7 Replies Latest reply on Dec 28, 2012 10:44 AM by ECBowen
    PP5.5 very slow on brand new iMac
    GPpictures
      I have seen a number of threads similar to this, but none have been helpful.
      I purchased a brand new 21.5" iMac late last year.
      Processor 2.8 GHz Intel Core i7
      Memory 12 GB 1333 MHz DDR3
      I installed CS5.5, and found it to be pretty slow. So I got some more RAM. I now hav 12GB of RAM. I saw an improvement, but it's still really slow. Premiere is the worst. When I press play, even on low-res video footage, it often takes a couple seconds to start playing.
      I clicked Project Settings, and for Renderer, the "Mercury Playback Engine Software Only" option is grayed out.
      I looked at some threads... and apparently I have to manually set a graphics card or something like that? I know nothing about that.
      I have finally had enough of this. Very frusterating. I was sold in PP5.5's speed, and it has been extremely slow.
      Any suggestions? Thanks!
        • 1. Re: PP5.5 very slow on brand new iMac
          RjL190365 Level 4
          Your 2011 iMac has only an AMD (formerly ATi) GPU - and you cannot upgrade or even replace it at all. Worse, Premiere Pro CS5.5 does not support OpenCL at all for GPU acceleration in its MPE engine (CS5.5 supports only CUDA, which is used by most recent Nvidia GPUs, for GPU acceleration). Worst of all, your iMac's GPU has only 512MB of dedicated graphics RAM. And because your iMac does not have enough dedicated graphics RAM, Premiere Pro will be permanently locked into the MPE software-only mode.
          • 2. Re: PP5.5 very slow on brand new iMac
            GPpictures Level 1
            Thank you very much for the reply.
            This is very disheartening. So, there is nothing I can do? Would upgrading to CS6 solve the problem?
            • 3. Re: PP5.5 very slow on brand new iMac
              GPpictures Level 1
              Could a thunderbolt external harddrive help?
              • 4. Re: PP5.5 very slow on brand new iMac
                Probably not... CS6 does add support for "some" ATI cards for hardware MPE, but I think the cards still need 1Gig of video ram
                But, follow the link inside http://forums.adobe.com/thread/773101 to read more
                • 5. Re: PP5.5 very slow on brand new iMac
                  RjL190365 Level 4
                  Basically, there is nothing that you can do with that 2011 iMac. Upgrading to CS6 still would not have allowed you to enable GPU acceleration: OpenCL GPU acceleration only works if the GPU has 1GB or more dedicated RAM (and officially, CS6 for MacOS only supports Macbook Pros, not iMacs, with the HD 6750M or HD 6770M and 1GB or more dedicated graphics RAM for OpenCL GPU acceleration on AMD GPUs). Your iMac's GPU has only 512MB of dedicated RAM, as I mentioned. That's too little RAM to even allow the enabling of the GPU acceleration in CS6.
                  As for the addition of the Thunderbolt external hard drive, that would still gain some improvement in performance, especially since your iMac is bottlenecked by the use of only a single disk (the OS disk for absolutely everything). The iMac's internal hard drive uses a SATA interface like Windows PCs use - and a single SATA connection can only pass data in one direction at a time (this is what I meant by "half-duplex"); a block of transfers in one direction (either read or write) must be completed before any transfers start moving in the opposite direction. And most video editing tasks require simultaneous transfers in both directions on a disk interface (which a single SATA connection cannot perform; this is why we often needed two or more disks).
                  • 6. Re: PP5.5 very slow on brand new iMac
                    GPpictures Level 1
                    Thanks for that detailed reply. Considering a Thunderbolt harddrive.
                    A user on another website said "If you plan to edit HD material, your really need a PCIE or USB 3 external raid in order for PrP to function. Media should not be on internal or firewire drives for best performance."
                    I have never owned one of these. What do you think?
                    • 7. Re: PP5.5 very slow on brand new iMac
                      ECBowen Most Valuable Participant
                      A Thunderbolt drive or raid would be the ideal upgrade to work from. That will be about as good as the performance will be on that IMac with Adobe.
                      Eric
                      ADK
