2 Replies Latest reply on Aug 9, 2007 7:03 PM by awootton
    Flex and dot net
    Michael_Lahzy
      Could I connect to Flex and use its functionality from visual studion .net like useing c#?
      could i use flex sdk from c3?
      Thx in advance
        • 1. Re: Flex and dot net
          GordonSmith Level 4
          If you mean "Can I write Flex apps in C#" or "Can I write Flex apps in MXML and AS3 using Visual Studio", the answer is no. But if you write a Flex app, it can access an ASP.NET page using HTTP, call a web service written in C# using SOAP, etc. In other words, Flex uses standard internet protocols to access data over a network; if the server happens to implement those protocols using C#, Flex doesn't care. However, it cannot directly call remote C# code the way it can call remote Java code with RemoteObject.
          • 2. Flex and dot net
            awootton Level 1
            We (my team) went over this 50 times. A lot of the docs talk about Flex Data Services, which is a java servlett from Adobe that has a lot of wicked functionality. Like, for instance, they can propagate changes to other flex apps. There's talk about RPC and other proprietary protocols. It's easy to get confused.
            In the end, Flex doesn't care. We decided to write our own server in Java and use JSON for the messaging. It just plain works.
            So, yes, imho write your server in C#, it will work. Fire up a debugger in Visual Studio, and another in Flex and watch it happen.
