window, which is unusual, something must be wrong in your system.
Can you copy and paste or browse files in OS app like TextEdit?
Maybe a time to upgrade your OS. We know Apple fixed many issues since 10.6.8.
9. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 9:47 AM (in response to Michiharu Ariza)I can copy and paste files into TextEdit but it's this window where I can't paste anything.
Any idea why Photoshop CS2 which never crashes all of the sudden crashes on startup everytime now that Photoshop CS6 is installed - could the software be wonky??
10. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 10:10 AM (in response to gator soup)Ran Disk Repair, bought and Ran Cocktail - no joy.
Restarted as a different user and CS6 seemed to be fine, it let me scroll without crashing, CS2 crashed immediately.
What do you mean by a bad system install?
11. Re: New CS6 is crashing and now my old CS2 is crashing too.
Chris CoxDec 20, 2012 10:48 AM (in response to heyhon)
It sounds like you've got a system level problem (bug in the OS).
Corrupt fonts and corrupt OS font caches have been known to do that.
But we really need to see the full crash log to figure out what is going on.
12. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 11:35 AM (in response to Chris Cox)Here is the CS2 crash report (switched from Firefox to Safari, now I can copy and paste)
Process: Adobe Photoshop CS2 [206]
Path: /Applications/older software/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
Identifier: com.adobe.Photoshop
Version: 9.0 (9.0x196) (9.0)
Code Type: PPC (Translated)
Parent Process: launchd [109]
Date/Time: 2012-12-20 12:44:26.240 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Exception Type: EXC_CRASH (SIGILL)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x80239236 __pthread_kill + 10
1 libSystem.B.dylib 0x80238ad7 pthread_kill + 95
2 com.adobe.Photoshop 0xb80f5a71 gettimeofday_wrapper + 37593
3 ??? 0x1c1bab8f 0 + 471575439
Thread 1:
0 libSystem.B.dylib 0x80142afa mach_msg_trap + 10
1 libSystem.B.dylib 0x80143267 mach_msg + 68
2 com.adobe.Photoshop 0xb819440f CallPPCFunctionAtAddressInt + 206231
3 libSystem.B.dylib 0x80170259 _pthread_start + 345
4 libSystem.B.dylib 0x801700de thread_start + 34
Thread 2:
0 com.adobe.Photoshop 0xb815acc0 spin_lock_wrapper + 90152
1 com.adobe.Photoshop 0xb8179c5b CallPPCFunctionAtAddressInt + 97763
2 com.adobe.Photoshop 0xb80c6b13 0xb8000000 + 813843
3 com.adobe.Photoshop 0xb80c0037 0xb8000000 + 786487
4 com.adobe.Photoshop 0xb80dd8e8 0xb8000000 + 907496
5 com.adobe.Photoshop 0xb8145397 spin_lock_wrapper + 1791
6 com.adobe.Photoshop 0xb801ceb7 0xb8000000 + 118455
Thread 3:
0 com.adobe.Photoshop 0xb815a8ff spin_lock_wrapper + 89191
1 com.adobe.Photoshop 0xb8176e5d CallPPCFunctionAtAddressInt + 85989
Thread 4:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x802fc540 ecx: 0xb7fffa6c edx: 0x80239236
edi: 0xb81f8714 esi: 0x00000004 ebp: 0xb7fffa98 esp: 0xb7fffa6c
ss: 0x0000001f efl: 0x00000286 eip: 0x80239236 cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x8023922c
Binary Images:
0x80000000 - 0x8005dff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x8007d000 - 0x800e7fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x80142000 - 0x802e9ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x8036b000 - 0x804e6fe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x805de000 - 0x805ecfe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x805f1000 - 0x805fdff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x80601000 - 0x80647ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x80654000 - 0x807d6fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
0x80838000 - 0x808e5fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x808f9000 - 0x808fcfe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x8fe00000 - 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0xb8000000 - 0xb81defff +com.adobe.Photoshop 9.0 (9.0x196) (9.0) <F24FBFDD-E694-6F38-BFFB-293613CEF2DE> /Applications/older software/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Translated Code Information:
objc[206]: garbage collection is ON
NO CRASH REPORT
13. Re: New CS6 is crashing and now my old CS2 is crashing too.
heyhon Dec 20, 2012 11:37 AM (in response to Chris Cox)and here is the CS6 crash report
Process: Adobe Photoshop CS6 [2341]
Path: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
Version: 13.0.0 (20120315.r.428)
Code Type: X86-64 (Native)
Parent Process: launchd [99]
Date/Time: 2012-12-20 10:53:10.721 -0500
Report Version: 6
Exception Type: EXC_CRASH (SIGABRT)
Application Specific Information:
