13 Replies Latest reply on Dec 19, 2012 1:21 PM by kglad
    Create Empty Movie Clip in a Loop
    TheScarecrow
      I have an Array with image names in it.  I want to loop through the array and create empty movie clips and load an image into it.  I also want to do this in rows of 3.  RIght now I am just having trouble getting the images to load.  Any help would be appreciated.  Thanks.
      CODE:
      function placeImages() {
                trace("Place Images");
                trace(currentArray);
                startX = 110;
                startY = 86;
                xSpace = 63;
                xSpace = 50;
                row = 1;
                switch (currentArray)
                                    case "regArray2":
                                              for (var x = 1; x < regArray2.length+1; x++) {
                                                        //trace("AddChild");
                                                        this.createEmptyMovieClip("picture"+x, 1000);
                                                        this["picture"+x]._x = 110;
                                                        this["picture"+x]._y = 86;
                                                        this["picture"+x]._xscale = 10;
                                                        this["picture"+x]._yscale = 10;
                                                        this["picture"+x].loadMovie(regArray2[x]);
                                              break;
        • 1. Re: Create Empty Movie Clip in a Loop
          show regArray2 if the following fails:
                    startX = 110;
                    startY = 86;
                    xSpace = 63;
                    xSpace = 50;
                    row = 1;
                                        case "regArray2":
                                                  for (var x = 0; x < regArray2.length; x++) {
                                                            this.createEmptyMovieClip("picture"+x, this.getNextHighestDepth());
                                                            this["picture"+x]._x = x%3*200+100;
                                                            this["picture"+x]._y = 200*Math.floor(x/3)+100;
                                                          // scale after loading is complete
                                                  break;
          • 2. Re: Create Empty Movie Clip in a Loop
            TheScarecrow Level 1
            That is perfect.  I have one more question... how can I link them to a bigger image if they want to click on it and open it bigger within flash not a sepreate window?
            • 3. Re: Create Empty Movie Clip in a Loop
              flash (and i) need some way to determine the larger images' path/name.  that could be another array or some rule about converting the regArray2 element names to the large image names.
              p.s.  please mark helpful/correct responses.
              • 4. Re: Create Empty Movie Clip in a Loop
                its the smae image.  That is why I was scaling it.
                • 5. Re: Create Empty Movie Clip in a Loop
                  so, the initially loaded images are too large and you want to scale them down when loaded and scale them back up when clicked?
                  if yes, you can use:
                            startX = 110;
                            startY = 86;
                            xSpace = 63;
                            xSpace = 50;
                            row = 1;
                                                case "regArray2":
        this["picture"+x].createEmptyMovieClip("loadTarget",0);
        this["picture"+x].loadTarget._xscale=this["picture"+x].loadTarget._yscale = 50;
        this["picture"+x].onRelease=function(){
        this.loadTarget._xscale=this.loadTarget._yscale=100;
        this["picture"+x].loadTarget.loadMovie(regArray2[x]);
                                                          break;
                  • 6. Re: Create Empty Movie Clip in a Loop
                    Yes.  When they click on them I want them to scale up to normal.  then if they click off of the image it goes back to down to small size.
                    • 7. Re: Create Empty Movie Clip in a Loop
                      using rollover and rollout will work better:
                                startX = 110;
                                startY = 86;
                                xSpace = 63;
                                xSpace = 50;
                                row = 1;
                                                    case "regArray2":
        this["picture"+x].loadTarget._xscale=this["picture"+x]._yscale = 10;
        this["picture"+x].onRollOver=function(){
        this["picture"+x].onRollOut=function(){
        this.loadTarget._xscale=this.loadTarget._yscale=10;
                                                              break;
                      • 8. Re: Create Empty Movie Clip in a Loop
                        It doesnt seem to work right.  It scales it corretly in X direction but not the Y.  I am nost sure why.  Everything looks right.  Got any ideas?
                        • 9. Re: Create Empty Movie Clip in a Loop
                          there's a typo.  use:
                                    startX = 110;
                                    startY = 86;
                                    xSpace = 63;
                                    xSpace = 50;
                                    row = 1;
                                                        case "regArray2":
        this["picture"+x].loadTarget._xscale=this["picture"+x].loadTarget_yscale = 10;
        break;
                          • 10. Re: Create Empty Movie Clip in a Loop
                            Awesome. Thanks.  You are great.
                            • 11. Re: Create Empty Movie Clip in a Loop
                              you're welcome.
                              • 12. Re: Create Empty Movie Clip in a Loop
                                Kglad
                                Can this be altered so that the rollver places the image at like 100 20 and over all the other images?
                                • 13. Re: Create Empty Movie Clip in a Loop
                                  the rollovered image can be placed at 100,20:
                                            startX = 110;
                                            startY = 86;
                                            xSpace = 63;
                                            xSpace = 50;
                                            row = 1;
        case "regArray2":
        this["picture"+x].loadTarget._xscale=this["picture"+x].loadTarget_ysc ale = 10;
                                  this["picture"+x].origX = this["picture"+x]._x;
                                  this["picture"+x].origY = this["picture"+x]._y;
                                  this._x=100;
                                  this._y=20;
                                  this._x=this.origX;
                                  this._y=this.origY;
        break;
