1. Re: nVidia Graphics Card - Adobe Premiere CS6
John T Smith Dec 28, 2012 9:01 AM (in response to 420Production)with at least 1Gig of video ram, use the nVidia Hack http://forums.adobe.com/thread/629557 - which is a simple entry in a "supported cards" file
2. Re: nVidia Graphics Card - Adobe Premiere CS6
420Production Dec 28, 2012 10:10 AM (in response to John T Smith)I can't see to do the "command prompt" bit? Can you help explain please?
3. Re: nVidia Graphics Card - Adobe Premiere CS6
John T Smith Dec 28, 2012 10:22 AM (in response to 420Production)Search http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US for all things Microsoft
4. Re: nVidia Graphics Card - Adobe Premiere CS6
420Production Dec 28, 2012 10:49 AM (in response to John T Smith)I've done that command prompt, the small black screen flashes on the top left corner and goes off straight away? I didn't even get time to read it..
5. Re: nVidia Graphics Card - Adobe Premiere CS6
John T Smith Dec 28, 2012 10:54 AM (in response to 420Production)Find the text file with Windows Explorer and either double click to open in Notepad, or right click and open in Notepad
You MAY need to copy the file to a different location to edit, and then copy back when your edit is finished... and when you do that, you will need to give yourself permission, since I have read other messages which indicate that the file is in a protected directory
6. Re: nVidia Graphics Card - Adobe Premiere CS6
JEShort01 Dec 28, 2012 10:59 AM (in response to 420Production)The hack...
Simply find and rename (or delete) the cuda_supported_cards.txt file
If you are successful, you should be able to select the "Mercury Playback Engine GPU Acceleration" option (from menu: Edit / project settings / General).
Regards,
Jim
7. Re: nVidia Graphics Card - Adobe Premiere CS6
420Production Dec 28, 2012 12:05 PM (in response to JEShort01)It worked! Thank you so much!
8. Re: nVidia Graphics Card - Adobe Premiere CS6
420Production Dec 28, 2012 12:06 PM (in response to John T Smith)Thank you!
9. Re: nVidia Graphics Card - Adobe Premiere CS6
420Production Dec 28, 2012 12:12 PM (in response to JEShort01)How do I know if Adobe Premiere is definitely using my Graphics card? And is there a hack for for Afte Effects? Thanks
10. Re: nVidia Graphics Card - Adobe Premiere CS6
John T Smith Dec 28, 2012 12:44 PM (in response to 420Production)>is there a hack for for Afte Effects?
http://forums.adobe.com/community/aftereffects_general_discussion