*** error for object 0x107b08408: incorrect checksum for freed object - object was probably modified after being freed.
0 libSystem.B.dylib 0x00007fff891130b6 __kill + 10
1 libSystem.B.dylib 0x00007fff891b39f6 abort + 83
2 libSystem.B.dylib 0x00007fff891a262d szone_error + 519
3 libSystem.B.dylib 0x00007fff890cc854 small_malloc_from_free_list + 473
4 libSystem.B.dylib 0x00007fff890c91e1 szone_malloc_should_clear + 2070
5 libSystem.B.dylib 0x00007fff890c898a malloc_zone_malloc + 82
6 com.apple.CoreFoundation 0x00007fff815266a0 __CFBasicHashRehash + 240
7 com.apple.CoreFoundation 0x00007fff81547f07 CFBasicHashRemoveValue + 1143
8 com.apple.CoreFoundation 0x00007fff81572fac CFRunLoopRemoveSource + 700
9 com.apple.CoreFoundation 0x00007fff8155a5a2 __CFSetApplyFunction_block_invoke_1 + 18
10 com.apple.CoreFoundation 0x00007fff8154ead5 CFBasicHashApply + 213
11 com.apple.CoreFoundation 0x00007fff8155a55f CFSetApplyFunction + 191
12 com.apple.CoreFoundation 0x00007fff81572f21 CFRunLoopRemoveSource + 561
13 com.apple.DesktopServices 0x00007fff855b30cf TClientChangeNotifier::~TClientChangeNotifier() + 81
14 com.apple.DesktopServices 0x00007fff855b31d0 TClientChangeNotifier::RemovePtrReference() + 108
15 com.apple.DesktopServices 0x00007fff855b3068 TNotifier::RemovePtrReference() + 40
16 com.apple.DesktopServices 0x00007fff855bad67 TNodeRequest::~TNodeRequest() + 33
17 com.apple.DesktopServices 0x00007fff855bad31 TNodeRequest::RemovePtrReference() + 35
18 com.apple.DesktopServices 0x00007fff855c0dae NodeDisposeRequest + 48
19 com.apple.AppKit 0x00007fff82a6581e -[NSNavFBENode copyIcon] + 105
20 com.apple.AppKit 0x00007fff82a56a23 -[NSNavBrowserCell drawInteriorWithFrame:inView:] + 923
21 com.apple.AppKit 0x00007fff827118d9 -[NSOutlineView _drawContentsAtRow:column:withCellFrame:] + 95
22 com.apple.AppKit 0x00007fff827109fc -[NSTableView drawRow:clipRect:] + 1242
23 com.apple.AppKit 0x00007fff82a7406f -[NSNavOutlineView drawRow:clipRect:] + 321
24 com.apple.AppKit 0x00007fff827102ef -[NSTableView drawRowIndexes:clipRect:] + 369
25 com.apple.AppKit 0x00007fff82710170 -[NSOutlineView drawRowIndexes:clipRect:] + 131
26 com.apple.AppKit 0x00007fff8270ec9c -[NSTableView drawRect:] + 1302
27 com.apple.AppKit 0x00007fff82704d75 -[NSView _drawRect:clip:] + 3566
28 com.apple.AppKit 0x00007fff8270254b -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 2112
29 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
30 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
31 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
32 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
33 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
34 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
35 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
36 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
37 com.apple.AppKit 0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
38 com.apple.AppKit 0x00007fff82701b2c -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 254
39 com.apple.AppKit 0x00007fff826fe3de -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2683
40 com.apple.AppKit 0x00007fff82677c0e -[NSView displayIfNeeded] + 969
41 com.apple.AppKit 0x00007fff82672aba _handleWindowNeedsDisplay + 678
42 com.apple.CoreFoundation 0x00007fff81593b07 __CFRunLoopDoObservers + 519
43 com.apple.CoreFoundation 0x00007fff8156f434 __CFRunLoopRun + 468
44 com.apple.CoreFoundation 0x00007fff8156ed8f CFRunLoopRunSpecific + 575
45 com.apple.HIToolbox 0x00007fff89f4d7ee RunCurrentEventLoopInMode + 333
46 com.apple.HIToolbox 0x00007fff89f4d5f3 ReceiveNextEventCommon + 310
47 com.apple.HIToolbox 0x00007fff89f4d4ac BlockUntilNextEventMatchingListInMode + 59
48 com.apple.AppKit 0x00007fff82647eb2 _DPSNextEvent + 708
49 com.apple.AppKit 0x00007fff82647801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
50 com.apple.AppKit 0x00007fff82af1718 -[NSScroller trackKnob:] + 1830
51 com.apple.AppKit 0x00007fff82aef850 -[NSScroller mouseDown:] + 936
52 com.apple.AppKit 0x00007fff827413a7 -[NSWindow sendEvent:] + 5409
53 com.apple.AppKit 0x00007fff82676afa -[NSApplication sendEvent:] + 4719
54 com.adobe.Photoshop 0x0000000101921919 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17610681
55 com.adobe.Photoshop 0x0000000101920b7f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17607199
56 com.apple.AppKit 0x00007fff82882e06 -[NSApplication _realDoModalLoop:peek:] + 509
57 com.apple.AppKit 0x00007fff82880951 -[NSApplication runModalForWindow:] + 129
58 com.apple.AppKit 0x00007fff82ae6112 -[NSSavePanel runModal] + 318
59 com.adobe.Photoshop 0x000000010192f56e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17667086
60 com.adobe.Photoshop 0x00000001005b3050 0x100000000 + 5976144
61 com.adobe.Photoshop 0x0000000100c4dcc5 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4160357
62 com.adobe.Photoshop 0x00000001005b3f4a 0x100000000 + 5979978
63 com.adobe.Photoshop 0x0000000100c51b02 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4176290
64 com.adobe.Photoshop 0x000000010061b102 boost::system::system_error::what() const + 338690
65 com.adobe.Photoshop 0x00000001006145b7 boost::system::system_error::what() const + 311223
