1 Reply Latest reply on Aug 4, 2006 10:40 AM by sharonma
    Creating FDS Project
    blackshirt
      I currently have a dev server with Jrun 4 on it. I want to use Flex Builder to create a FDS project that compiles on the server. I have Jrun instance with default-ear, flex, and SERVER-INF folders. Under my default-war folder I have the WEB-INF/flex folder.
      When I create my FDS project my root folder points to default-war, my root URL points to server:8104/....I use default location and call my project "Test". So now I have a "Test" folder under default-war with my Test.mxml.
      When I run the app in Flex Builder I get
      java.lang.NullPointerException
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:258)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
      at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      So I dont know if I'm even setting up the project right? Do most people point to their Jrun dev instance for development then move the necessary files from dev to staging or QA server?
      thanks
        • 1. Re: Creating FDS Project
          sharonma Level 1
          Hi blackshirt,
          Could you check the project properties in Flex Builder by right click on the “Test” project and select “Properties”? The project properties should look something like that:
          After install Flex with integrated JRun (in default location):
          Flex root folder: C:\fds2 \jrun4\servers\default\flex
          Flex server URL: http://localhost:8700/flex/ (where 8700 is the default port number for the Flex/JRun server)
          FDS project root: C:\ fds2 \jrun4\servers\default\flex\Test
          After install Flex under JRun4 (both in default locations):
          Flex root folder: C:\JRun4\servers\default\flex
          Flex server URL: http://localhost:8100/flex/ (where 8100 is the default port number for the JRun default server)
          FDS project root: C:\JRun4\servers\default\flex\Test
          Sharon
          Flex Builder QA
