1 Reply Latest reply on Jul 12, 2006 9:36 AM by Newsgroup_User
    API problems
    Xposure Interactive
      I have a program with a shortcut next to it. The short cut works from out side the program but on some systems it doesn't work with this code: set OK = baOpenFile( the moviePath & "ToolBoxTalks.lnk" , "maximised" ).
      On most computers this works but on the odd one it doesn't. Its a mystery. It works on a machine without director installed so it is not that the Xtra is missing.
        • 1. Re: API problems
          Level 7
          When you set the result of your operation to the variable OK, that
          usually tells you what is going on. For testing purposes, change it to
          this:
          alert string(ok)
          Now, when that code runs, it will send up an alert box with the error
          code. Consult the BuddyAPI documentation for baOpenFile for a list of
          what the error codes mean.