66 com.adobe.Photoshop 0x0000000100614674 boost::system::system_error::what() const + 311412
67 com.adobe.Photoshop 0x00000001005b0c02 0x100000000 + 5966850
68 com.adobe.Photoshop 0x00000001005b77ec 0x100000000 + 5994476
69 com.adobe.Photoshop 0x00000001005ad3ae 0x100000000 + 5952430
70 com.adobe.Photoshop 0x000000010001faa2 0x100000000 + 129698
71 com.adobe.Photoshop 0x00000001019202d4 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17604980
72 com.apple.Foundation 0x00007fff85f13bc5 __NSFireTimer + 114
73 com.apple.CoreFoundation 0x00007fff81570bb8 __CFRunLoopRun + 6488
74 com.apple.CoreFoundation 0x00007fff8156ed8f CFRunLoopRunSpecific + 575
75 com.apple.HIToolbox 0x00007fff89f4d7ee RunCurrentEventLoopInMode + 333
76 com.apple.HIToolbox 0x00007fff89f4d551 ReceiveNextEventCommon + 148
77 com.apple.HIToolbox 0x00007fff89f4d4ac BlockUntilNextEventMatchingListInMode + 59
78 com.apple.AppKit 0x00007fff82647eb2 _DPSNextEvent + 708
79 com.apple.AppKit 0x00007fff82647801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
80 com.apple.AppKit 0x00007fff8260d68f -[NSApplication run] + 395
81 com.adobe.Photoshop 0x0000000101920402 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17605282
82 com.adobe.Photoshop 0x000000010192266e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17614094
83 com.adobe.Photoshop 0x00000001005ae27c 0x100000000 + 5956220
84 com.adobe.Photoshop 0x00000001007b074f boost::system::system_error::what() const + 1999183
85 com.adobe.Photoshop 0x00000001007b0999 boost::system::system_error::what() const + 1999769
86 com.adobe.Photoshop 0x000000010054b24c 0x100000000 + 5550668
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff890ddc0a kevent + 10
1 libSystem.B.dylib 0x00007fff890dfadd _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff890df7b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff890df2de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff890dec08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff890deaa5 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff890ffa6a __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff89103881 _pthread_cond_wait + 1286
2 MultiProcessor Support 0x000000011dc380f3 main + 8403
3 MultiProcessor Support 0x000000011dc381b0 main + 8592
4 MultiProcessor Support 0x000000011dc54f50 main + 126768
5 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 3:
2 ...ple.CoreServices.CarbonCore 0x00007fff812b3d87 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff81222ff8 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff8121cefb MPWaitOnQueue + 215
5 com.adobe.ACE 0x000000010514b2c9 0x105112000 + 234185
6 com.adobe.ACE 0x000000010514a5da 0x105112000 + 230874
7 ...ple.CoreServices.CarbonCore 0x00007fff811f50d1 PrivateMPEntryPoint + 63
8 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
9 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 4:
0 libSystem.B.dylib 0x00007fff890dea2a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff890dee3c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff890deaa5 start_wqthread + 13
Thread 5:
1 libSystem.B.dylib 0x00007fff890ff8f9 nanosleep + 148
2 com.adobe.PSAutomate 0x00000001233449cb ScObjects::Thread::sleep(unsigned int) + 59
3 com.adobe.PSAutomate 0x000000012332a7c9 ScObjects::BridgeTalkThread::run() + 169
4 com.adobe.PSAutomate 0x0000000123344d36 ScObjects::Thread::go(void*) + 166
Thread 6:
2 com.adobe.ape.engine 0x000000013d3e7c0d APXGetHostAPI + 2516093
3 com.adobe.ape.engine 0x000000013d195ec1 APXGetHostAPI + 83761
4 com.adobe.ape.engine 0x000000013d3e7cd1 APXGetHostAPI + 2516289
5 com.adobe.ape.engine 0x000000013d3e7d4a APXGetHostAPI + 2516410
6 com.adobe.ape.engine 0x000000013d3e7e79 APXGetHostAPI + 2516713
7 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 7:
Thread 8:
0 libSystem.B.dylib 0x00007fff890c4d7a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff890c53ed mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff8156f902 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff8156ed8f CFRunLoopRunSpecific + 575
4 com.apple.CoreMediaIOServices 0x00007fff8654f5f7 MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff865511c2 CAPThread::Entry(CAPThread*) + 140
6 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 9:
0 libSystem.B.dylib 0x00007fff890c4dda semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff89103772 _pthread_cond_wait + 1015
2 com.adobe.ape.engine 0x000000013d3e7bd0 APXGetHostAPI + 2516032
3 com.adobe.ape.engine 0x000000013d3ffddb APXGetHostAPI + 2614859
Thread 10:
3 com.adobe.ape.engine 0x000000013d57a2c3 APXGetHostAPI + 4164403
Thread 11:
0 libSystem.B.dylib 0x00007fff89108956 recvfrom + 10
1 ServiceManager-Launcher.dylib 0x000000012445e5ec Invoke + 45721
2 ServiceManager-Launcher.dylib 0x000000012445d813 Invoke + 42176
3 ServiceManager-Launcher.dylib 0x000000012445cbe0 Invoke + 39053
4 ServiceManager-Launcher.dylib 0x000000012445cc66 Invoke + 39187
5 ServiceManager-Launcher.dylib 0x000000012445830f Invoke + 20412
6 ServiceManager-Launcher.dylib 0x0000000124458616 Invoke + 21187
7 ServiceManager-Launcher.dylib 0x0000000124458cd7 Invoke + 22916
