0 Replies Latest reply on Dec 18, 2012 9:09 PM by huangxinghui
    StackOverFlow Error in release mode
    huangxinghui Level 1
      Use Flex SDK3.5
      the exmaple code:
       <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          creationComplete="init()">
       <mx:Script>
        <![CDATA[
         import mx.collections.ArrayCollection;
         private function init():void
          qryAlarmMemoHandler(new ArrayCollection());
         private function qryAlarmMemoHandler(result:Object):void
          var scheduleArr:ArrayCollection = new ArrayCollection();
          for (var i:int=0;i<5,i<result.length;i++)
           var item:Object = result[i];
           item.date = item.BEGIN_DATE;
           item.content = item.TITLE;
           scheduleArr.addItem(item);
       </mx:Script>
      </mx:Application>
      the problem:
      when compile this code in debug mode, it works fine.
      but when compile the code in release mode, it works wrong,
      the error message:
      VerifyError: Error #1023: Stack overflow occurred.
       at StackOverflowExample/init()
       at StackOverflowExample/___StackOverflowExample_Application1_creationComplete()
       at flash.events::EventDispatcher/dispatchEventFunction()
       at flash.events::EventDispatcher/dispatchEvent()
       at mx.core::UIComponent/dispatchEvent()
       at mx.core::UIComponent/set initialized()
       at mx.managers::LayoutManager/doPhasedInstantiation()
       at Function/http://adobe.com/AS3/2006/builtin::apply()
       at mx.core::UIComponent/callLaterDispatcher2()
       at mx.core::UIComponent/callLaterDispatcher()
      when i annotate this code
           //item.date = item.BEGIN_DATE;
           //item.content = item.TITLE;
      it works fine again.
      i don't know what cause this problem.
      Thanks for any help!
      Best Regards!
      Huang
