0 Replies Latest reply on Dec 24, 2012 3:55 AM by Indisader
    Export errors in placed PDF and AI images
    Indisader Level 1
      Hy
      I´m having an issue with InDesign exporting to PDF/HTML a document with images.
      The document is allways  exported without any error message, but sometimes it´s exported with empty (blank) images corresponding to a incrusted PDF and Adobe Ilustrator images. The images do are exported, but empty.
      I´m using a script to export multiple docs at once (50 to 70 docs) and, without doing any changes, sometimes required 2 or 3 attempts to get the proper export with all the images.
      I don´t know exactly when and why this happends, but after son tests I found that:
      - Once a doc fail, all the next fails too, i.e., if the doc 30 fails, then the next 40 docs will be exported with empty images.
      - If during the exporting, when inDesign is running the script, you click in the window (it´s not active, because the scripts has the control), this casue it always fails.
        But this is not the only cause, because, althought you don´t do this, sometimes it fail anyway.
      - Jpeg images are always exported
      I have an script to export all doc properties (based on reflection) and checkin the differences between a correct and a wrong exportation, I get this:
      Export OK
      description - State: Initializing
      Database: 7 nodes; 8 links; 278572 bytes
      Performance:
      0.0 ms setting up;
      0.0 ms expanding nodes;
      0.0 ms visiting nodes;
      0.0 ms invalidating due to changes;
      0.0 ms compacting database;
      0.0 ms total (includes misc).
      length - 252
      __proto__ -
      processResults - No errors yet; still looking.
      length - 31
      __proto__ -
      processInventory - Documento
      length - 11
      Export fail
      description - State: Results complete
      Database: 135 nodes; 223 links; 278572 bytes
      Performance:
      0.1 ms setting up;
      5.1 ms expanding nodes;
      21.6 ms visiting nodes;
      26.9 ms total (includes misc).
      length - 262
      __proto__ -
      processResults - Errors Found (1):
            Gráfico incrustado (R=1)
      length - 56
      __proto__ -
         Pliego 1
            Capa
               Elemento de página
            Capa
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
               Marco gráfico
                  Gráfico incrustado
                     Gráfico incrustado
         Pliego 2
         ..... /* repeted */
      length - 17833
      __proto__ -
      aggregatedResults - Documento3.indd,[Básico],1,TEXTO (1),,,,2,Fuente no disponible (1),,,,3,CourierNew (1),,,,4,Gráfico incrustado,1,Problema: Fuente no disponible
      Reparar: Edite el archivo de origen para aplicar una fuente diferente.,Problema,Fuente no disponible,Reparar,Edite el archivo de origen para aplicar una fuente diferente.
      0 - Documento3.indd
      1 - [Básico]
      2 - 1,TEXTO (1),,,,2,Fuente no disponible (1),,,,3,CourierNew (1),,,,4,Gráfico incrustado,1,Problema: Fuente no disponible
      length - 3
      __proto__ -
      Tech. details:
      - InDesign CS5 V7.0.4
      - Windows 7, tested y 64 and 32 bits
      - The images are incrusted
      - Some images bellow to a master page (header and footers) and others are part of the doc.
      - Some images are incrusted PDFs, other jpeg, jpg, etc...
      In order to export to PDF I use:
      doc.exportFile(ExportFormat.pdfType, ficheroPDF,  false, myPDFExportPreset);
      Any help will be very apreciated
