2 Replies Latest reply on Dec 24, 2012 10:10 AM by Aiesyaah
    Revert statements in Adobe Edge
    Aiesyaah Level 1
      I have solved that part of the animation that allows only 1 draggable element in a droppable area at any one time. Am applying it to all the draggable elements now. However, I'm having some kind of problem right now.
      I can drag the elements around. but now, i can only drop one element in the whole droppable areas. The rest of the elements will be revert back to it's original position without even dropping in first.
      I have also placed a reset button on the stage but I don't know why it won't appear eventhough I have tried changing it's position on the "Elements" column.
      This is my file so far, link: https://www.box.com/s/5a0dsq29upy2wtatxmyb
      This is an excerpt of my code which can work for the 1st draggable element.
      yepnope(
          nope:[
              'js/jquery-ui-1.9.2.custom.min.js',
              'js/jquery.ui.touch-punch.min.js',
              'css/jquery-ui-1.9.2.custom.min.css'
          complete: init
      function init() {
                var stage = sym.$("Stage");
                var animalArray = new Array();
      //DRAGGABLE. case1, _2
                var _2 = sym.$("_2");
                _2.css("position", "absolute");
                _2.draggable({ disabled: false });
                _2.draggable({ containment: stage });
                _2.draggable({
                snap: '.target1',
         snapMode: 'centre',
      //REVERT PART 1
         revert: "invalid",
         stop: function() {
         $(this).draggable('option', 'revert', 'invalid');
                animalArray.push(_2);
      //DROPPABLE
                var position1 = sym.$("position1");
                position1.css("position", "absolute");
                position1.droppable({
      //REVERT PART 2
         greedy: true,
                accept: ".allcases",
                drop: function(event, ui) {
                //console.log(ui['draggable'].eq(0).attr('id'));
                //REVERT PART 3
                if($('.filled').length<1){
                var draggedElement = ui['draggable'].eq(0).attr('id').replace("Stage_", "")
                //console.log(draggedElement)
                //for loop
                for(var i=0 ; i<animalArray.length;i++){
                var element = animalArray[i].attr('id').replace("Stage_", "")
                if(draggedElement == element){
                //change the animals width and height upon dropped over here
                animalArray[i].css('width','75px');
                animalArray[i].css('height','75px');
                //REVERT PART 4
                $(this).append('<div class="filled" ></div>')
                }else{
                ui.draggable.draggable('option', 'revert', true);
      //and these are the codes that don't work
      //DRAGGABLE. case2, _5, position2
                var _5 = sym.$("_5");
                _5.css("position", "absolute");
                _5.draggable({ disabled: false });
                _5.draggable({ containment: stage });
                _5.draggable({
                snap: '.target2',
         snapMode: 'centre',
         //REVERT PART 1
         revert: "invalid",
         stop: function() {
                animalArray.push(_5);
      //DROPPABLE
                var position2 = sym.$("position2");
                position2.css("position", "absolute");
      //drop into position2
                position2.droppable({
      //REVERT PART 2
         greedy: true,
      //REVERT PART 3
      //edit the length?
                //orig: if($('.filled').length<1){
                //if($('.filled').length<6){ //other elements will still be stacked on top of it.
      //if($('.filled').length<10){ //other elements will still be stacked on top of it. but im able to drop e 1st element
      if($('.filled').length<50){
                //for loop
      //REVERT PART 4
                }else{
      //end of codes--------------//
      //there's more elements of course, so you download the folder from the link above.
      I hope anyone can help me. Thank you so much
