1. Re: Can not figure out an error message
kglad Dec 29, 2012 10:37 PM (in response to nikolaig)holderMovieClip.holderMovieClip_Bckgrnd doesn't exist when line 206 executes.
use the trace function to debug.
2. Re: Can not figure out an error message
nikolaig Dec 30, 2012 6:20 AM (in response to kglad)It does exist. I manually checked for it on the screen and see that it is there and named properly.
Maybe some code reneders it to null?
What trace function would I use to debug and on what action do I apply it to?
3. Re: Can not figure out an error message
Ned Murphy Dec 30, 2012 6:23 AM (in response to nikolaig)Does the object animate into place in the frames prior to frame 72? If so, be sure to assign the instance name at the beginning.
4. Re: Can not figure out an error message
nikolaig Dec 30, 2012 6:40 AM (in response to Ned Murphy)no, it does not animate into place. It appears only on frame 72, and this is the code for it:
holderMovieClip.holderMovieClip_Bckgrnd.visible = false;
5. Re: Can not figure out an error message
Ned Murphy Dec 30, 2012 6:54 AM (in response to nikolaig)As kglad already said, use the trace function to debug.
Just before line 72 try using...
trace(holderMovieClip, holderMovieClip.holderMovieClip_Bckgrnd)
and see which of the two objects is coming up null. I'd suspect it would be the first (holderMovieClip) since the 1009 error usually erupts for a directly targeted object rather than a parent.child referenced object.
I will leave this to kglad to try to help you with further. I just thought there might be something precluding the object in the timeline since the error occurs at a frame greater than 1. Just as a matter of added info, here are a number of possible causes for a 1009 error...
the null object....
- is declared but not instantiated
- doesn't have an instance name (or the instance name is mispelled)
- does not exist in the frame where that code is trying to talk to it
- is animated into place but is not assigned instance names in every keyframe for it
- is one of two or more consecutive keyframes of the same objects with no name assigned in the preceding frame(s). -
6. Re: Can not figure out an error message
kglad Dec 30, 2012 7:03 AM (in response to nikolaig)the problem is holderMovieClip.holderMovieClip_Bckgrnd.
put a trace(this.name,currentFrame) on the first frame of holderMovieClip.holderMovieClip_Bckgrnd, put a trace(holderMovieClip, currentFrame) on the first keyframe that contains holderMovieClip and put trace(this.name,currentFrame) just above line 206 in the frame that contains the error message.
paste the trace output here.
7. Re: Can not figure out an error message
nikolaig Dec 30, 2012 7:15 AM (in response to Ned Murphy)On frame 72, line 206 I have this code:
On line 205 I put this code:
trace(holderMovieClip, holderMovieClip.holderMovieClip_Bckgrnd);
Here is what I have in the output panel:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/frame72()[acolyte51b_AppsPopUpsThumbs_fla. mainsite_mc_2::frame72:205]
at flash.display::MovieClip/gotoAndPlay()
at icysophistication_tl_fla::MainTimeline/onClickfloraLyte_btn()
if on line 205 I put the code:
trace(holderMovieClip);
then I have an error coming on line 206 (line 205 is clear of errors now):
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/frame72()[acolyte51b_AppsPopUpsThumbs_fla. mainsite_mc_2::frame72:206]
if on line 205 I put this code:
trace(holderMovieClip.holderMovieClip_Bckgrnd);
I have an error again coming on line 205
I guess it means that somehow "holderMovieClip_Bckgrnd", which is inside "holderMovieClip" somehow disappears. I know it is there as I checked on it on the screen. It also works when I acess it from other pages. But somehow it "disappears" when I access it from my trouble page. How do I figure out what causes it?
8. Re: Can not figure out an error message
kglad Dec 30, 2012 7:29 AM (in response to nikolaig)put
put
put
and paste the output here.
