I know this is an old thread, but I came up with a solution to this problem after some digging that I think might work incase anyone else has come across this problem. My method was as follows.
1. Create two click boxes, identical in size and stacked on top of each other in the stage. Set them one after the other in the timeline - I put the first one on bottom in the but it doesn't really matter in the layers because the click boxes do not operate simultaneously. Also create a text caption that contains the hint you want to give your user. Place the text caption under the click box in the time line so it does not overlap with the first text box.
2. On the first click box, set the options to...
On Success: Go to the next slide
Attempts: 3
Last Attempt: Continue
No success, failure, or hint captions
Others: Only Pause project until user clicks.
2. On the second box, set the options to...
Attempts: Infinite
That's it. It will pause on the first click box until the three attempts are spent, then it will play the second click box as it shows the hint.
Thank you so much for this followup.
