14 Replies Latest reply on Jan 6, 2013 3:54 AM by mafrustrated
    Adobe Reader X (10.1.4) issue [Flash Player, actually]
    mafrustrated Level 1
      I just updated to Adobe Reader X (10.1.4).  Since the update it takes at least 2 minutes (no exaggeration) to load a webpage.  Even navigating from page to page within this website takes 2 minutes to load ... each time I change pages.
      I have Windows Vista.
      I updated to Adobe Flash Player 11 ActiveX shortly before updating Adobe Reader by the internet worked fine after that update.
      I'd like to remove the Adobe Reader X update, revert to an earlier version or repair the current one.
      Message was edited by: Pat Willener - changed subject line.
        • 1. Re: Adobe Reader X (10.1.4) issue
          Claudio González Most Valuable Participant
          Although I doubt thar your slow downloads are in any way related with Reader, you can try using this tool to remove all traces of previous version(s) of Reader:
          http://labs.adobe.com/downloads/acrobatcleaner.html
          • 2. Re: Adobe Reader X (10.1.4) issue
            You were right Claudio.  I used the tool you suggested and removed Reader from my computer.  That didn't fix the problem.  So, I decided to go to the Microsoft site.  There I found 2 possible explainations for my problem.  The first was an outdated video card which did not apply to me. The second was add-ons.  It turned out that Shockwave (Adobe Flash Player 11 Axtive X) was the culprit.  I disabled it and my internet works perfectly.  I mentioned before that the internet worked well after I installed it (shockwave).  But now that I think about it, although the browser was open, I didn't actually use it before updating Reader.
            Thanks for your assistance.
            • 3. Re: Adobe Reader X (10.1.4) issue
              pwillener Level 8
              You can use the Flash Player uninstaller to remove it: http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
              If you want to reinstall an earlier version, you can get it from the Flash Player Archive: http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
              • 4. Re: Adobe Reader X (10.1.4) issue
                pwillener Level 8
                P.S. outdated video/graphics/display drivers can also cause problems with Flash Player; see this FAQ how to check for newer drivers: http://forums.adobe.com/thread/945765
                • 5. Re: Adobe Reader X (10.1.4) issue
                  I just got around to trying out your suggestions yesterday.  I ran into a few problems.
                  1. I ran the Flash Player uninstaller using the link above.  It seemed to run OK.  But...
                       a. Flash Player is still installed
                       b. There are some websites that appear to open (the tab at the top shows the name) but the screen is totally blank and there is no error message.
                  2. When I looked into installing a previous version (using the Flash Player Archive link above) , a flag came up stating that this is not the most recent version of flash player. I had 2 options: 1. follow link to download most recent download.  2. click the quit button
                  Any suggestions?
                  • 6. Re: Adobe Reader X (10.1.4) issue
                    pwillener Level 8
                    That is strange; did you close all browser windows before running the uninstaller?
                    Can you go to C:\Windows\system32\Macromed\Flash (using Windows Explorer) and tell me what files are in there?
                    • 7. Re: Adobe Reader X (10.1.4) issue
                      Yes I did close all browser windows.  As a matter or fact, a screen popped up indicating 2 programs that use Flash player were running. And that the uninstall would not begin until I exited out of them both.  I had to restart my computer before I could run the uninstall because although I exited Internet Explorer, the program still indicated that it was open.
                      And here is what I found at the above address:
                      activex.vch                                             VCH File
                      Flash32_11_5_502_135.ocx             ActiveX Control
                      FlashInstall                                             Text Document
                      FlashPlayerUpdateService               Application
                      FlashUtil32_11-5_502_AtiveX         Application
                      mms.cfg                                                CFG File
                      The date modified is 12/21/2012 3:37 AM. That's when I did the initial update.
                      • 8. Re: Adobe Reader X (10.1.4) issue
                        pwillener Level 8
                        Yes, that shows it's not uninstalled.  Can you copy & paste the contents of the FlashInstall.log file from that folder here into the forum?  The last 50 or so lines should be enough.
