2 Replies Latest reply on Dec 20, 2012 3:23 AM by robert-sfl
    Some images missing in RTF export
    robert-sfl Level 1
      Hi all,
      when exporting RTF from Indesign CS6 some images are missing. All Images (those OK as well as those missing) are placed in anchored frames. In the Links view I checked that all references are resolved. They are not marked not to print.
      Any ideas what I should look for? I must add that I am a rather basic Indesign user. Searching the forum I found a few similar questions, but no answers yet.
        • 1. Re: Some images missing in RTF export
          Joel Cherney Level 5
          I can't find it right now, but there was another thread about this sometime in the last six to twelve months. I suspect that it has something to do with the RTF-writing abilities of InDesign. My recollection was that the image data was actually in the RTF, but it was not being rendered.
          What are you using to view your RTFs?  Can you look at the RTFs in another application (LibreOffice, TextEdit, et cetera) to verify that it's an RTF-source problem and not an RTF-viewer problem? I deal with quite a few applications that write, ah, flaky RTFs (many translation tools do this poorly) and sometimes you can fix flaky RTFs by simply opening up the RTF in another application, making an insignificant change, and resaving.
          Another thing to look for is the formats of the placed images - you say some are missing. But are all the missing images (or all the present images) saved in a single format?
          • 2. Re: Some images missing in RTF export
            robert-sfl Level 1
            Hi Joel, I viewed the RTF output in Word and FrameMaker and the result
            was the same, therefore I assumed that the image was actually missing.
            Thanks for the idea though, I will try a few other tools.
            I could fix one image by moving it from behind to before the list. Strange..
