6 Replies Latest reply on Dec 26, 2012 4:46 PM by si conehead
    Is my clip interlaced or non-interlaced?
    si conehead Level 2
      Is there a way in PP that I can find this info, or is there another product that will give me this info? I am running CS5 on a Windows 7 64 bit PC.
        • 1. Re: Is my clip interlaced or non-interlaced?
          Peru Bob Adobe Community Professional & MVP
          This is a good, free one:
          http://mediainfo.sourceforge.net/en
          Create a shortcut on the desktop and drag your media file into it.
          • 2. Re: Is my clip interlaced or non-interlaced?
            si conehead Level 2
            I ran the program on my clip but I do not see where it tells me it is interlaced or not
            • 3. Re: Is my clip interlaced or non-interlaced?
              post a screendump in tree view.
              • 4. Re: Is my clip interlaced or non-interlaced?
                si conehead Level 2
                General
                Complete name                            : C:\Users\WarChief1\Desktop\Adobe Lens Correction\MAH00486.MP4
                Format                                   : MPEG-4
                Format profile                           : Sony PSP
                Codec ID                                 : MSNV
                File size                                : 7.23 MiB
                Duration                                 : 5s 5ms
                Overall bit rate mode                    : Variable
                Overall bit rate                         : 12.1 Mbps
                Encoded date                             : UTC 2012-12-26 15:40:34
                Tagged date                              : UTC 2012-12-26 15:40:40
                Video
                Format                                   : AVC
                Format/Info                              : Advanced Video Codec
                Format profile                           : Main@L4.0
                Format settings, CABAC                   : Yes
                Format settings, ReFrames                : 2 frames
                Codec ID                                 : avc1
                Codec ID/Info                            : Advanced Video Coding
                Duration                                 : 5s 5ms
                Bit rate mode                            : Variable
                Bit rate                                 : 12.0 Mbps
                Maximum bit rate                         : 16.0 Mbps
                Width                                    : 1 440 pixels
                Height                                   : 1 080 pixels
                Display aspect ratio                     : 16:9
                Frame rate mode                          : Constant
                Frame rate                               : 29.970 fps
                Color space                              : YUV
                Chroma subsampling                       : 4:2:0
                Bit depth                                : 8 bits
                Scan type                                : Progressive
                Bits/(Pixel*Frame)                       : 0.257
                Stream size                              : 7.15 MiB (99%)
                Audio
                Format                                   : AAC
                Format/Info                              : Advanced Audio Codec
                Format profile                           : LC
                Codec ID                                 : 40
                Duration                                 : 4s 992ms
                Bit rate mode                            : Constant
                Bit rate                                 : 128 Kbps
                Channel(s)                               : 2 channels
                Channel positions                        : Front: L R
                Sampling rate                            : 48.0 KHz
                Compression mode                         : Lossy
                Delay relative to video                  : 33ms
                Stream size                              : 76.4 KiB (1%)
                • 5. Re: Is my clip interlaced or non-interlaced?
                  AngeloLorenzo Level 1
                  It's a progressive clip. Progressive, for all intent and purpose, is the opposite of interlaced. It is showing/refreshing the entire frame of video at once.
                  • 6. Re: Is my clip interlaced or non-interlaced?
                    si conehead Level 2
                    Got it.
                    Thanks for everyone's help
                    Steve Cohen