9. Re: Can not figure out an error message
nikolaig Dec 30, 2012 8:56 AM (in response to kglad)Section/Page with the holderMovieClip.holderMovieClip_Bckgrnd spans from frames 72-81. Which means all of the code I was instructed to put is located on frame 72.
trace(this.name,currentFrame) - I put on line 203
trace(holderMovieClip, currentFrame) - I put on line 204
trace(this.name,currentFrame) - I put on line 205
I have a set up where I can acsess frame 72 with the troubled holderMovieClip.holderMovieClip_Bckgrnd from two separate sections/pages of the site. Here is what I have on frame 72 when I acsess it from section/pageA
OUTPUT:
instance2 72
OUTPUT:
[object MovieClip] 72
OUTPUT:
instance2 72--------------------------------------
Here is what I have on frame 72 when I acsess it from section/pageB. Section/pageB is on frame 82, which is referenced in the code.
OUTPUT:
instance2 72
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/gotoFrame2()[acolyte51b_AppsPopUpsThumbs_f la.mainsite_mc_2::frame82:351]
OUTPUT:
null 72
OUTPUT:
instance2 72
10. Re: Can not figure out an error message
kglad Dec 30, 2012 9:02 AM (in response to nikolaig)you're not following my suggestions.
let's try one thing at a time:
put
that means go to holderMovieClip_Bckgrnd's timeline. on its first frame put that trace.
11. Re: Can not figure out an error message
nikolaig Dec 30, 2012 9:50 AM (in response to kglad)Ah, did not realise that, I thought all of the code has to be on the main timeline.
O.K. one thing at the time. I went inside holderMovieClip, then inside holderMovieClip_Bckgrnd and on the time of holderMovieClip_Bckgrnd I put this trace:
Here is what I have in the Output panel when I acsess it from page A:
holderMovieClip_Bckgrnd 1
Here is what I have in the Output panel when I acsess it from page B (which starts from frame 82):
12. Re: Can not figure out an error message
kglad Dec 30, 2012 1:09 PM (in response to nikolaig)good. leave that trace statement and add:
trace(holderMovieClip, currentFrame) on the first keyframe that contains holderMovieClip.
it's important the above trace be on the first keyframe that contains holderMovieClip. that keyframe is on the same timeline as the timeline that contains your code. it will only be in frame 206 IF that is the first keyframe that contains holderMovieClip. if holderMovieClip exists in more than 1 keyframe, the trace will probably not be in frame 206.
13. Re: Can not figure out an error message
nikolaig Dec 30, 2012 4:49 PM (in response to kglad)I left the trace statement. I also made sure that my labeled section where holderMovieClip exists is one frame only. So the code and the art and the holderMovieClip are all cosisting of only one key frame (which is #72).
null 72
14. Re: Can not figure out an error message
kglad Dec 30, 2012 11:00 PM (in response to nikolaig)what do you mean by "page B" and are you showing two different trace results based on something related to "page B"?
15. Re: Can not figure out an error message
nikolaig Dec 31, 2012 6:15 AM (in response to kglad)Correct. I am showing two different trace results depending which page I am acsessing the page with holderMovieClip from.
There is page A which gives me good results and then there is page B which gives me bad results. The code which leads to page with holderMovieClip seems to be identical on both pages A and B.
Page B (bad results page) has a big code section which creates an xml loaded thumb scroller. If I apply block comment to this chunk of code then it works and I can have good working results from both pages.
How do I go about and find out what line exactly causes the problem in the code?
16. Re: Can not figure out an error message
kglad Dec 31, 2012 7:10 AM (in response to nikolaig)there should be 2 trace statements in your code. one, on frame 1 of holderMovieClip_Bckgrnd - trace(this.name,currentFrame) and one, on the first keyframe that contains holderMovieClip - trace(this.name,currentFrame).
add a third trace at the top of your pageB code: trace("xml").
retest using pageB. only show the trace results that are followed by the null object error.
