2 Replies Latest reply on Nov 23, 2007 8:17 AM by akewea
    Bundle not find in AS project
    akewea
      Hi everyone !
      I'm trying to localize an ActionScript project, but it fails...
      I've got the error :
      quote:
      Error: Could not find resource bundle application
      at mx.resources::ResourceBundle$/getResourceBundle()[E:\dev\flex\sdk\frameworks\projects\fra mework\src\mx\resources\ResourceBundle.as:122]
      But if I switch Flex 3 M3 SDK to Flex 2 SDK, it works fine...
      I also try to deal with ResourceManager, but no locale and no bundle are found.
      This seems to occur only with AS project. I try to do the same with a Flex project and everything is ok.
      Does anyone already have this problem ?
      Thanks.
      Damien
        • 1. Re: Bundle not find in AS project
          Ivascu Cristian Level 1
          Are you using the runtime localization strateges that have been added into Flex 3 (see http://labs.adobe.com/wiki/index.php/Flex_3:Feature_Introductions:_Runtime_Localization) or the same way it was done in Flex 2?
          Can you provide a simple piece of code that fails, or more detailed reproduction steps and log a bug report on this?
          Cristian
          • 2. Re: Bundle not find in AS project
            akewea Level 1
            Well, I tried many strategies, in fact... ;)
            But the one tha work with Flex 2 SDK is
            quote:
            package {
            import flash.display.Sprite;
            import mx.resources.ResourceBundle;
            public class TestApp extends Sprite {
            [Bindable]
            [ResourceBundle("application")]
            private var i18n:ResourceBundle;
            public function TestApp ()
            trace(i18n.getString("test"));
            With this class as my Application (very simple) and Flex 2 SDK, it works fine; If I choose Flex 3 M3 SDK, I've got the error above...
            With de ResourceManager (and Flex 3 SDK, of course), there no errors. But ResourceManager instance has no bundle and no locale...
            Is this a Flex 3 bug ?
            Thanks for your help.
            Damien
