1 Reply Latest reply on Nov 29, 2007 7:23 AM by dlusignan
    Data binding, Flex Data Service, and polymorphism
    The Bruder Level 1
      Hi All,
      I am using Flex Data Service with Java server through the remote object mechanism to return a complex object.
      one of the members of complex object is a base class which is populated with different instances of derived classes on the server.
      the derived object is properly identified when using a RemoteObject result handler,
      but - when i attempt to use data binding the property appears as null
      Does someone know why it doesn't work with data binding? are there any known problems with data binding and polymorphism?