8 ServiceManager-Launcher.dylib 0x0000000124458f41 Invoke + 23534
9 ServiceManager-Launcher.dylib 0x000000012445b61d Invoke + 33482
10 ServiceManager-Launcher.dylib 0x000000012445b775 Invoke + 33826
11 ServiceManager-Launcher.dylib 0x000000012445bfb2 Invoke + 35935
12 ServiceManager-Launcher.dylib 0x000000012445c0ad Invoke + 36186
13 ServiceManager-Launcher.dylib 0x000000012444ed6b Login + 480
14 ServiceManager-Launcher.dylib 0x00000001244527ad Login + 15394
15 ServiceManager-Launcher.dylib 0x000000012445c412 Invoke + 37055
16 ServiceManager-Launcher.dylib 0x000000012445e253 Invoke + 44800
17 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
18 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 12:
4 com.apple.CoreFoundation 0x00007fff8156eb16 CFRunLoopRun + 70
5 com.apple.DesktopServices 0x00007fff855aa326 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 514
6 ...ple.CoreServices.CarbonCore 0x00007fff811f50d1 PrivateMPEntryPoint + 63
Thread 13:
Thread 14: com.apple.CFSocket.private
0 libSystem.B.dylib 0x00007fff89108932 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x00007fff81591468 __CFSocketManager + 824
2 libSystem.B.dylib 0x00007fff890fdfd6 _pthread_start + 331
3 libSystem.B.dylib 0x00007fff890fde89 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000123679000 rcx: 0x00007fff5fbf80d8 rdx: 0x0000000000000000
rdi: 0x0000000000000925 rsi: 0x0000000000000006 rbp: 0x00007fff5fbf80f0 rsp: 0x00007fff5fbf80d8
r8: 0x0000000000000e03 r9: 0x0000000000000000 r10: 0x00007fff8910f0fa r11: 0x0000000000000202
r12: 0x0000000000000000 r13: 0x0000000107b08408 r14: 0x0000000106bb0000 r15: 0x00000001236790c0
rip: 0x00007fff891130b6 rfl: 0x0000000000000202 cr2: 0x000000012367b000
Binary Images:
0x100000000 - 0x10333cfff +com.adobe.Photoshop 13.0.0 (20120315.r.428) <6A87A703-3170-CA73-8C77-35C282C4E264> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
0x1039bf000 - 0x1039bffff libgenkit.dylib ??? (???) <3A91C7FD-2FA1-9BA5-C409-B83C7DCCA1D8> /usr/lib/libgenkit.dylib
0x1039c2000 - 0x1039eeff7 +libtbb.dylib ??? (???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbb.dylib
0x103a05000 - 0x103a13ff3 +libtbbmalloc.dylib ??? (???) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbbmalloc.dylib
0x103a27000 - 0x103a2efff org.twain.dsm 1.9.4 (1.9.4) <92859D8B-FC2A-2932-C510-AB6F6478A546> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x103a36000 - 0x103a50ff7 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x103a59000 - 0x103a5fff7 com.apple.agl 3.0.12 (AGL-3.0.12) <E5986961-7A1E-C304-9BF4-431A32EF1DC2> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x103a66000 - 0x103c74fff +com.adobe.owl AdobeOwl version 4.0.93 (4.0.93) <CB035C4D-044D-4004-C887-814F944E62ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x103cb5000 - 0x1040fbff7 +com.adobe.MPS AdobeMPS 5.8.0.19463 (5.8.0.19463) <8A4BA3B2-6F6A-3958-ABDE-C3E8F21373B0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x104177000 - 0x1044d0ff7 +com.adobe.AGM AdobeAGM 4.26.17.19243 (4.26.17.19243) <E96C804B-158B-D4A2-9A64-482F9ADC29D0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x104539000 - 0x10489afef +com.adobe.CoolType AdobeCoolType 5.10.31.19243 (5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x1048e7000 - 0x10490fff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x104916000 - 0x104942fff +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.7.101.18636 (3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
0x104965000 - 0x104ab2ff7 +com.winsoft.wrservices WRServices 5.0.0 (5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x104b26000 - 0x104b95fef +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <924155A9-D00E-B862-C490-5099BA70B978> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x104bbc000 - 0x104c15fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <BC353D4E-1AE2-3FB5-D3EE-81A09C0C4328> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x104cb5000 - 0x104d3cff7 +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <5FCA15B4-F721-09C3-B412-1F86D9D7DE9E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
0x104da1000 - 0x104dbcff7 +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <BB7B342A-8CBC-4B73-58A2-9B062F590EBC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
0x104dd6000 - 0x105013fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <6839CFB1-74EE-B205-7D82-ABC5428E0810> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x105112000 - 0x10528bfff +com.adobe.ACE AdobeACE 2.19.18.19243 (2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x10529e000 - 0x1052bdfff +com.adobe.BIB AdobeBIB 1.2.02.19243 (1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x1052c4000 - 0x1053a8fe7 +com.adobe.amtlib amtlib 6.0.0.75 (6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x1053b9000 - 0x10547efff +com.adobe.JP2K 2.0.0 (2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x1054cb000 - 0x1054cfff7 +com.adobe.ape.shim 3.3.8.19346 (3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x1054d5000 - 0x105553fff +com.adobe.FileInfo.framework Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 (66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x105564000 - 0x1055c4ff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.3 -c 11 (66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x1055ce000 - 0x105b26fef +com.nvidia.cg 2.2.0006 (???) /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/Cg.framework/Cg
