2 Replies Latest reply on Dec 22, 2012 8:57 AM by wycks
    AVI to .DV
    wycks Level 1
      I've been trying to convert videos with Apple Intermediate Codec and was able to use a MAC to convert the AIC videos to AVI and .DV.  The problem is that I had to give back the Mac to the person who loaned it to me and now I've found out that the AVI files don't work, but the one .DV video I created does work.  So is there some way to convert an AVI file to a .DV file?  (it looks to me like a .dv video file isn't the same as an .avi file using the DV codec, is that right?)
        • 1. Re: AVI to .DV
          the_wine_snob Level 9
          What is the CODEC used, in those converted AVI files? That will likely determine if they can be converted, and even which program would be used to convert them.
          Which platform are you on, PC? That will determine which conversion program(s) is/are recommended.
          Good luck, and please let us know just a bit more.
          • 2. Re: AVI to .DV
            wycks Level 1
            I'm using a PC.  This is the information I have on the video:
            General
            Complete name                    : E:\matt amanda wedding\! CONVERTED\CEREMONY CONVERTED\Clip #7.avi
            Format                           : AVI
            Format/Info                      : Audio Video Interleave
            Format_Commercial_IfAny          : DVCPRO 50
            Format profile                   : OpenDML
            File size                        : 18.1 GiB
            Duration                         : 44mn 52s
            Overall bit rate                 : 57.8 Mbps
            Video
            Format                           : DV
            Codec ID                         : dv50
            Codec ID/Hint                    : DVCPro5
            Duration                         : 44mn 52s
            Bit rate mode                    : Constant
            Bit rate                         : 48.8 Mbps
            Width                            : 720 pixels
            Height                           : 480 pixels
            Display aspect ratio             : 16:9
            Frame rate mode                  : Constant
            Frame rate                       : 29.970 fps
            Standard                         : NTSC
            Color space                      : YUV
            Chroma subsampling               : 4:2:2
            Bit depth                        : 8 bits
            Scan type                        : Progressive
            Bits/(Pixel*Frame)               : 4.715
            Stream size                      : 18.0 GiB (100%)
            Audio
            Format                           : MPEG Audio
            Format version                   : Version 1
            Format profile                   : Layer 2
            Codec ID                         : 50
            Duration                         : 44mn 52s
            Bit rate                         : 256 Kbps
            Channel(s)                       : 2 channels
            Sampling rate                    : 48.0 KHz
            Stream size                      : 82.2 MiB (0%)
            Alignment                        : Aligned on interleaves
            Interleave, duration             : 24 ms (0.72 video frame)
            Interleave, preload duration     : 24 ms