17. Re: Can not figure out an error message
nikolaig Jan 2, 2013 5:58 AM (in response to kglad)There are trace statements trace(this.name,currentFrame) on the first frame of holderMovieClip_Bckgrnd and on the first keyframe that contains holderMovieClip(which is the main time line).
I've added a third trace on top of my troubled page B (which is at frame 82 in the code sample below): trace("xml")
Here are my results:
xml
instance2 72
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/gotoFrame2()[acolyte51b_AppsPopUpsThumbs_f la.mainsite_mc_2::frame82:353]
At your previous suggestion you were instructing me to put the code
trace(holderMovieClip, currentFrame) on the first keyframe that contains holderMovieClip, rather than trace(this.name,currentFrame), here are the results if the trace trace(holderMovieClip, currentFrame) is used:
xml
null 72
18. Re: Can not figure out an error message
kglad Jan 2, 2013 7:57 AM (in response to nikolaig)when you use pageB, what you think is holderMovieClip_Bckgrnd is not being displayed. some other movieclip (with instance name = instance2 - a name assigned by flash because you assigned none) probably looks to you like holderMovieClip_Bckgrnd but flash does not think it is the same. that movieclip does not contain holderMovieClip_Bckgrnd.
this problem is on frame 72 of the timeline that contains triggering the error message.
is frame 72 the first keyframe (and therefore the first frame) that contains holderMovieClip on the timeline that's triggering the error message? if not, what is the first keyframe and what other keyframes exist that contains holderMovieClip?
19. Re: Can not figure out an error message
nikolaig Jan 2, 2013 8:26 AM (in response to kglad)Frame 72 is the ONLY frame that contain holderMovieClip on the timeline. I made sure that that this page/section which contains the holderMovieClip consists of only one keyframe.
Just a reminder that I have another pageA which also accesses frame 72 with the same set up and calls on holderMovieClip and everything is working.
Major difference with pageB is that pageB has xml loader code for thumb image scroller. If I comment out that image scroller code then the pageB is working as well
20. Re: Can not figure out an error message
kglad Jan 2, 2013 8:33 AM (in response to nikolaig)comment-out all the code in pageB and retest. do you see the same, a different or no error message?
and, when you do that, does frame 72 play so the code in that frame executes?
21. Re: Can not figure out an error message
nikolaig Jan 2, 2013 8:55 AM (in response to kglad)I commented out all the code on pageB which has to do with building up an xml loading image scroller and it works with no problem I can access the frame 72 and everything works as expected. Here is what I see in theOutput panel when I go from pageB to frame 72:
xml
instance2 72
22. Re: Can not figure out an error message
kglad Jan 2, 2013 9:05 AM (in response to nikolaig)copy and paste you pageB code.
23. Re: Can not figure out an error message
nikolaig Jan 2, 2013 9:11 AM (in response to kglad)Here is the entire pageB code:
stop();
trace("xml")
import com.greensock.*;
import com.greensock.easing.*;
//thumb scroller////////////////////////////////////////////////////////////////////////
//load xml
var xmlLoader:URLLoader = new URLLoader();
/////Parse XML
var xmlData:XML = new XML();
var xmlPath:String = "loadingAssets/appThumbnails/slideshow_image_scroller_ActiveTuts_mine/app_thmbs_imgs60x90 .xml";
xmlLoader.load(new URLRequest(xmlPath));
//trace("loading xml from: " + xmlPath);
xmlLoader.addEventListener(Event.COMPLETE, LoadXML);
function LoadXML(e:Event):void {
//trace("xml load complete");
xmlData = new XML(e.target.data);
//trace(xmlData.image); //we'll see each image xml element listed in the output panel with this xmlList
buildScroller(xmlData.image); //rather than trace the xmlList, we send it to our buildScroller function
/////Build Scroller MovieClip to Contain Each Image
var scroller:MovieClip = new MovieClip();
var padding:Number = 5;//creating a var for padding to be used later on in easier calculations
//making the mask+boundaries
scroller.mask = maskRctngl;
var maskBorders:Number = 93;// distance from stage borders 88 px + padding 5 px