                        • 9. Re: Adobe Reader X (10.1.4) issue
                          pwillener Level 8
                          I am moving this topic to the Flash Player forum.
                          • 10. Re: Adobe Reader X (10.1.4) issue
                            Here's the contents of the flash install text document. I hope it fits:
                            =O====== M/11.1.102.55 2011-12-04+04-59-38.310 ========
                            0000 [I] 00000010 "C:\Users\Owner\AppData\Local\Temp\install_flash_player_ax_32bit.exe" -dlm -install
                            0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                            0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                            0004 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                            0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                            0006 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash11e.ocx
                            0007 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.exe
                            0008 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.dll
                            0009 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                            =X====== M/11.1.102.55 2011-12-04+04-59-41.512 ========
                            =O====== M/11.5.502.135 2012-12-21+08-37-18.080 ========
                            0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe" -refreshIEElevationPolicies
                            =X====== M/11.5.502.135 2012-12-21+08-37-18.214 ========
                            =O====== M/11.5.502.135 2012-12-21+08-35-15.637 ========
                            0000 [I] 00000010 "C:\Users\Laura\AppData\Local\Temp\C14C.dir\InstallFlashPlayer.exe" -iv 4
                            0001 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                            0002 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash11e.ocx 5
                            0003 [I] 00000018
                            0004 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash11e.ocx 5
                            0005 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.dll 5
                            0006 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.exe 5
                            0007 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_135.ocx
                            0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
                            0009 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
                            0010 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                            0011 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                            0012 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                            0013 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                            0014 [I] 00000012
                            =X====== M/11.5.502.135 2012-12-21+08-48-56.573 ========
                            =O====== M/11.5.502.135 2012-12-28+02-26-30.294 ========
                            0000 [I] 00000010 "C:\Users\Laura\Desktop\uninstall_flash_player.exe" -force   -force
                            0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0005 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0006 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0009 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0011 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0018 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0026 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0027 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0028 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0029 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0030 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0032 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0035 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0036 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0038 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0039 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0040 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0041 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0042 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0043 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0044 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0045 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0046 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0047 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0048 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0049 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0050 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0051 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0052 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0053 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0054 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            =X====== M/11.5.502.135 2012-12-28+02-27-34.331 ========
                            =O====== M/11.5.502.135 2012-12-28+02-27-59.284 ========
                            0055 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0056 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0057 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0058 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0059 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0060 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0062 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0063 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0064 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0065 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0066 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0067 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0068 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0069 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0070 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0071 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0072 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0073 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0074 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0075 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0076 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0077 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0078 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0079 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0080 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0081 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0082 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0083 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0084 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0085 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0086 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0087 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0088 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0089 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0090 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0091 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0092 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0093 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0094 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0095 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0096 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0097 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0098 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0099 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0100 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0101 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0102 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0103 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0104 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0105 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0106 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0107 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0108 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0109 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0110 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0111 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0112 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0113 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0114 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0115 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0116 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0117 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0118 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0119 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0120 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0121 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0122 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0123 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0124 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0125 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0126 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0127 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0128 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0129 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0130 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0131 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0132 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0133 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0134 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0135 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0136 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0137 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0138 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0139 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0140 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0141 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0142 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0143 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0144 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0145 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0146 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0147 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0148 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0149 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0150 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0151 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0152 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0153 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0154 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0155 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0156 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0157 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0158 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0159 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0160 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0161 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0162 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0163 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0164 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0165 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0166 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0167 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0168 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0169 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0170 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0171 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0172 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0173 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0174 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0175 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0176 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0177 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0178 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0179 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0180 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0181 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0182 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0183 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0184 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0185 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0186 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0187 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0188 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0189 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0190 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0191 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0192 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0193 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0194 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0195 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0196 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0197 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0198 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0199 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0200 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0201 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0202 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0203 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0204 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0205 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0206 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0207 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0208 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0209 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0210 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0211 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0212 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0213 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0214 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0215 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0216 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0217 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0218 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0219 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0220 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0221 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0222 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0223 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0224 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0225 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0226 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0227 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0228 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0229 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0230 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0231 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0232 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0233 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0234 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0235 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0236 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0237 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0238 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0239 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0240 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0241 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0242 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0243 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0244 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0245 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0246 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0247 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0248 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0249 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0250 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0251 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0252 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0253 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0254 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0255 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0256 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0257 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0258 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0259 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0260 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0261 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0262 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0263 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0264 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0265 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0266 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0267 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0268 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0269 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0270 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0271 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0272 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0273 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0274 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0275 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0276 