0x106183000 - 0x1061f1fef +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x106245000 - 0x10626affe +adobepdfsettings ??? (???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
0x1062a5000 - 0x1062a9ff7 +com.adobe.AdobeCrashReporter 6.0 (6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x1062af000 - 0x10645ffef +com.adobe.PlugPlug 3.0.0.383 (3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x106516000 - 0x106536fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <DC3301F2-FC6E-70C7-3927-B0DD024210D6> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ocl.framework/Versions/A/aif_ocl
0x106550000 - 0x10660dfff +com.adobe.AdobeExtendScript ExtendScript 4.2.12 (4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x106657000 - 0x106705fef +com.adobe.AdobeScCore ScCore 4.2.12 (4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x106742000 - 0x10683cfe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.7.101.18636 (3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x1068e0000 - 0x106b29fe7 +com.adobe.linguistic.LinguisticManager 6.0.0 (17206) <301AAE8E-BA78-230E-9500-FCCA204B49CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x106bac000 - 0x106bacff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
0x106bf0000 - 0x106bf2fef com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1081ea000 - 0x1081f9fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <1718111B-FC8D-6C8C-09A7-6CEEB0826A66> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x10a2bd000 - 0x10a2d4fe7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <1A440248-D188-CA5D-8C20-5FA33647DE93> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x10a2d8000 - 0x10a2f9fef libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <76503A7B-58B6-64B9-1207-0C273AF47C1C> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x10a2fd000 - 0x10a30ffff libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <00E29B30-3877-C559-85B3-66BAACBE005B> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x10a313000 - 0x10a314fff libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <84C660E9-8370-79D1-2FC0-6C21C3079C17> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x10a45e000 - 0x10a45efff +Enable Async IO ??? (???) <F56F1FB2-9CF1-19A8-0D14-885A652B19B7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
0x10a462000 - 0x10a465fff +FastCore ??? (???) <29AAF151-6CC4-28C5-68B8-0F6600A20435> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x10a65d000 - 0x10a670ff7 +MeasurementCore ??? (???) <2E842E3B-9E4D-6D59-7E5B-A01979288E4B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Mea surementCore
0x10a67c000 - 0x10a6a2ff7 +com.adobe.ape 3.3.8.19346 (3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/adbeapecore
0x10b172000 - 0x10b1b8fe7 +com.adobe.pip ??? (6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x10b26c000 - 0x10b26dfff ATSHI.dylib ??? (???) <D2881261-24A6-4717-D7F9-DF263ABB30F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
0x11db00000 - 0x11db6cfff +MMXCore ??? (???) <B9B6C7FB-CE56-8F6F-664E-DFCBBC5E3ADE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x11dbf3000 - 0x11dc78fff +MultiProcessor Support ??? (???) <467BB668-E9DD-60F4-CAAD-768A98174734> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x11f260000 - 0x11f264fff com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
0x11f269000 - 0x11f26fff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <C35BDA60-35FC-4BE7-B378-DCC73D99E2C9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
0x11f274000 - 0x11f2b1fff com.apple.DP.ScreenInputDevice 15.0 (15.0) <69919162-3E04-C270-B8AB-8E26634D4BBB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
0x122606000 - 0x1226f7fff +com.adobe.AdbeScriptUIFlex ScriptUIFlex 6.2.29 (6.2.29.18602) <2BD3388F-976E-0B1C-55DB-B97A5AF95724> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
0x12277b000 - 0x1227c1fff +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 6.0.0.24 (6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/updaternotifications.framework/Versions/A/UpdaterNotification s
0x123200000 - 0x12345bff7 +com.adobe.PSAutomate 13.0 (13.0) <6EE89DAF-28E8-B15F-1C4B-18D8D19F6452> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Scri ptingSupport
0x12356d000 - 0x1235e7fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x123da8000 - 0x123daefe7 libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <87272933-FB21-81D0-00E6-92BC3D7583FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
0x124097000 - 0x1240bdfff GLRendererFloat ??? (???) <38621D22-8F49-F937-851B-E21BD49A8A88> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
0x1241c5000 - 0x1242abfe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <2D39CB30-54D9-B03E-5FCF-E53122F87484> /usr/lib/libcrypto.0.9.7.dylib
0x124303000 - 0x12432cfef com.apple.mio.DAL.VDC_4 140.0 (1496) <E22DEEC2-EE3D-03AD-9E02-BDE03CE73588> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Cont ents/MacOS/VDC
