0 Replies Latest reply on Dec 23, 2012 5:52 AM by jeet_stevenson
    Premeire CS6 & photoshop "codec not found" bug fix
    jeet_stevenson
      I recently started using  premiere cs6 & found that if i import layerd photoshop file as a sequence save it & close the application. File does not reopen. i searched sevrel forum but did not found any satifactory solution.
      I did dicovered a workaround. check steps below:
      1. Import photoshop file as sequence
      2. open sequence with all the layers-> Copy all the layers
      3. Make a new sequence & choose appropriate preset ie resoluton & codec of project
      4. paste all the layers in new sequence.
      5. MAKE SURE you delete photoshop sequence that was made when importing .psd
      It will work---
      I have made a video if you dont understand the steps
      https://vimeo.com/channels/jeetstevenson/56192205
      premeire cs6 & photoshop codec not found bug fix from kamaljeet on Vimeo.