this.addChild(scroller);
//scroller.y = scroller.x = padding;//original version//new (after padding var) positions scroller vertically on stage. Makes y and x = to padding distance
scroller.y = 645;//old (before padding var) positions scroller vertically on stage
scroller.x = maskBorders;
var thumbSmall:Number = 1;//setting up scale Tween on rollover
var thumbLarge:Number = 1.05;//setting up scale Tween on rollover
/////Parse XML
//build scroller from xml
function buildScroller(imageList:XMLList):void{
//trace("build Scroller");
//var scroller_x:int=0;
for (var item:uint = 0; item<imageList.length();item++) {
var thisOne:MovieClip = new MovieClip();
//thisOne.img_width=imageList[item].attribute("width");
//outline
var thumbFadeOut:Number = .3;//setting Border Tweens//doesn't work with TweenMax transitions
var thumbFadeIn:Number = .7;//setting Border Tweens//doesn't work with TweenMax transitions
var blackBox:Sprite = new Sprite();
blackBox.graphics.beginFill(0xFFFFFF);
blackBox.graphics.drawRect(-1, -1, 62, 92);//-1,-1 places rectangle 1px left and up.62, 92 draws rectangle 1px wider on all sides of placed image dimenstions of 60x90
blackBox.alpha = thumbFadeOut;//setting Border Tweens
thisOne.addChild(blackBox);
thisOne.blackBox = blackBox;//setting Border Tweens
//scroller_x += thisOne.img_width + 20;
//var currentX = currentImageWidth+spaceBetween;//modified line to adjust variable thumb widths
//thisOne.x = (84 + padding) *item;//original placement//84 is the width of the loaded images and 15 (which was before paddign var) is the padding
thisOne.x = thisOne.myx = (60 + padding) *item;//replaces the line above for scale tweenw roll over calculation. "myx" is a made up term which defines the position. 61 is the width of the thumb
thisOne.itemNum = item;
thisOne.title = imageList[item].attribute("title");
thisOne.link = imageList[item].attribute("url");
thisOne.src = imageList[item].attribute("src");
thisOne.alpha = 0;//makes all thumb images at alpha=0 before they are fully loaded
//trace(thisOne.itemNum, thisOne.title, thisOne.link, thisOne.src);
//Loading and Adding the Images
//image container
var thisThumb:MovieClip = new MovieClip();
//add image
var ldr:Loader = new Loader();
//var url:String = imageList[item].attribute("src");
var urlReq:URLRequest = new URLRequest(thisOne.src);
//trace("loading thumbnail "+item+" into Scroller: " + thisOne.src);//url
ldr.load(urlReq);
//assign event listeners for Loader
ldr.contentLoaderInfo.addEventListener(Event.COMPLETE,completeHandler_AppPopUps);//tells us when the loading is complete
ldr.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, errorHandler_AppPopUps);//tells us if there are any typo errors when the loading is complete
thisThumb.addChild(ldr);
thisOne.addChild(thisThumb);
//create listeners for this thumb
thisOne.buttonMode = true;//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.CLICK, clickScrollerItem_AppPopUps);//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.MOUSE_OVER, overScrollerItem_AppPopUps);//traces the title when the mouse is over the bounding box in the Output Panel
thisOne.addEventListener(MouseEvent.MOUSE_OUT, outScrollerItem_AppPopUps);//traces the title when the mouse is out the bounding box in the Output Panel
//add item
scroller.addChild(thisOne);
scroller.addEventListener(Event.ENTER_FRAME, moveScrollerThumbs);//adding movement on mouse position
//trace("termination of build scroller");
function clickScrollerItem_AppPopUps(e:MouseEvent):void{
//trace("clicked item " +e.currentTarget.itemNum + " - visit url: " +e.currentTarget.link);//traces the link put in xml file in the Output Panel
//loads BIG SWFs
loader_AppPopUpsLoader.url = MovieClip(e.currentTarget).link;//loads xml assigned SWF into the loader//url corresponds to the url in xml file
loader_AppPopUpsLoader.load(true);//loads xml assigned SWF into the loader
//loader_howToLoader.url = sourceVar;//will work if set up differently, need to make sure that whatever comes after the = is properly set up
//it can be a variable like sourceVar or the link property of a movieclip. as long as the variable/property point to a valid url string, the loader will work.
