1 Reply Latest reply on Dec 19, 2012 2:19 PM by Jeff_Coatsworth
    Glossary Not Appearing in Windows 7 64 Bit
    srmsrm
      I have RH7 installed on XP. All is OK when I view the CHM file in XP.  When I view the CHM file in W7 64 Bit, the glossary does not appear.
      Do I need to install RH7 under W7 64 bit to get the glossary to work under W7 64 bit?  If that is true, one issue is I have Office 2010 which RH7 doesn't support and I'm not in a position to upgrade to RH10.
      Is there any way to keep RH7 installed on XP and generate the CHM file that shows the glossary under W7 64 bit?
      Thank you.
      Shawn
