7 Replies Latest reply on Aug 28, 2006 7:14 AM by Graeme Harker
    Binding Static Variables
    dimival Level 1
      I have some static variables in a class which are obviously values that never change. Then in my mxml i bind these values to some components so they can access those static values, the problem is that it gives me the following warning:
      "Data binding will not be able to detect assignments to..."
      How do i get rid of those warnings? Obviously using the Bindable metadata doesn't work because they are static variables, i only need my components to be able to access those values without those warnings, does anyone know how???
      Diego
        • 1. Re: Binding Static Variables
          inlineblue Level 1
          Binding to static varaibles should not be a problem. You might get a compiler warning, but they're just warnings. How're you doing the binding?
          • 2. Re: Binding Static Variables
            jpwrunyan Level 1
            I had the same issue. In Flex 1.5 there were never any warnings, in 2.0 they throw a warning. The application does work just fine, though. Maybe it's more an issue with Flex Builder and bogus (sort-of) errors.
            • 3. Re: Binding Static Variables
              dimival Level 1
              I am doing the binding like this:
              <ns2:Boton ctrl="{ctrl}" label="Listar" tag="{Controller.LIST}" click="ctrl.actionList(event)"/>
              The Controller class has many static variables, in this example LIST. As you said, it is just a warning but when i deploy my application on a web server, it throws all these warnings in my browser, which looks terrible. I can't show the application to my client because those warnings are showing in the browser. That's why i want to get rid of them. Any ideas?
              • 4. Re: Binding Static Variables
                inlineblue Level 1
                Appearing in your browser? How? They're supposed to be trace messages that go to the debug console. Where in the browser are they appearing?
                • 5. Re: Binding Static Variables
                  inlineblue Level 1
                  quote:
                  Just FYI, they're not bogus warnings. Because static variables cannot be declared [Bindable], Flex will not be able to detect assignments to them, so any changes you make at runtime won't trigger a binding. However, if you're not going to make changes to the variables, then there's no problem because the initial value is always picked up when the app first starts.
                  • 6. Re: Binding Static Variables
                    dimival Level 1
                    quote:
                    Nope, they appear in the browser window when i deploy my application. I can send you a snapshot so you can see it for yourself but i will need your email or something.
                    • 7. Re: Binding Static Variables
                      Graeme Harker Level 1
                      A var that's declared "static" doesn't stay the same necessarily.
                      For example, Cairngorm's whole data "model" in V1.5 is implemented as a set of static variables of a class that's never instantiated and the "view" is bound to those static variables. Needless to say that doesn't work in V2.
                      Out of interest, why can't static variables be declared [Bindable] in V2?
