• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
setting a default "no results found" for google map
Participant ,
Dec 27, 2012 Dec 27, 2012
A client is running the google maps search by proximity module. This works fine, except some selections don't generate a map, resulting in an empty div where the map should be (but isn't because there aren't any results.) So the client wanted to add "no results found" into the empty layer, which is easy enough with javascript. Except that now when there is a map, the js detects that that div is empty (because the map is added by javascript), and adds "no results found" until the map overwrites it.
And then I thought about maybe doing a callback on the google maps code except it doesn't even appear when there's no result.
So my question is, how can I set a textual default for the map layer when this happens?
TOPICS
Web apps
Views
981
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Feb 19, 2013 Feb 19, 2013
LATEST
Hi Kenneth,
if (typeof google === 'object' && typeof google.maps === 'object') { your code }
This will detect if the maps module is rendered or not.
Kind Regards,
Alex.
Votes
Translate
Translate
Report
Report