/////original set up if to open a linked jpg/////
//var urlRequest:URLRequest = new URLRequest(e.currentTarget.link);
//try {
//navigateToURL(urlRequest);
//catch (e:Error) {
// handle error here
//trace(e);
//scale Up on rollOver
function overScrollerItem_AppPopUps(e:MouseEvent):void{
//trace("over"+e.currentTarget.title);//traces the title when the mouse is over the bounding box in the Output Panel
TweenMax.to(e.currentTarget, .5, { scaleX:thumbLarge, scaleY:thumbLarge, x:e.currentTarget.myx - e.currentTarget.width * Math.abs(thumbSmall - thumbLarge)/2, y: -e.currentTarget.width * Math.abs(thumbSmall - thumbLarge)/2 });
TweenMax.to(e.currentTarget.blackBox, .5,{ autoAlpha:.5 } );//setting Border Tweens, originally { alpha:thumbFadeIn }
TweenMax.to(e.currentTarget, .5, {alpha:1, colorMatrixFilter:{contrast:1, brightness: 1, saturation: 1}});
//scale Down on rollOut
function outScrollerItem_AppPopUps(e:MouseEvent):void{
//trace("out"+e.currentTarget.title);//traces the title when the mouse is out the bounding box in the Output Panel
TweenMax.to(e.currentTarget, .5, { scaleX:thumbSmall, scaleY:thumbSmall, x:e.currentTarget.myx, y:0 } );
TweenMax.to(e.currentTarget.blackBox, .5, { autoAlpha:.3} ); //setting Border Tweens, originally { alpha:thumbFadeOut }
TweenMax.to(e.currentTarget, .5, {alpha:.7, colorMatrixFilter:{contrast:1.1, brightness: .7, saturation: .5}});
function completeHandler_AppPopUps(e:Event):void{
//trace("thumbnail complete "+e.target.loader.parent.parent.name)//tells us when the loading is complete
Bitmap(e.currentTarget.loader.content).smoothing=true;//makes loaded jpg's with smoothing rendition
//size image into scroller (need only if I will have images at different sizes)
resizeMe(e.target.loader.parent, 60, 90, true, true, false);
TweenMax.to(e.target.loader.parent.parent, .5, {alpha:.7});//makes all thumb images at alpha=.7 after they are fully loaded
//Tweener.addTween(e.target.loader.parent.parent, { alpha:1, time: .5 } );//caurina version
TweenMax.to(e.target.loader.parent.parent, .5, {colorMatrixFilter:{contrast:1.1, brightness: .7, saturation: .5}});//makes all thumb images at brightness:0.5 after they are fully loaded
//The resizing function (need only if I will have images at different sizes)
// parameters
// required: mc = the movieClip to resize
// required: maxW = either the size of the box to resize to, or just the maximum desired width
// optional: maxH = if desired resize area is not a square, the maximum desired height. default is to match to maxW (so if you want to resize to 200x200, just send 200 once, or resizeMe(image, 200);)
// optional: constrainProportions = boolean to determine if you want to constrain proportions or skew image. default true.
// optional: centerHor = centers the displayObject in the maxW area. default true.
