1. Re: Google Maps
Aishvarya Raj Rastogi Dec 21, 2012 3:39 PM (in response to Asad 6SM)Hi Asad,
1. The reason you are unable to see the map in other browsers is the CSS you have used in your template. I removed the template from dealers location page and the map was displayed. I tested it in Firefox. Please refer to the following link http://screencasteu.worldsecuresystems.com/aish/2012-12-22_0502.png
2. Again, missing corners is because of the conflicting CSS. I removed the template and it worked. Please refer to the following link http://screencasteu.worldsecuresystems.com/aish/2012-12-22_0505.png
I suspect the zoom issue is due to the CSS as well. Please test your template for different browsers, make it compatible with all the browsers and then try again.
Cheers,
Aish
2. Re: Google Maps
Asad 6SM Dec 21, 2012 9:05 PM (in response to Aishvarya Raj Rastogi)Hi Aish
Thanks for your reply. Do you have any idea which bit of the CSS is causing the issue? I can't seem to find it.
Kind Regards
Asad Ali
Six Serving Men