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0277 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0278 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0279 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0280 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0281 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0282 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0283 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0284 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0285 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0286 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0287 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0288 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0289 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0290 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0291 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0292 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0293 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0294 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0295 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0296 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0297 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0298 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0299 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0300 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0301 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0302 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0303 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0304 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0305 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0306 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0307 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0308 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0309 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0310 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0311 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0312 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0313 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0314 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0315 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0316 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0317 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0318 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0319 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0320 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0321 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0322 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0323 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0324 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0325 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0326 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0327 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0328 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0329 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0330 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0331 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0332 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0333 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0334 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0335 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0336 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0337 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0338 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0339 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0340 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0341 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0342 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0343 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0344 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0345 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0346 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0347 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0348 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0349 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0350 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0351 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0352 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0353 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0354 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0355 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0356 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0357 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0358 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0359 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0360 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0361 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0362 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0363 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0364 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0365 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0366 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0367 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0368 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0369 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0370 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0371 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0372 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0373 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0374 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0375 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0376 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0377 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0378 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0379 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0380 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0381 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0382 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0383 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0384 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0385 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0386 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0387 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0388 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0389 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0390 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0391 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0392 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0393 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0394 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0395 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0396 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0397 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0398 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0399 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0400 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0401 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0402 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0403 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0404 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0405 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0406 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0407 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0408 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0409 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0410 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0411 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0412 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0413 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0414 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0415 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0416 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0417 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0418 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0419 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0420 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0421 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0422 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0423 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0424 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0425 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0426 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0427 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0428 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0429 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0430 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0431 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0432 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0433 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0434 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0435 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0436 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0437 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0438 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0439 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0440 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0441 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0442 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0443 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0444 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0445 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0446 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0447 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0448 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0449 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0450 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0451 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0452 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0453 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0454 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0455 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0456 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0457 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0458 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0459 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0460 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0461 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0462 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0463 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0464 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0465 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0466 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0467 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0468 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0469 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0470 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0471 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0472 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0473 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0474 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0475 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0476 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0477 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0478 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0479 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0480 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0481 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0482 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0483 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0484 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0485 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0486 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0487 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0488 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0489 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0490 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0491 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0492 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0493 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0494 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0495 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0496 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0497 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0498 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0499 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0500 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0501 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0502 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0503 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0504 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0505 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0506 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0507 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0508 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0509 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0510 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0511 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0512 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0513 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0514 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0515 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0516 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0517 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0518 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0519 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0520 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0521 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0522 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0523 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0524 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0525 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0526 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0527 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0528 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0529 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0530 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0531 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0532 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0533 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0534 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0535 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0536 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0537 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0538 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0539 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0540 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0541 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0542 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0543 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0544 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0545 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0546 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0547 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0548 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0549 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0550 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0551 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0552 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0553 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0554 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0555 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0556 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0557 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0558 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0559 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0560 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0561 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0562 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0563 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0564 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0565 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0566 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0567 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0568 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0569 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0570 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0571 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0572 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0573 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0574 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0575 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0576 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0577 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0578 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0579 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0580 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0581 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0582 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0583 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0584 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0585 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0586 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0587 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0588 