6 Replies Latest reply on Feb 11, 2013 4:56 AM by SureshRaji
    Justification in Indesign CS6
    Sudha K Level 1
         I want to do justification in Indesign CS6.  When im trying its throwing the error 'data out of range'.  My code is
      myParagraphs = myDoc.paragraphStyles;
      for(var i=1; i<myParagraphs.length; i++)
                  myParagraphs[i].minimumWordSpacing = 25;
                  myParagraphs[i].desiredWordSpacing = 30;
                  myParagraphs[i].maximumWordSpacing = 50;
                  myParagraphs[i].minimumLetterSpacing = 25;
                  myParagraphs[i].desiredLetterSpacing = 40;
                  myParagraphs[i].maximumLetterSpacing = 75;
                  myParagraphs[i].minimumGlyphScaling = 25;
                  myParagraphs[i].desiredGlyphScaling = 50;
                  myParagraphs[i].maximumGlyphScaling = 100;
      Kindly help me.
        • 1. Re: Justification in Indesign CS6
          Vamitul Level 4
          GlyphScaling cannot be lower than 50.
          myParagraphs[i].minimumGlyphScaling = 25 // imposible indesign hard-coded lower limit is 50 ;
          • 2. Re: Justification in Indesign CS6
            Sudha K Level 1
            Hi thanks for your replay.
            Now It is working fine for glyphs, but not for letterspacing.
            I tried folowing code with the below specified limits, but it is showing error     -   " data out of range"
            Kindly help me on this.
            myParagraphs[i].minimumLetterSpacing = parseInt (myPointSizeField4.editValue);  // 100 to 500
            myParagraphs[i].desiredLetterSpacing = parseInt (myPointSizeField5.editValue);   // 100 to 500
            myParagraphs[i].maximumLetterSpacing = parseInt (myPointSizeField6.editValue);   // 100 to 500
            • 3. Re: Justification in Indesign CS6
              Vamitul Level 4
              oh man.. i had such a nice and detailed replay just before the forums went down.. here we go again
              it is the same problem as before
              here are the minumum/maximum values (in CS5, but i'm guessing they are the same in CS6):
              Min. valueMax. value
              Word Spacing01000
              Letter Spacing-100500
              Glyph Scaling50200
              what kind of object is myPointSizeField4? Form what I see you are using plain widget scripting (don't know how to call it as opposed to ScriptUI objects). Be careful with the Editboxes as they convert the user's input into points!
              for debugging purposes try sprinkling your code with some alerts, in this case, just before trying to change the paragraph styles:
              alert ("myPointSizeField4 value is: "+parseInt (myPointSizeField4.editValue).toString());
              also there is a small problem with your code, as myDoc.paragraphStyles will return only the first level of them (the "myParagraphs" variable will not contain the paragraphs styles that are in groups/subgroups). better for you is:
              var myParagraphs = myDoc.allParagraphStyles; // use var to declare variables. not compulsory in javaScript, but will save you a lot of troube in the long run; the allParagraphStyles property returns a proper array (not a collection), and will include all paragraphs styles regardless of whether tey are inside groups or not.
              • 4. Re: Justification in Indesign CS6
                Sudha K Level 1
                     I tried as you said , still it is showing error as below.
                //myParagraphs = myDoc.paragraphStyles;
                myParagraphs[i].minimumLetterSpacing = parseInt (myPointSizeField4.editValue).toString();    // value = 10
                myParagraphs[i].desiredLetterSpacing = parseInt (myPointSizeField5.editValue).toString();    // value = 20
                myParagraphs[i].maximumLetterSpacing = parseInt (myPointSizeField6.editValue).toString();   // value = 30
                When I used toString I got following error message
                when I dont use toString() i got below error
                dono what to do.
                • 5. Re: Justification in Indesign CS6
                  Sudha K Level 1
                    I got solution for my prob. Using properties, i can do this.
                    Thanks.
                  - Sudha K
                  • 6. Re: Justification in Indesign CS6
                    SureshRaji Level 2
                    The default justification values for a default document is:
                    Word Spacing : 80, 100, 133
                    Letter Spacing : 0, 0, 0
                    Glyph Scaling : 100, 100, 100
                    So, we have to set the maximum letter spacing at first, then desired letter spacing and then minimum letter spacing accordingly. The same is also applied for Glyph Scaling also.
                    Try like this,
                    Hope this may be helpful.