0x124449000 - 0x124474fff +ServiceManager-Launcher.dylib 389.0.0 (compatibility 2.5.0) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/CS6ServiceManager/lib/ServiceManager-Launcher.dylib
0x1252a2000 - 0x125435fe7 GLEngine ??? (???) <BCE83654-81EC-D231-ED6E-1DD449B891F2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x125466000 - 0x125889fef libclh.dylib 3.1.1 C (3.1.1) <432F5475-F934-92A0-FB49-78F03DA82176> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x13d14d000 - 0x13e0d2fd7 +com.adobe.ape.engine 3.3.8.19346 (3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS /adbeapeengine
0x200000000 - 0x200787fe7 com.apple.GeForceGLDriver 1.6.36 (6.3.6) <4F23289A-D45A-0630-8D7F-4C35A4D2AA00> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
0x7fff80066000 - 0x7fff8007aff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
0x7fff800ba000 - 0x7fff800d0fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
0x7fff8028c000 - 0x7fff802f6fe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
0x7fff80305000 - 0x7fff8030cfff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff80312000 - 0x7fff8031dff7 com.apple.HelpData 2.0.5 (34.1.1) <24DC6CD3-02B7-9332-FF6D-F0C545857B55> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff8031e000 - 0x7fff8034ffff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8035f000 - 0x7fff807a3fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
0x7fff807a4000 - 0x7fff80859fe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
0x7fff811ee000 - 0x7fff81522fef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
0x7fff81523000 - 0x7fff8169afe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8169b000 - 0x7fff81718fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff818d6000 - 0x7fff81919fef libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
0x7fff8191a000 - 0x7fff82016ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
0x7fff82017000 - 0x7fff820a3fef SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8215c000 - 0x7fff8231bfff com.apple.ImageIO.framework 3.0.6 (3.0.6) <2C39859A-043D-0EB0-D412-EC2B5714B869> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
0x7fff82340000 - 0x7fff82468ff7 com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff82469000 - 0x7fff8257fff7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
0x7fff82580000 - 0x7fff825c1fff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff825c2000 - 0x7fff82603fef com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff82604000 - 0x7fff82ffeff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff82fff000 - 0x7fff82fffff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
0x7fff83000000 - 0x7fff83003fff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
0x7fff8300d000 - 0x7fff83059fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff8305a000 - 0x7fff83060ff7 IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff83061000 - 0x7fff830f0fff com.apple.PDFKit 2.5.1 (2.5.1) <38BEE9BB-3716-49BA-7E14-687FE9E066EB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
0x7fff830f1000 - 0x7fff83100fef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff83101000 - 0x7fff83103fff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
0x7fff83104000 - 0x7fff83124fff com.apple.DirectoryService.Framework 3.6 (621.15) <9AD2A133-4275-5666-CE69-98FDF9A38B7A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff83141000 - 0x7fff83162fe7 libPng.dylib ??? (???) <14F055F9-D7B2-27B2-E2CF-F0A222BFF14D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
0x7fff83163000 - 0x7fff8317cfff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
0x7fff8317d000 - 0x7fff831ccff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff831cd000 - 0x7fff839d7fe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
0x7fff839d8000 - 0x7fff839e7fff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff839e8000 - 0x7fff83a1bff7 libTrueTypeScaler.dylib ??? (???) <B7BA8104-FA18-39A2-56E1-922EE7A660AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff83a60000 - 0x7fff83a65fff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff83c69000 - 0x7fff83c6aff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
0x7fff83c77000 - 0x7fff83d38fef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
0x7fff83d39000 - 0x7fff83dbbfff com.apple.QuickLookUIFramework 2.3 (327.7) <73407EAE-6854-E444-37B1-019AAEDEB31B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
0x7fff83dbc000 - 0x7fff83dc9fe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff83e47000 - 0x7fff84081fef com.apple.imageKit 2.0.3 (1.0) <9EA216AF-82D6-201C-78E5-D027D85B51D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
0x7fff84082000 - 0x7fff8413bfff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff8413c000 - 0x7fff8413cff7 com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff8413d000 - 0x7fff84158ff7 com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
0x7fff84177000 - 0x7fff8417cff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