// optional: centerVert = centers the displayObject in the maxH area. default true.
function resizeMe(mc:DisplayObject, maxW:Number, maxH:Number=0, constrainProportions:Boolean=true, centerHor:Boolean=true, centerVert:Boolean=true):void{
maxH = maxH == 0 ? maxW : maxH;
mc.width = maxW;
mc.height = maxH;
if (constrainProportions) {
mc.scaleX < mc.scaleY ? mc.scaleY = mc.scaleX : mc.scaleX = mc.scaleY;
if (centerHor) {
mc.x = (maxW - mc.width) / 2;
if (centerVert){
mc.y = (maxH - mc.height) / 2;
var speed:Number;
function moveScrollerThumbs(e:Event):void {
if ( mouseY > scroller.y && mouseY < scroller.y + scroller.height){//vertically over scroller
if (mouseX < stage.stageWidth/2 -maskBorders*2 && mouseX > 0) {//left half of stage explicitly. -padding*2(multiply by 2) gives a "no movement" padding at the center of the stage
speed = -(mouseX - (stage.stageWidth/2 -maskBorders*2)) /8;//8 is the number which controls the speed (which is divided by this number). Higher number = slower speed. -padding*2(multiply by 2) gives a "no movement" padding at the center of the stage
else if (mouseX > stage.stageWidth/2 +maskBorders*2 && mouseX < stage.stageWidth) {//right half of stage explicitly. +padding*2(multiply by 2) gives a "no movement" padding at the center of the stage
speed = -(mouseX - (stage.stageWidth/2 +maskBorders*2)) /8;//8 is the number which controls the speed (which is divided by this number). Higher number = slower speed. +padding*2(multiply by 2) gives a "no movement" padding at the center of the stage
else{
speed =0;//if in the center area, clear the speed to 0 so we don't have any roll over effect from the last frame
scroller.x += speed;
//scroller limits// set to padding (could be any number specified numerically) to compliment an established spacing
if (scroller.x < -scroller.width + stage.stageWidth -maskBorders){//if scroller too far left
scroller.x = -scroller.width + stage.stageWidth -maskBorders;
else if (scroller.x > maskBorders){ //if scroller to far right
function errorHandler_AppPopUps(e:IOErrorEvent):void{
trace("thumbnail error="+e);//tells us if there are any typo errors when the loading is complete
///arrowLeft/Right_mc///////////////////////////////////////////////////////////////////// /////////////////////
var _arrowLeft:MovieClip;
var _arrowRight:MovieClip;
_arrowLeft = this.getChildByName("arrowLeft_mc") as MovieClip;
_arrowRight = this.getChildByName("arrowRight_mc") as MovieClip;
//_arrowLeft.visible = _arrowRight.visible = false;
_arrowLeft.alpha = _arrowRight.alpha = 0.2;
//_arrowLeft.visible = _arrowRight.visible = true;
_arrowLeft.addEventListener(MouseEvent.ROLL_OVER, _rollOverArrowHandler);
_arrowLeft.addEventListener(MouseEvent.ROLL_OUT, _rollOutArrowHandler);
_arrowRight.addEventListener(MouseEvent.ROLL_OVER, _rollOverArrowHandler);
_arrowRight.addEventListener(MouseEvent.ROLL_OUT, _rollOutArrowHandler);
function _rollOverArrowHandler(event:Event):void {
TweenLite.to(event.currentTarget, 0.5, {alpha:1});
TweenLite.to(event.currentTarget, 0.5, {glowFilter:{color:0xffffff, alpha:1, blurX:15, blurY:15}});
function _rollOutArrowHandler(event:Event):void {
TweenLite.to(event.currentTarget, 0.5, {alpha:.2});
TweenLite.to(event.currentTarget, 0.5, {glowFilter:{remove:true}});
///loader and button/////////////////////////////////////////////////////////////////////////////////// ////////
//import com.greensock.*;
//import com.greensock.easing.*;
import com.greensock.loading.*;
import com.greensock.events.LoaderEvent;
import com.greensock.loading.display.*;
import flash.events.MouseEvent;
//this hides the background in the MC container, allowing it to be present on the working screen but not live
holderMC_AppPopUps.holderMC_applicationsBckgrnd.visible = false;
