1 Reply Latest reply on Dec 21, 2012 2:32 PM by Jim_Simon
    Inconsistent Importing
    wycks Level 1
      I'm using Premiere CS5 and am having problems importing footage.  I had to convert videos that were using the Apple Intermediate Codec to AVI The clips play fine with a video player like Media Player Classic.  I created a project using the DV - NTSC preset.  When I drag the clips I want to use, they only show up as audio files.  But I was able to get one video to work on one project, but the rest just import the audio.  Then I created a new project and got one different videeo clip to work while the rest are all just audio.  Then I went back to the first project that had the one clip working but now it's just acting like an audio file.  So clearly Premiere CS5 can work with these clips, but I can't seem to get all the imported clips working and stay working..
      And when I do have a clip working, when i try importing more I get the Error message 'Unsupported format or damaged file"  I know the format is supported because all the videos have the same properties, and i know they're not damaged because I've gotten some to work.
      Also, when I do get a video working, sometimes it's both a video and audio clip and sometimes it's just video like others are just audio.  And when I double click the clip that only shows up as a video file, I can hear the audio in the source cilp window
      And when i go back to a project that did hav e the video working, the file shows up as offline when it looked and sounded fine before closing the project.
      Any help would be greatly appreciated.
      Media Player Classic gave me this information on the videos:
      Complete name                    : E:\matt amanda wedding\! CONVERTED\CEREMONY CONVERTED\Clip #7.avi
      Format                           : AVI
      Format/Info                      : Audio Video Interleave
      Format_Commercial_IfAny          : DVCPRO 50
      Format profile                   : OpenDML
      File size                        : 18.1 GiB
      Duration                         : 44mn 52s
      Overall bit rate                 : 57.8 Mbps
      Format                           : DV
      Codec ID                         : dv50
      Codec ID/Hint                    : DVCPro5
      Duration                         : 44mn 52s
      Bit rate mode                    : Constant
      Bit rate                         : 48.8 Mbps
      Width                            : 720 pixels
      Height                           : 480 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Standard                         : NTSC
      Color space                      : YUV
      Chroma subsampling               : 4:2:2
      Bit depth                        : 8 bits
      Scan type                        : Progressive
      Bits/(Pixel*Frame)               : 4.715
      Stream size                      : 18.0 GiB (100%)
      Format                           : MPEG Audio
      Format version                   : Version 1
      Format profile                   : Layer 2
      Codec ID                         : 50
      Duration                         : 44mn 52s
      Bit rate                         : 256 Kbps
      Channel(s)                       : 2 channels
      Sampling rate                    : 48.0 KHz
      Stream size                      : 82.2 MiB (0%)
      Alignment                        : Aligned on interleaves
      Interleave, duration             : 24 ms (0.72 video frame)
      Interleave, preload duration     : 24 ms
