12 Replies Latest reply on Jan 2, 2013 3:11 AM by geoffrey5239
    Loss of audio sync when importing Samsung Galaxy 2 (GT-I1900) video to Premier Elements 10
    geoffrey5239
      I am loosing audio sync when I import video from a Samsung Galaxy 2 GT-I1900 phone even when using settings chosen by Premier Elements 10.
      The file plays OK in Windows 7 media player.
      I have tried using both direct import from the phone and transferring the file separately without solving the problem.
      The Premier Elements is version 10.0(20110902.Mol11.B123.280463)
      Unlinking the audio and video makes no difference.
      VideoReDo reports the file as :
      File:                                     Name : C:\dcim from samsung\DCIM\Camera\20121121_114639.mp4
                                             Duration : 00:09:45.22
                                             Mux type : MP4
      Video:                                Encoding : H.264
                                        VideoStreamID : x201
                                           Frame rate : 29.91 fps
                                        Encoding size : 1280 x 720
                                         Aspect ratio : 16:9
                                      Header bit rate : 20.000 Mbps
                                           VBV buffer : 380 KBytes
                                              Profile : Baseline/4.0
                                          Progressive :  Progressive
                                               Chroma : 4:2:0
                                         Entropy mode : CABAC
                                             Bit rate : 11.626 Mbps
      Audio Stream: 1 (Primary)                Codec : AAC
                                               Format : ADTS
                                             Channels : 2.0
                                             Language : eng
                                                  PID : x202
                                        PES Stream Id : xC0
                                        Sampling rate : 48000
      Letting VideoReDo simply rewrite the file resulted in loss of all but the first few seconds of audio.
      Elements seems to have imported the file as NTSC-AVCHD-AVCHD LITE 720p 30fps
      The computer is running Windows 7 Professional  64 bit version  Service Pack 1 kernel 6.1.7601.17944 (reported by SIW)
      The computer motherboard is a Gigabyte Z68x-UD3H-B3 with an Intel Core i5-2500 CPU at 3.30GHz. Memory is 4GB.
      I note that others have had similar problems with non video recorder recordings.
      Can you suggest any file conversion of the original that will work – I have tried several with no improvement in the final result.
      And can anyone shed light on what is the basic cause of these problems?