TweenMax.to(progressBar_AppPopUpsLoader_mc, 0, {blurFilter:{blurX:20, blurY:11}});
//makes sure that none of the barPopUp_mc is showing
progressBar_AppPopUpsLoader_mc.gradientbar_appLoader_mcPopUp_mc.scaleX = 0;
//sourceVar has to be specified before the loader set up
var sourceVar_AppPopUpsLoader:String;
//sourceVar_AppPopUpsLoader = "images/app_images/PnP/BubbleOasis.swf";//do not specify this if loading from multiple buttons from other pages
var loader_AppPopUpsLoader:SWFLoader;
if (loader_AppPopUpsLoader){
if(loader_AppPopUpsLoader.content){
loader_AppPopUpsLoader.unload();
loader_AppPopUpsLoader = new SWFLoader(sourceVar_AppPopUpsLoader,
estimatedBytes:1500000,
container:holderMC_AppPopUps,// more convinient and easier to manage if to place the LoaderMax into an empty mc (holderMovieClip)
// if not will work as well. Then the line container:holderMovieClip, has to be replaced with container:this,
// can be any size, can not be scaled as it distorts the content
onProgress:progressHandler_AppPopUpsLoader,
onComplete:completeHandler_AppPopUpsLoader,
centerRegistration:true,
//x:-260, y:-320, //no need for this is if used: centerRegistration:true,
alpha:1,
scaleMode:"none"
//scaleX:0, scaleY:0,
//vAlign:"top",
//width:825,
//height:575,//scales proportionally but I need to cut off the edges
//crop:true,
//autoPlay:false
function progressHandler_AppPopUpsLoader(event:LoaderEvent):void{
progressBar_AppPopUpsLoader_mc.gradientbar_appLoader_mcPopUp_mc.scaleX = loader_AppPopUpsLoader.progress;
function completeHandler_AppPopUpsLoader(event:LoaderEvent):void{
var loaded_AppPopUpsLoader:ContentDisplay = event.target.content;
//TweenMax.to(loaded_appLoader, 1.5, {alpha:1, scaleX:1, scaleY:1});//only need this line if corresponding values are changed in SWF loader constructor
TweenMax.to(progressBar_AppPopUpsLoader_mc, 1.5, {alpha:0, scaleX:0.25, scaleY:0.25});
holderMC_AppPopUps.visible = true;
//removing the scroller with the clcik//////////////////////////////////////////////////////////////////////////////////// ////////
//first.setting up the function which will remove the scroller and stop it from consuming resources//
/*function removeScrollerFF():void{
if(scroller){//prevents a problem if you were to use the same navigation code after the scroller is removed
scroller.removeEventListener(Event.ENTER_FRAME, moveScrollerThumbs);
removeChild(scroller);
scroller=null; // if, when you want to re-create your scroller, it fails to be re-created, remove this line of code.
///second. add listeners for navigation objects, i.e a button which will remove the scroller
testButton_mc.addEventListener(MouseEvent.CLICK, navF);
//third.create the listener functions for navigation objects
function navF(e:MouseEvent):void{
//in each listener function call the function that removes the scroller
removeScrollerFF();
//trace("you tried to delete the scroller");
//add the navigation code
gotoAndPlay("howto");
testButton_mc.buttonMode = true;
testButton_mc.addEventListener(MouseEvent.CLICK, gotoFrame2);
function gotoFrame2(e:MouseEvent): void{
gotoAndPlay("prdctsPopUps");
//trace("you clicked testDelete_mc");
/*dummy_mc.visible = false;
dummy_mc.addEventListener(Event.REMOVED_FROM_STAGE, removeScrollerF);
function removeScrollerF(e:Event=null):void{
if(scroller){
trace(scroller);
if(scroller.stage){
trace(scroller.stage);
trace(scroller.parent);
scroller.parent.removeChild(scroller);
/*dummy2_mc.visible = false;
function removeScrollerF2(e:Event=null):void{
trace("dummy2_mc works on null");
dummy2_mc.addEventListener(Event.REMOVED_FROM_STAGE,removeScrollerF2);*/
24. Re: Can not figure out an error message
kglad Jan 2, 2013 12:24 PM (in response to nikolaig)1. comment out this line:
buildScroller(xmlData.image); //rather than trace the xmlList, we send it to our buildScroller function and retest.
