• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Renaming Projects
New Here ,
Jul 13, 2006 Jul 13, 2006
I want to rename my project & used the Rename Project feature; however, my primarily layout & others SSLs still have the old project name appearing in the IE Title Bar. How do I change that?
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
You need to change the Window Caption name.
Open up the windows properties dialog (this is accessed by double clicking on the window on the under the windows folder on the project tab) and you will see the Windows Caption field on the left side of the window. Change the name and recompile.
Hope that helps
Craig
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Miwon
If you press Ctrl+Shift+?, you should see the Project Settings dialog. Did you try changing what appears in the field labeled "Project Title"?
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Hi, Craig & Rick.
Thank you so much!! I've been driving myself crazy for 2 days! I should have used the forum earlier.
Laura
Votes
Translate
Translate
Report
Report
New Here ,
Jul 26, 2016 Jul 26, 2016
Hello,
I am having a similar issue with v10 where I have changed all the fields to rename the project that I can find yet when I render the project and put it live, there is one place which is visible and showing the old project name.
Below you will find the results page in the first image and the balance of the images are showing the fields which have been updated.  I cannot locate the missing field that needs to be updated to remove the "OldCo" information.
Any assistance you could provide would be appreciated.
Wade
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Hi there
What you have shown us in that first image (I'll capture and share below) is likely something that is part of the skin.
I'd say you need to open the skin editor. (Project Set-up pod) And check there.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
