1. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
kglad Dec 28, 2012 1:46 PM (in response to Jim Wiley)are you adding the returns in the strings panel or in an xml file?
2. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
Jim Wiley Dec 28, 2012 1:53 PM (in response to kglad)I have tried both.
Thanks for the response
3. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
kglad Dec 28, 2012 1:56 PM (in response to Jim Wiley)make sure your textfield is multiline.
if that doesn't fix the problem, exactly what is the problem?
4. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
Jim Wiley Dec 28, 2012 2:02 PM (in response to kglad)I can't get it to give me a single line feed (\f) or a new line like many text editors that only give a single line from a Enter/Return key press in the Strings Panel. Same for the raw XML file. It is always 2 line feeds.
I am just trying to set line breaks.
Thanks again.
5. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
kglad Dec 28, 2012 2:19 PM (in response to Jim Wiley)1 person found this helpfuli don't see a problem.
do you see a different leading when using a carriage return in the strings panel vs when typing text with a carriage return directly into a dynamic textfield?
6. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
Jim Wiley Dec 28, 2012 3:43 PM (in response to kglad)OK - this is modal. I was linking the text directly using commands only. I was not forcing the link to the text field by Applying the String Panel cell data (XML).
You would think the CS5 would honor the \f etc. in the raw XML text data.
Thanks Kglad
7. Re: StringPanel XML Text w/ Carriage Returns/LineFeeds
kglad Dec 28, 2012 4:15 PM (in response to Jim Wiley)you're welcome.
p.s. please mark helpful/correct responses, if there are any.
