5 Replies Latest reply on Dec 31, 2012 8:51 AM by joel_pau
    Integrating some CSSDeck into Edge
    Dam4222 Level 1
      Hi Community,
      Can anyone help me figure out how to integrate this CSSDeck code into an Edge Composition? http://cssdeck.com/labs/j3zlzqro/35? I tried to follow Joel Pau example here: http://forums.adobe.com/message/4896224#4896224 but had no luck implmenting. My knowledge of code is pretty weak so I have troulbe following.
      Thanks for your help!
      Adam
        • 1. Re: Integrating some CSSDeck into Edge
          joel_pau Level 5
          So, it's a new library mixing mainly svg tags and window.requestAnimationFrame.
          ==> original version: http://dev.web-gate.fr/repulsive/
          ==> library home page: http://d3js.org/
          ==> tutorial about circles: http://mbostock.github.com/d3/tutorial/circle.html
          Implementation.
          Are required: yepnope and javascript window from http://cssdeck.com/labs/j3zlzqro/35
          So, you open compositionReady panel and you perform 2 copy and paste.
          1) Firstly, you copy and paste this code:
          yepnope({
                            nope:['http://d3js.org/d3.v3.min.js'],
                            complete: init
          function init() {}
          2) Then you copy and paste javascript window from http://cssdeck.com/labs/j3zlzqro/35 within function init() { ... }
          You save. It doesn't work. You have to rewrite these lines:
          var w = sym.$("Stage").width(),
               h = sym.$("Stage").height();
          var svg = d3.select("#Stage").append("svg:svg")
          svg.selectAll("circle").on("mousemove", function() {
                     var p1 = d3.mouse(this);
                     root.px = p1[0];
                     root.py = p1[1];
                     force.resume();
          Now it works using a MacBook Pro and Safari. But poor performance.
          Others operating systems and browsers: i don't know.
          • 2. Re: Integrating some CSSDeck into Edge
            Dam4222 Level 1
            Hey Joel,
            This is fantastic, two questions for you: 1) How would I add this to my own layer, i.e. if I create a rectangle and only want it within the rectangle instead of on the stage? 2) I would have had no idea that I should change things in the Javascript the way you did in this scenario. How can I educate myself to learn what to change and recognize these things?
            Thanks so much for all your help.
            Adam
            • 3. Re: Integrating some CSSDeck into Edge
              joel_pau Level 5
              So: circles and one rectangle on Stage.
              var w = sym.$("Rectangle").width(),
                    h = sym.$("Rectangle").height();
              var svg = d3.select(sym.lookupSelector("Rectangle")).append("svg:svg")
              Now, this line: var nodes = d3.range(100).map(function() { return {radius: Math.random() * 19 + 4}; }),
              100 ==> number of circles, you can modify.
              19+4 ==> circle size: replacing 19 by 9 means small circles and 29 big circles.
              About learning or skills, tonight i don't find an idea. I think about and look for tomorrow.
              • 4. Re: Integrating some CSSDeck into Edge
                joel_pau Level 5
                Optimized versions.
                1) Mouse effect works better using this code:
                svg.on("mousemove", function() {
                           root.px = p1[0];
                           root.py = p1[1];
                           force.resume();
                2) Attachments.
                Big and small Stages.
                • 5. Re: Integrating some CSSDeck into Edge
                  joel_pau Level 5
                  Adam.Perlis@gmail.com wrote:
                  Hey Joel,
                  Adam
                  About 2) that is learning.
                  Are required knowledge on: HTML DOM, CSS DOM, jQuery.
                  Therefore, basics are: html, css, dom, javascript.
                  At last but not least: the specifics of main browsers.
