• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to use "SESSION_kt_email" in my CFC..?
Contributor ,
Dec 21, 2012 Dec 21, 2012
Can someone show me the correct way to reference a Session variable called "SESSION.kt_email" and filter it out of my User_email list?
- The CFC below is used to grab all of the correct emails, but "exclude" the email of the logged in user
- I'm using the GROUP_CONCAT so the outputted emails are separated by commas
- My CFC works fine until I add in the Session stuff, then I get this error..
Here is the CFC email_actions_updated.cfc:
<!--- Generated by Adobe Dreamweaver CS4 10.0.0.4117 [en] (Win32) - Thu Dec 20 2012 16:57:12 GMT-0600 (Central Standard Time) --->
<cfcomponent>
          <cffunction name="GetEmails" access="remote" returnType="any" output="false">
                    <cfargument name="id" type="numeric" required="true">
  <cfargument name="kt_email" type="any" required="true">
                    <!--- GetEmails body --->
        <!--- Create Filtered Email list --->
<cfquery name="rsEmailAction" datasource="care">
SELECT GROUP_CONCAT(NULLIF(User_email, <cfqueryparam cfsqltype="cf_sql_varchar" value="#ARGUMENTS.kt_email#"> )) AS User_email
  FROM (
SELECT    CONCAT(tblemailaction.uea_User, "@corp.clearwave.com") AS User_email,
tblemailaction.uea_ADSL
FROM      tblemailaction, tbltickets, tbltickettype
WHERE     tbltickets.ttType = tbltickettype.ttDesc
  AND     tbltickettype.ttID = tblemailaction.uea_ADSL
  AND     tblemailaction.uea_Updated = 1
  AND ttNum = <cfqueryparam cfsqltype="cf_sql_integer" value="#ARGUMENTS.id#">
) q
</cfquery>
                    <cfreturn rsEmailAction>
          </cffunction>
</cfcomponent>
Here is my sample calling page:
<cfparam name="URL.id" default="40865">
<!--- Create Filtered Email list and just send Email to flagged Users --->
<cfinvoke
component="CRM.CTS.email_actions_updated"
method="GetEmails"
returnvariable="rsEmailAction"
id="#URL.id#">
<head>
</head>
<body>
<input name="email_list" type="text" id="email_list" value="<cfoutput>#rsEmailAction.User_email#</cfoutput>" size="150" />
</body>
Views
988
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 22, 2012 Dec 22, 2012
<cfinvoke
    method="GetEmails"
    id="#URL.id#">
Your function requires 2 arguments. Yet your cfinvoke has just one. Were you perhaps going for something like this:
<cfinvoke
Votes
Translate
Translate
Community Expert ,
<cfinvoke
    method="GetEmails"
    id="#URL.id#">
<cfinvoke
    method="GetEmails"
    id="#URL.id#"
    kt_email="#session.kt_email#">
Votes
Translate
Translate
Report
Report
Contributor ,
Dec 26, 2012 Dec 26, 2012
I added in the second argument as follows:
<cfinvoke
method="GetEmails"
id="#URL.id#"
And now I'm getting an error on the cfc:
Element SESSION.KT_EMAIL is undefined in ARGUMENTS.
Votes
Translate
Translate
Report
Report
LEGEND ,
Is the cfc code still the same as in the opening post?  In any event, if you comment out all the code in your function and replace it with <cfdump var="#arguments#">, do you see the two arguments and their expected values?
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Dan, that helped to point to the problem and the error on my cfc.. I had indeed changed the cfc since my first post and inserted the word "Session" to my Argument as below..
SELECT GROUP_CONCAT(NULLIF(User_email, <cfqueryparam cfsqltype="cf_sql_varchar" value="#ARGUMENTS.Session.kt_email#"> )) AS User_email
I changed the #ARGUMENTS.Session.kt_email# to just #ARGUMENTS.kt_email# and it now returns the correct results!
Thanks to both you and BKBK
ps: you must live in these forums..?
Votes
Translate
Translate
Report
Report
LEGEND ,
In addition to BKBK's answer, are you sure about the double quotes in the concat function of your query?
Votes
Translate
Translate
Report
Report
Resources
Documentation