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0589 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0590 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0591 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0592 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0593 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0594 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0595 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0596 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0597 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0598 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0599 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0600 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0601 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0602 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0603 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0604 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0605 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0606 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0607 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0608 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0609 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0610 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0611 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0612 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0613 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0614 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0615 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0616 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0617 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0618 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0619 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0620 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0621 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0622 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0623 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0624 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0625 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0626 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0627 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0628 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0629 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0630 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0631 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0632 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0633 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0634 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0635 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0636 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0637 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0638 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0639 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0640 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0641 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0642 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0643 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0644 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0645 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0646 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0647 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0648 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0649 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0650 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0651 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0652 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0653 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0654 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0655 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0656 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0657 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0658 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0659 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0660 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0661 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0662 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0663 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0664 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0665 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0666 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0667 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0668 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0669 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0670 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0671 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0672 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0673 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0674 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0675 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0676 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0677 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0678 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0679 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0680 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0681 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0682 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0683 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0684 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0685 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0686 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0687 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0688 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0689 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0690 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0691 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0692 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0693 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0694 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0695 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0696 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0697 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0698 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0699 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0700 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0701 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0702 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0703 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0704 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0705 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0706 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0707 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0708 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0709 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0710 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0711 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0712 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0713 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0714 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0715 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0716 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0717 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0718 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0719 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0720 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0721 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0722 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0723 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0724 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0725 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0726 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0727 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0728 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0729 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0730 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0731 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0732 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0733 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0734 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0735 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0736 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0737 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0738 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0739 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0740 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0741 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0742 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0743 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0744 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0745 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0746 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0747 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0748 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0749 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0750 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0751 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0752 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0753 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0754 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0755 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0756 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0757 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0758 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0759 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0760 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0761 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0762 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0763 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0764 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0765 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0766 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0767 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0768 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0769 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0770 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0771 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0772 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0773 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0774 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0775 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0776 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0777 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0778 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0779 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0780 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0781 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0782 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0783 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0784 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0785 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0786 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0787 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0788 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0789 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0790 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0791 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0792 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0793 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0794 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0795 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0796 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0797 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0798 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0799 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0800 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0801 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0802 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0803 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0804 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0805 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0806 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0807 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0808 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0809 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0810 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0811 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0812 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0813 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0814 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0815 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0816 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0817 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0818 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0819 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0820 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0821 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0822 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0823 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0824 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0825 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0826 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0827 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0828 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0829 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0830 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0831 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0832 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0833 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0834 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0835 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0836 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0837 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0838 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0839 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0840 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0841 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0842 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0843 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0844 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0845 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0846 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0847 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0848 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0849 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0850 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0851 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0852 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0853 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0854 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0855 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0856 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0857 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0858 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0859 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0860 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0861 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0862 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0863 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0864 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0865 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0866 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0867 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0868 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0869 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0870 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0871 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0872 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0873 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0874 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0875 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0876 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0877 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0878 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0879 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0880 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0881 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0882 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0883 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0884 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0885 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0886 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0887 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0888 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0889 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0890 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0891 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0892 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0893 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0894 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0895 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0896 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0897 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0898 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0899 