3 Replies Latest reply on Dec 23, 2012 10:21 PM by Blackmore111
    How to show one message when validation of several required fileds fails
    Blackmore111
      Hello.
      I'm using ColdFusion 9 and I have a question.
      When we have a form with required fields coded like this:
      <cfinput ... required="yes" message="Enter a value 1" />
      <cfinput ... required="yes" message="Enter a value 2" />
      <cfinput ... required="yes" message="Enter a value 3" />
      When user sumbits this form he will se an alert window:
      Enter a value 1
      Enter a value 2
      Enter a value 3
      How can I make it other way so then one single message is outputted like:
      "Enter values for all required fields"
      Not one message for each required field.
      Sorry for my imperfect English. Thank you.
        • 1. Re: How to show one message when validation of several required fileds fails
          BKBK Adobe Community Professional & MVP
          I don't think the automatic validation built into cfinput will allow you to do that. You should create your own validation. Here is an example to get you started:
          <script language="javascript" type="text/javascript">
              function validate() {
                  // the values of the required fields
                  var a_val = document.getElementById("a_id").value;
                  var b_val = document.getElementById("b_id").value;
                  var c_val = document.getElementById("c_id").value;
                  // trim any leading and trailing spaces
                  a_val = a_val.replace(/^\s+|\s+$/g,'');
                  b_val = b_val.replace(/^\s+|\s+$/g,'');
                  c_val = c_val.replace(/^\s+|\s+$/g,'');
                  // validate
                  if(a_val=='' || b_val=='' || c_val=='') {
                          alert('You must enter values for the required fields a, b and c');
                          return false;
                  else
                  return true;
          </script>
          <cfif isdefined("form.sbmt")>
          <cfdump var="#form#">
          </cfif>
          <cfform onsubmit="return validate()">
          a:<cfinput name="a" id ="a_id" type="text">
          b:<cfinput name="b" id ="b_id" type="text">
          c:<cfinput name="c" id ="c_id" type="text">
          <cfinput name="sbmt" type="submit" value="send"/>
          </cfform>
          This is just a basic validation script to illustrate the principle. You may of course make it as sophisticated as you want, or even import specialized Javascript libraries to do the validation for you.
          • 2. Re: How to show one message when validation of several required fileds fails
            Blackmore111 Level 1
            Thank you very much, that's the very thing I needed.
            • 3. Re: How to show one message when validation of several required fileds fails
              So, thanks to BKBK, I created an universal solution to this. Here it goes if anyone'll need it.
              Here is cffunction that generates validation code:
              cffunction name="generate_validation" access="public" returntype="string">
                                  <cfargument name="fieldList" type="string" required="yes">
                        <cfoutput>
                                  <cfsavecontent variable="scr">
                      <cfloop list="#fieldList#" index="i">
                        var val_#i# = document.getElementById("#i#").value;
                        val_#i# = val_#i#.replace(/^\s+|\s+$/g,'');
                        if (val_#i# == '')
                         document.getElementById("#i#").focus();
                         alert('Please fill all required fields!');
                         return false;
                      </cfloop>
                      return true;
              </cfsavecontent>
              </cfoutput>
                                  <cfreturn scr>
                        </cffunction>
              And it works from .cfm page like this:
              <cfinvoke component="iCFC.udfs" method="generate_validation" returnvariable="scr" fieldList="name,image,code,manual_create_order" />
              <cfoutput>
                  <script>
                      #scr#
                  </script>
              </cfoutput>
                <cfform onsubmit="return validate()" action="contents/service/process_service.cfm" name="fProcess" method="post" >
