5 Replies Latest reply on Dec 19, 2012 5:00 PM by FamilyLegacyVideo
    Premiere CS5 not importing .mov files - codec missing or unavailable
    FamilyLegacyVideo Level 1
      I'm on a Windows 7 PC running Premiere Pro CS5. Have encountered a problem with .mov files that I haven't had before. I recently received three files from a shoot at a local tv station. They are .mov files and I believe they are in an XD CAM wrapper or format. I've gotten files from this station before and have imported them with no trouble (not sure if the earlier files were XD CAM, though). When I try to import, I get the error message: Codec missing or unavailable. Would using the Prism video convertor to convert to another format be the way to go? The file sizes range from 7.18 GB to 14.9 GB. Thanks in advance.
        • 1. Re: Premiere CS5 not importing .mov files - codec missing or unavailable
          First, lets find out exactly what is inside that MOV wrapper
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below... a screen
          shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30
          For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
          • 2. Re: Premiere CS5 not importing .mov files - codec missing or unavailable
            John,
            Here's the result of a GSpot scan on one of the troublesome files.
            • 3. Re: Premiere CS5 not importing .mov files - codec missing or unavailable
              Here's more info on the above clip:
              General
              Complete name                    : F:\FLV Projects\TalkingMatters\Leah Fabiano-Smith121312\Smith01.mov
              Format                           : QuickTime
              Format/Info                      : Original Apple specifications
              Format_Commercial_IfAny          : XDCAM EX422
              File size                        : 15.0 GiB
              Duration                         : 38mn 58s
              Overall bit rate                 : 55.0 Mbps
              Encoded date                     : UTC 2012-12-13 08:53:51
              Tagged date                      : UTC 2012-12-13 08:53:51
              ©TSC                             : 2997
              ©TSZ                             : 100
              Video
              Format                           : MPEG Video
              Format version                   : Version 2
              Format profile                   : 4:2:2@High
              Format settings, BVOP            : Yes
              Format settings, Matrix          : Default
              Format settings, GOP             : M=3, N=15
              Codec ID                         : xd5b
              Codec ID/Hint                    : XDCAM
              Duration                         : 38mn 58s
              Bit rate mode                    : Constant
              Bit rate                         : 50.0 Mbps
              Width                            : 1 888 pixels
              Original width                   : 1 920 pixels
              Height                           : 1 062 pixels
              Original height                  : 1 080 pixels
              Display aspect ratio             : 16:9
              Frame rate mode                  : Constant
              Frame rate                       : 29.970 fps
              Color space                      : YUV
              Chroma subsampling               : 4:2:2
              Bit depth                        : 8 bits
              Scan type                        : Interlaced
              Scan order                       : Top Field First
              Compression mode                 : Lossy
              Bits/(Pixel*Frame)               : 0.832
              Stream size                      : 13.6 GiB (91%)
              Language                         : English
              Encoded date                     : UTC 2012-12-13 09:33:19
              Tagged date                      : UTC 2012-12-13 09:33:19
              Audio
              Format                           : PCM
              Format settings, Endianness      : Big
              Format settings, Sign            : Unsigned
              Codec ID                         : in24
              Duration                         : 38mn 58s
              Bit rate                         : 4 608 Kbps
              Channel(s)                       : 4 channels
              Sampling rate                    : 48.0 KHz
              Bit depth                        : 24 bits
              Stream size                      : 1.25 GiB (8%)
              Language                         : English
              Menu
              Language                         : English
              • 5. Re: Premiere CS5 not importing .mov files - codec missing or unavailable
                Thanks, John. I was able to get the clips to play using the demo version of Calibrated XD and QuickTime player - but still not in Premiere Pro. I assume I'd have to convert the files using QuickTime Pro - but I'm not crazy about having to purchase both that and Calibrated XD. Luckily, the TV station still has the files on their server and can export them using the ProRes codec, which has worked just fine for me in the past. So, lesson learned - and thanks for your help. Have a Happy New Year!