0x7fff8417d000 - 0x7fff84183ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff84184000 - 0x7fff841b4fef com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff841b5000 - 0x7fff841c3ff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff84214000 - 0x7fff84267ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
0x7fff84268000 - 0x7fff842d9ff7 com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8430a000 - 0x7fff843aafff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
0x7fff843ab000 - 0x7fff843c1fef libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
0x7fff843c2000 - 0x7fff848c8ff7 com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff848ec000 - 0x7fff8499cfff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8499d000 - 0x7fff84a37fff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
0x7fff84a38000 - 0x7fff84a98fe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff84a99000 - 0x7fff84aabfe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff84af8000 - 0x7fff84b27ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
0x7fff84b28000 - 0x7fff84db1ff7 com.apple.security 6.1.2 (55002) <772E1B13-8271-02F8-B1FE-023592A7AED7> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff84db2000 - 0x7fff851f9fef com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff851fa000 - 0x7fff851fbfff com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x7fff851fc000 - 0x7fff85247fef com.apple.ImageCaptureCore 1.1 (1.1) <F23CA537-4F18-76FC-8D9C-ED6E645186FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff85248000 - 0x7fff8525cfff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8529a000 - 0x7fff8529aff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8529b000 - 0x7fff852a0fff libGIF.dylib ??? (???) <5B2AF093-1E28-F0CF-2C13-BA9AB4E2E177> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
0x7fff85430000 - 0x7fff85486fe7 libTIFF.dylib ??? (???) <9BC0CAD5-47F2-9B4F-0C10-D50A7A27F461> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
0x7fff85487000 - 0x7fff855a6fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff855a7000 - 0x7fff855a7ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff855a8000 - 0x7fff8568dfef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
0x7fff8568e000 - 0x7fff8574bfff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
0x7fff85796000 - 0x7fff857fefff com.apple.MeshKitRuntime 1.1 (49.2) <4D3045D0-0D50-7053-3A05-0AECE86E39F8> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
0x7fff85818000 - 0x7fff85859fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
0x7fff8585a000 - 0x7fff858a2ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
0x7fff858a3000 - 0x7fff85c40fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff85c41000 - 0x7fff85c44ff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff85e28000 - 0x7fff85e2cff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff85e2d000 - 0x7fff85eacfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff85ead000 - 0x7fff8612ffff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff86146000 - 0x7fff861a8fe7 com.apple.datadetectorscore 2.0 (80.7) <5B6AABCA-C75A-D28F-6A2F-59648F0ABFC8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
0x7fff861a9000 - 0x7fff86367fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <0B4ABA92-C1F0-4548-A157-0CFD65561DA5> /usr/lib/libicucore.A.dylib
0x7fff86368000 - 0x7fff86373ff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
0x7fff863e7000 - 0x7fff864b2fff ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <86982FBB-B224-CBDA-A9AD-8EE97BDB8681> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
0x7fff864d8000 - 0x7fff864f9fff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
0x7fff864fa000 - 0x7fff864faff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8652b000 - 0x7fff86540ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
0x7fff86541000 - 0x7fff86586fff com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
0x7fff865a3000 - 0x7fff868c6fe7 com.apple.JavaScriptCore 6534.57 (6534.57.3) <99973578-D474-3664-1388-61CB47E9D6E9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff8705c000 - 0x7fff870a3fff com.apple.QuickLookFramework 2.3 (327.7) <A8169A96-FAE6-26B2-A9A9-C78BA5787146> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff870a4000 - 0x7fff870a8ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff870f9000 - 0x7fff87189fff com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
0x7fff8718a000 - 0x7fff8719bff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
0x7fff871a4000 - 0x7fff871eeff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
0x7fff871ef000 - 0x7fff87309fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
0x7fff87364000 - 0x7fff87364ff7 com.apple.Carbon 150 (152) <23704665-E9F4-6B43-1115-2E69F161FC45> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff87365000 - 0x7fff873d1fe7 com.apple.CorePDF 1.4 (1.4) <06AE6D85-64C7-F9CC-D001-BD8BAE31B6D2> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff873fc000 - 0x7fff87665fff com.apple.QuartzComposer 4.2 ({156.30}) <C05B97F7-F543-C329-873D-097177226D79> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
0x7fff87666000 - 0x7fff876a9ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff876aa000 - 0x7fff876acfff libRadiance.dylib ??? (???) <61631C08-60CC-D122-4832-EA59824E0025> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
