1 Reply Latest reply on Dec 20, 2012 5:47 AM by kasq
    SCR Reference
    Shashi Aachar
         I would like to know how can i make my class object as reference?
         For ex:
          /** @scr.reference */
          private SlingRepository slingRepository;
         In the java i have to get slingRepository through reference only. So i want to make my customized class objects accessible through reference only. Provide pointers if u know, Thanks for helping.
      Regards,
      Shashi
        • 1. Re: SCR Reference
          kasq Level 3
          Try to read following links:
          http://dev.day.com/content/ddc/blog/2008/05/slingosgi.html
          http://blogs.adobe.com/kmossman/2012/04/osgi-sling-service-example.html
          and bellow some example code which maybe hepls you somehow:
          ISampleService.java
          package com.project.intf;
          public interface ISampleService {
          SampleService.java
          package com.project;
          import org.apache.felix.scr.annotations.Component;
          import org.apache.felix.scr.annotations.Properties;
          import org.apache.felix.scr.annotations.Property;
          import org.apache.felix.scr.annotations.Service;
          import org.osgi.service.component.ComponentContext;
          import com.project.intf.ISampleService;
          @Component(immediate=true, metatype=false, label="COMPONENT NAME")
          @Service
          @Properties(value = {
                    @Property(name="service.description", value="Sample Service")
          public class SampleService implements ISampleService {
                    protected synchronized void activate(ComponentContext componentContext) {
                              //some code here
                      protected void deactivate(ComponentContext componentContext) {
                              //some code here
          and then if you want access to your sample service using reference (for example in your custom  Sling Post Servlet):
          ExampleServlet.java
          import org.apache.felix.scr.annotations.Reference;
          import org.apache.felix.scr.annotations.ReferenceCardinality;
          import org.apache.felix.scr.annotations.ReferencePolicy;
          import org.apache.sling.api.SlingHttpServletRequest;
          import org.apache.sling.api.SlingHttpServletResponse;
          import org.apache.sling.api.servlets.SlingAllMethodsServlet;
          @Component(immediate=true, metatype=false, label="........")
          @Service
                    @Property(name="sling.servlet.methods", value="GET"),
               @Property(name="sling.servlet.resourceTypes", value="sling/servlet/default"),
               @Property(name="sling.servlet.selectors", value="ex"),
               @Property(name="sling.servlet.extensions", value="html")
          public class ExampleServlet extends SlingAllMethodsServlet {
             @Reference(policy=ReferencePolicy.DYNAMIC, cardinality=ReferenceCardinality.MANDATORY_UNARY)
             private ISampleService yourservice;
                    protected void doGet(SlingHttpServletRequest request, SlingHttpServletResponse response) throws ServletException {
               // some code
          Of course this is a example code , but maybe it hepls you to understand a litte bit OSGI Sling Services
          Regards,
          kasq
