16 Replies Latest reply: Dec 25, 2012 11:49 AM by nikolaig RSS
    How to remove xml loaded jpgs on EXIT_FRAME?
    nikolaig Community Member
      I have a perfectly working code which removes an xml loaded image thumb scroller. It is set up to remove the loaded jpg's on a mouse click with the listener assigned to a navigation object.
      My problem is that on that page I have 75+ navigation objects and would like to avoid to assign the scroller remove function to all of them.
      Is there a way to tweek this code so it works on something like EXIT_FRAME. So it is not assigned to any navigation object, but rather to the fact that user has navigated out of the page with the scroller. My site is segmented into labeled sections, maybe this somehow can be factored in?
      //removing the scroller///////////////////////////////////////////////////////
      //first.setting up the function which will remove the scroller and stop it from consuming resources//
      function removeScrollerF():void{
      if(scroller){
      scroller.removeEventListener(Event.ENTER_FRAME, moveScrollerThumbs);
      removeChild(scroller);
      scroller=null;
      ///second. add listeners for naviagation objects
      testDelete_mc.addEventListener(MouseEvent.CLICK, navF);
      //third.  create the listener functions for navigation objects
      function navF(e:MouseEvent):void{
       // in each listener function call the function that removes the scroller
      removeScrollerF();
      // add the navigation code
      gotoAndPlay("howto");
        • 1. Re: How to remove xml loaded jpgs on EXIT_FRAME?
          kglad CommunityMVP
          in the ide, add a movieclip (with no content or with its visible property assigned to false) to the frame where you add your image scroller and assign it an instance name (eg, dummy_mc).  make sure it exists in no other frame except the one that contains your image scroller code.
          you can then use:
          dummy_mc.addEventListener(Event.REMOVED_FROM_STAGE,removeScrollerF);
          and change your removeScrollerF code from:
          //whatever
          to:
          function removeScrollerF(e:Event=null):void{
          //whatever
          • 2. Re: How to remove xml loaded jpgs on EXIT_FRAME?
            Unfortunately the code came back with an argument error like this:
            ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.
                at flash.display::DisplayObjectContainer/removeChild()
            this error references this line in the code:
            Here is my full set up:
            dummy_mc.visible = false;
            function removeScrollerFF(e:Event=null):void{
            if(scroller){//prevents a problem if you were to use the same navigation code after the scroller is removed
            scroller=null;  // if, when you want to re-create your scroller, it fails to be re-created, remove this line of code.
            dummy_mc.addEventListener(Event.REMOVED_FROM_STAGE,removeScrollerFF);
            • 3. Re: How to remove xml loaded jpgs on EXIT_FRAME?
              kglad CommunityMVP
              the movieclip need to be added to the keyframe that contains your code that adds the scroller.
              • 4. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                It doesn't work.
                I guess again I am missing something basic.
                Here is my set up:
                My flash site is segmented into several labeled sections. Each section is at 10 frames long, so I can read what it is titled and know where I am on the main time frame. Each section is separated by a keyframe, i.e. at each tenth frame I inserted a keyframe, and then another one after next ten frames. AS3 layer mimics the same segmentation. In case with the scroller - it is located on frames 80-90 and section is labeled "AppPopUps". There is a key frame on frame 80 marking the begining of the section labeled "AppPopUps" and a keyframe on the frame 90 marking the beginning of the next section with other page. Keyframes are also inserted at 80 and 90 count on AS3 layer and layer with visual elements.
                So my symbol with little "a" for AS3 on AS3 layer is on frame 80, and layer with visual elements starts at frame 80. All of the layers segmented by the keyframe on frame 90. After frame 90 there is another code and another group of visual elements for the next page.
                For argument sake I seperated the AS3 layer into one singular keyframe and made another layer underneath it with a singular keyframe which contains dummy_mc.
                That makes the code and the movieclip to be on the same keyframe?
                What else can I try?
                • 5. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                  kglad CommunityMVP
                  there's a typo in your code.  your code should match my code (removeScrollerF is not the same as removeScrollerFF)
                  if it does match and if dummy_mc does NOT exist on the frames where you want the scroller removed, the code will work.
                  • 6. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                    I put an extra "F" to differentiate between the two methods. One on click and another one on the removed from stage.