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0900 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0901 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0902 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0903 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0904 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0905 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0906 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0907 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0908 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0909 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0910 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0911 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0912 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0913 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0914 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0915 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0916 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0917 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0918 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0919 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0920 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0921 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0922 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0923 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0924 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0925 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0926 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0927 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0928 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0929 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0930 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0931 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0932 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0933 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0934 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0935 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0936 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0937 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0938 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0939 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0940 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0941 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0942 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0943 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0944 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0945 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0946 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0947 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0948 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0949 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0950 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0951 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0952 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0953 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0954 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0955 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0956 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0957 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0958 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0959 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0960 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0961 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0962 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0963 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0964 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0965 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0966 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0967 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0968 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0969 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0970 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0971 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0972 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0973 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0974 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0975 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0976 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0977 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0978 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0979 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0980 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0981 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0982 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0983 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0984 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0985 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0986 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0987 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0988 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0989 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0990 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0991 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0992 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0993 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0994 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0995 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0996 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0997 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0998 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            0999 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1000 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1005 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1006 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1009 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1011 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1018 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1026 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1027 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1028 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1029 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1030 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1032 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1035 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1036 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1038 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1039 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1040 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1041 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1042 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1043 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1044 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1045 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1046 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1047 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1048 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1049 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1050 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1051 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1052 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1053 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1054 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1055 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1056 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1057 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1058 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1059 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1060 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1062 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1063 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1064 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1065 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1066 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1067 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1068 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1069 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1070 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1071 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1072 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1073 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1074 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1075 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1076 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1077 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1078 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1079 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1080 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1081 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1082 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1083 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1084 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1085 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1086 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1087 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1088 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1089 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1090 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1091 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1092 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1093 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1094 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1095 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1096 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1097 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1098 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1099 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1100 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1101 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1102 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1103 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1104 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1105 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1106 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1107 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1108 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1109 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1110 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1111 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1112 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1113 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1114 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1115 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1116 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1117 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1118 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1119 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1120 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1121 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1122 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1123 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1124 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1125 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1126 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1127 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1128 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1129 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1130 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1131 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1132 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1133 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1134 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1135 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1136 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1137 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1138 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1139 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1140 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1141 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1142 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1143 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1144 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1145 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1146 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1147 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1148 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1149 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1150 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1151 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1152 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1153 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1154 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1155 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1156 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1157 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1158 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1159 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1160 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1161 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1162 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1163 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1164 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1165 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1166 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1167 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1168 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1169 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1170 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1171 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1172 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1173 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1174 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1175 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1176 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1177 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1178 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1179 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            1180 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                            =X====== M/11.5.502.135 2012-12-28+02-46-47.872 ========
                            =O====== M/10.3.183.48 2012-12-29+13-31-21.399 ========
                            0000 [I] 00000010 "C:\Users\Laura\Downloads\install_flash_player_10_active_x.exe"
                            0001 [E] 00001013
                            =X====== M/10.3.183.48 2012-12-29+13-32-06.187 ========
                            • 11. Re: Adobe Reader X (10.1.4) issue
                              pwillener Level 8
                              Thank you for the install log; can you try a clean install, as described in http://forums.adobe.com/thread/928315
                              • 12. Re: Adobe Reader X (10.1.4) issue
                                mafrustrated Level 1
                                I did a clean install following the instructions you directed me to.  I installed 10.3 using the link at the bottom of the clean install instructions.  I can access the websites that I was previously unable to access.  However, I receive the following error messages on various websites:
                                Your System Status We're sorry You need to update your Flash Player
                                TypeError: Object doesn't support perperty or method 'playJSON'
                                You need to have the Adobe Flash Player to view this content.
                                Content on this page requires a newer version of Adobe Flash Player.
                                What do you suggest? Is there a way to update the 10.3 version?  Or perhaps the clean install will work with the newest version.
                                • 13. Re: Adobe Reader X (10.1.4) issue
                                  pwillener Level 8
                                  Yes, the clean install will absolutely work with the newest version.
                                  • 14. Re: Adobe Reader X (10.1.4) issue
                                    Success at last!!!
                                    I did a clean install of the latest version (11.5.502.135).  I was able to immediately access all desired websites but once there I still ran into the following error messages on various websites:
                                    TypeError: Object doesn't support property or method 'playJSON'
                                    So, I  went to installation problems/ Flash Player/ windows and followed the link to 'Check the Status of Flash Player version' and got a blank box.
                                    I then followed the link to step 4.  Since the install process seemed to have completed, I went to the next step 'see if Flash Player plug-in is enabled.  My Flash Player was disabled.  So, I enabled Shockwave Flash Object.  Now everything works! I revisited the websites there I got the above error messages and now the video content plays ... error free.
                                    Just out of curiosity, I went back to  'Check the Status of Flash Player version' and now I can see 'the movie'.
                                    Thanks so much!
