2 Replies Latest reply on Jul 17, 2006 8:05 AM by cmyck
    fdb shell script is broken
    cmyck Level 1
      Hi all,
      My copy of fdb shell script in the /bin dir of the SDK was fubar. Calling it yielded:
      G5:/Developer/SDKs/Flex/bin cmyk$ sh fdb
      : command not found
      : command not found
      'db: line 8: syntax error near unexpected token `in
      'db: line 8: `case `uname` in
      I'm not much of a shell scripter. But I was able to make it work using the mxmlc script.
      Here's the corrected source:
      #!/bin/sh
      # fdb launch script for unix. On windows, fdb.exe is used and
      # java settings are managed in jvm.config in this directory.
      case `uname` in
      CYGWIN*)
      OS="Windows"
      OS=Unix
      esac
      if [ $OS = "Windows" ]; then
      # set FLEX_HOME relative to mxmlc if not set
      test "$FLEX_HOME" = "" && {
      FLEX_HOME=`dirname $0`/..
      FLEX_HOME=`cygpath -m $FLEX_HOME`
      elif [ $OS = "Unix" ]; then
      fi
      VMARGS="-Dapplication.home=$FLEX_HOME -Xmx384m"
      java $VMARGS -jar $FLEX_HOME/lib/fdb.jar $*
      Cheers,
      Phil
        • 1. Re: fdb shell script is broken
          Level 7
          The issue is the line endings in fdb are dos carriage return/line feeds. The
          workaround is convert the line endings in the script. This can be easily
          accomplished using one of the following commands:
          dos2unix -o fdb
          or something like the following command:
          cat fdb | tr -d '\r' > fdb
          -brent
          "cmyck" <webforumsuser@macromedia.com> wrote in message
          news:e9e88m$n43$1@forums.macromedia.com...
          > Hi all,
          > it
          > yielded:
          > : command not found
          > : command not found
          > mxmlc script.
          > #!/bin/sh
          > case `uname` in
          > CYGWIN*)
          > OS="Windows"
          > OS=Unix
          > esac
          > fi
          > Cheers,
          > Phil
          • 2. Re: fdb shell script is broken
            cmyck Level 1
            Thanks Brent,
            I suspected something like that.
            The original also had redundant lines of code in it.
            This was used twice:
            Cheers,
            Phil
