5 Replies Latest reply on Dec 26, 2012 8:37 AM by Carl Von Stetten
    How to Generate Unique Cache Keys?
    Carl Von Stetten Adobe Community Professional & MVP
      I'm trying to improve the performance of my ColdFusion 10 application by making better use of caching.  I have a particular DAO/Gateway CFC that queries a particular database.  I added query caching to the query in this CFC and it made a huge difference.
      Since this database is outside my control for edits/updates, I need to be able to initiate flushing of the cached queries for this database only.  I don't believe the built-in ColdFusion ehcache query cache allows for granular control of flushing - in CF Administrator you pretty much can only flush the entire cache.
      So I figured the only solution was to create my own cache region that would be associated with just this database, and manually cache the queries into that region.  Then I can flush just that region without impacting any other cached queries.
      So here's my difficulty:  I believe that Internally, ColdFusion caches queries using a hash of the generated SQL.  I'm thinking I'll store my queries in cache with a key that hashes the input parameters.  Would the built-in Hash() function be the appropriate mechanism to create cache keys that are unique for each parameter combination?  Does it matter what algorithm I use with Hash()?
      -Carl V.
        • 1. Re: How to Generate Unique Cache Keys?
          I guess I'll answer my own question.  I've tested using Hash() using the MD5 algorithm, and it appears that it generates repeatable unique values for each combination of parameters.  I did this:
          1. Create a Struct containing key value pairs of the parameters (parameter name, parameter value).
          2. Convert the Struct to a String using SerializeJSON().
          3. Hash the String using Hash() with MD5.
          This seems to be what I was hoping for.  I would still love to get some confirmation that this is a good approach, or if there are better ways to do this.
          -Carl V.
          • 2. Re: How to Generate Unique Cache Keys?
            Adam Cameron. Level 5
            Sorry, didn't see your original question! You might be better asking this on StackOverflow, as there's more people who have more experience with CF keeping an eye on the questions there.
            What I can offer is that MD5 hashes are not guaranteed unique for different input strings. It's unlikely to happen, but it can happen. I think - but am not sure - more "thorough" hashing algorithms might be more likely to have a higher degree of uniqueness.
            That said, the general approach is how these things are generally done.  And it's very very unlikely that you'll ever come to use a combination of elements contributing to the key that will generate a hash that you've already used for something else.
            Adam
            • 3. Re: How to Generate Unique Cache Keys?
              @Adam,
              Thank you for the confirmation.  Maybe I'll switch the algorithm over to SHA, as SHA-256 through SHA-512 seem like overkill.
              This is new territory for me, so it's good to get validation on my thought process.  I might just put a question up on StackOverflow later.
              Thanks again!
              -Carl V.
              • 4. Re: How to Generate Unique Cache Keys?
                BKBK Adobe Community Professional & MVP
                Yes, ColdFusion's hash() is an appropriate mechanism to create such keys. The least troublesome software solutions are those that use built-in resources.
                No, I shouldn't think so. Even the weakest algorithm available to ColdFusion, like any other hash algorithm, makes use of the avalanche effect. A slight change in the input will result in an avalanche of changes in the output.
                • 5. Re: How to Generate Unique Cache Keys?
                  Per @Adam's suggestion, I posted a similar question on StackOverflow.  Someone over there reminded me that ColdFusion 10 now has a "cacheRegion" attribute on the CFQuery tag.  This provides exactly the separation of cached queries that I needed, without having to roll my own unique ID.  If I wanted to still generate my own ID, there is also the "cacheID" attribute on CFQuery that I could use.
                  -Carl V.