0x7fff876ad000 - 0x7fff87702ff7 com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff87703000 - 0x7fff8772bfff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
0x7fff8772c000 - 0x7fff8772fff7 com.apple.securityhi 4.0 (36638) <AEF55AF1-54D3-DB8D-27A7-E16192E0045A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
0x7fff87730000 - 0x7fff87757ff7 libJPEG.dylib ??? (???) <472D4A31-C1F3-57FD-6453-6621C48B95BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
0x7fff87773000 - 0x7fff87774ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff889b7000 - 0x7fff889b8fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff88fa1000 - 0x7fff890abff7 com.apple.MeshKitIO 1.1 (49.2) <C19D0CCD-1DCB-7EDE-76FA-BF74079AFC6A> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
0x7fff890ac000 - 0x7fff890c3fff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
0x7fff890c4000 - 0x7fff89285fef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff892bd000 - 0x7fff892f6ff7 com.apple.MeshKit 1.1 (49.2) <832A074D-7601-F7C9-6D3A-E1C58965C3A1> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x7fff892f7000 - 0x7fff8937cff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
0x7fff893c8000 - 0x7fff894c0ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <44AADE50-15BC-BC6B-BEF0-5029A30766AC> /usr/lib/libiconv.2.dylib
0x7fff8953f000 - 0x7fff895f5ff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff895f6000 - 0x7fff89621ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
0x7fff89622000 - 0x7fff896f6fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
0x7fff896f7000 - 0x7fff89740ff7 com.apple.securityinterface 4.0.1 (40418.0.1) <9AF33A9F-2D8C-2AE6-868C-EA836C861031> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff89741000 - 0x7fff89741ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff89772000 - 0x7fff897acfff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib
0x7fff897e0000 - 0x7fff89829fef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8992f000 - 0x7fff89a64fff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff89a65000 - 0x7fff89ba3fff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff89c7f000 - 0x7fff89ca4ff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff89ca5000 - 0x7fff89cabff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
0x7fff89cac000 - 0x7fff89d89fff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
0x7fff89d8a000 - 0x7fff89d8aff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff89dde000 - 0x7fff89e6bfff com.apple.iLifeMediaBrowser 2.5.5 (468.2.2) <0A7B422E-5D79-9980-2477-05DC2CB5CF7C> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
0x7fff89e6c000 - 0x7fff89ea7fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
0x7fff89ea8000 - 0x7fff89ecbfff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff89ecc000 - 0x7fff89f13ff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff89f14000 - 0x7fff89f1efff com.apple.DisplayServicesFW 2.3.3 (289) <97F62F36-964A-3E17-2A26-A0EEF63F4BDE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff89f1f000 - 0x7fff8a21dfff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
0x7fff8a21e000 - 0x7fff8a224fff libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <D2F8C7E3-CBA1-2E66-1376-04AA839DABBB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x7fff8a2a6000 - 0x7fff8a416fff com.apple.QTKit 7.7 (1791) <1BC285ED-A1EE-4A80-D264-C93803C439DD> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8a41c000 - 0x7fff8a42dfff com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x7fff8a42e000 - 0x7fff8a46cfe7 libFontRegistry.dylib ??? (???) <395D7C0D-36B5-B353-0DC8-51ABC0B1C030> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
0x7fff8a46d000 - 0x7fff8a4ebff7 com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
0x7fff8a4ec000 - 0x7fff8a5aefe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
14. Re: New CS6 is crashing and now my old CS2 is crashing too.
Chris CoxDec 20, 2012 12:21 PM (in response to heyhon)
CS2 report doesn't make sense - something corrupted the stack.
CS6 report makes sense - you're crashing in MacOS filesystem code.
Usually that is caused by corrupt disk structures, which can sometimes be repeaired with Disk Utility.
Also, Apple says they made this crashing code much better in 10.8 (but it still crashes sometimes).
15. Re: New CS6 is crashing and now my old CS2 is crashing too.
gator soup Dec 20, 2012 12:47 PM (in response to heyhon)Restarted as a different user and CS6 seemed to be fine... CS2 crashed immediately.
You could have a CS2 conflict (like a bad 3rd party plugin) or corruption or bad font (all OS/Adobe updates ran?)
What do you mean by a bad system install?
something in your installed software is corrupted and/or buggy
at this point, since it doesn't clear in a New User, i would download the latest Apple "Combo Updater"
http://support.apple.com/kb/DL1399
and install it on top of your system (THEN run Apple Software Update and all Adobe> Help> Updates)...
reboot test in new user
if you need CS2, you possibly uninstall/reinstall Photoshop CS2, and test in new user
and let us know the results...