                    I thought as long as I reference the function correctly I could change the code? In any case I changed it to one "F", the "dummy_mc" exists only on the frames with the scroller and not on the frames where I want the scroller to be removed. It still throughs this error:
                    which refers to this line in the code: "removeChild(scroller);"
                    Here is the code in its entirety, did I miss anything? I deleted all the previus set up, this is the only thing I have for removing the scroller:
                    • 7. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                      kglad CommunityMVP
                      there should be only one function removeScrollerF and there should not be any buttons that call it.  that code is unnecessary because of dummy_mc.
                      that was the only point of using dummy_mc:  to avoid coding for your 75+ buttons.
                      if you already added code for some of their listener functions, remove the removeScrollerF calls from those listener functions.
                      if you want to code all your buttons, you don't need dummy_mc and the code to do that was given to you previously.  if you want to code none of your buttons, use dummy_mc and remove the other calls to removeScrollerF.  if you want to code some of your buttons and not code some of your buttons, explain why?
                      • 8. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                        I did not want to code any buttons at all. I put an extra F in the function description just to differentiate between the two methods you were helping me with.
                        There is only one function "removeScrollerF" and there are no buttons that call it. There are no other listener functions for "removeScrollerF". I want to use only "dummy_mc" to remove the scroller from stage. I still get this errror:
                        what does it mean?
                        • 9. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                          kglad CommunityMVP
                          copy and paste your code.
                          click file>publish settings>swf and tick "permit debugging".  retest.
                          copy and paste the full error message and in your pasted code indicate the topmost line number (mentioned in the error message) triggering the error.
                          • 10. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                            I copied and pasted the code into a separate Flash file and did the testing as you suggested. Everything works perfectly and gives me no errors. Scroller is being terminated as it is supposed to when I navigate to another frame (without dummy_mc).
                            However, in the original flash file with many sections and pages, where scroller is a part of the complex layout I still have the errors in Output panel:
                                      at acolyte51_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF()[acolyte51_AppsPopUpsThumb s_fla.mainsite_mc_2::frame82:360]
                                      at flash.display::MovieClip/gotoAndPlay()
                                      at acolyte51_AppsPopUpsThumbs_fla::mainsite_mc_2/gotoFrame2()[acolyte51_AppsPopUpsThumbs_fla .mainsite_mc_2::frame82:348]
                            here is what on line 360:
                            here is what on line 348:
                            gotoAndPlay("contactus");
                            The above error code always comes up in combination with the navigation error on a button I used to navigate out of the page with the scroller. In other words there always be the error on line 360 and then an additinal error with navigation line gotoAndPlay depending on which button I clicked. So line number of 348 may change if I use another button to navigate out of the frames with the scroller. But the navigation related error of gotoAndPlay will come back with another error line number, indicating the code location for the button I just used.
                            • 11. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                              kglad CommunityMVP
                              replace line 360 with:
                              if(scroller){
                              if(scroller.stage){
                              • 12. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                                I still have the same error.
                                Here is how the code set up looks in its entirety:
                                dummy_mc.addEventListener(Event.REMOVED_FROM_STAGE, removeScrollerF);
                                if(scroller){
                                if(scroller.stage){
                                Here is the full error description:
                                frame82:360 refers to the same line of code:
                                • 13. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                                  kglad CommunityMVP
                                  use:
                                  if(scroller){
                                  if(scroller.stage){
                                  scroller.parent.removeChild(scroller);
                                  • 14. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                                    I replaced the code, the error still reads the same:
                                              at acolyte51_AppsPopUpsThumbs_fla::mainsite_mc_2/onClick_HowTo_btn()[acolyte51_AppsPopUpsThu mbs_fla.mainsite_mc_2::frame1:663]
                                    Line 360 refers to this line:
                                    I also tried parent.parent but it did not work as well as parent.parent.parent
                                    • 15. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                                      kglad CommunityMVP
                                      what's displayed in the output panel using:
                                      if(scroller){
                                      trace(scroller);
                                      if(scroller.stage){
                                      trace(scroller.stage);
                                      trace(scroller.parent);
                                      • 16. Re: How to remove xml loaded jpgs on EXIT_FRAME?
                                        [object MovieClip]
                                        [object Stage]
                                        [object mainsite_mc_2]
                                                  at acolyte51_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF()[acolyte51_AppsPopUpsThumb s_fla.mainsite_mc_2::frame82:363]