2. if that prevents the error, uncomment the above and comment out:
and retest.
3. if that prevents the error, uncomment the above and comment out the block shown below:
} else if (mouseX > stage.stageWidth/2 +maskBorders*2 && mouseX < stage.stageWidth) {//right half of stage explicitly. +padding*2(multiply by 2) gives a "no movement" padding at the center of the stage
} else {
} else if (scroller.x > maskBorders){ //if scroller to far right
and retest. let me know the results.
25. Re: Can not figure out an error message
nikolaig Jan 2, 2013 3:38 PM (in response to kglad)1. Doesn't prevent the error. If I comment out the line
/*buildScroller(xmlData.image); //rather than trace the xmlList, we send it to our buildScroller function*/
I do not have a scroller appearing on pageB (which is frame 73) and the same message as before in output panel:
xml
instance2 72
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/gotoFrame2()[acolyte51b_AppsPopUpsThumbs_f la.mainsite_mc_2::frame73:353]
2. With the line specififed previously in the section1 uncommented and this line commented out:
/*scroller.addEventListener(Event.ENTER_FRAME, moveScrollerThumbs);//adding movement on mouse position*/
I have a scroller appearing on pageB (which is frame 73), it doesn't move anymore on the mouseOver, and the same message as before in output panel:
xml
instance2 72
3. Both lines specified in sections 1 and 2 are uncommented.
This block is commented out:
I have the same results as in section 2. I have a scroller appearing on pageB (which is frame 73), it doesn't move anymore on the mouseOver, and the same message as before in output panel:
xml
you rolled over me
you rolled off me
instance2 72
26. Re: Can not figure out an error message
kglad Jan 2, 2013 4:12 PM (in response to nikolaig)just to clarify: commenting out all the code that you posted in message 23 prevents the error, correct?
if yes, comment out:
var xmlPath:String = "loadingAssets/appThumbnails/slideshow_image_scroller_ActiveTuts_mine /app_thmbs_imgs60x90.xml";
and test. does that prevent the error?
27. Re: Can not figure out an error message
nikolaig Jan 2, 2013 4:38 PM (in response to kglad)Correct, commenting out the entire code does prevent the error.
Just retested that with the entire code commented out from pageB. Have positive working results with this message in output panel:
xml
instance2 72
If I comment out section as you advised than the whole site does not work. As I understand due to the fact that a lot variables are being set up in this section which are used later on, but since commented out do not exist. Here is what I have in Compiler Errors :
Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 74 1120: Access of undefined property padding. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 105 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 107 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbLarge. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbLarge. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbSmall. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbLarge. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbSmall. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 136 1120: Access of undefined property thumbLarge. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 145 1120: Access of undefined property thumbSmall. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 145 1120: Access of undefined property thumbSmall. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 195 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 195 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 195 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 196 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 197 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 199 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 200 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 206 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 206 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 209 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 209 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 209 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 210 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 210 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 210 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 212 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 212 1120: Access of undefined property maskBorders. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 213 1120: Access of undefined property scroller. Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 213 1120: Access of undefined property maskBorders. Please let me know if you would like me to go deeper into the code and comment out functions which use all of these vars
28. Re: Can not figure out an error message
nikolaig Jan 2, 2013 8:43 PM (in response to kglad)Through dumb blocking out every single line of code and retesting the movie I finaly found the line which causes the problem:
If I block out this line I obviously have no scroller on the screen, but everything works and the rest of the scroller code remains on the screen.
Is there any fix for that?
xml
instance2 72
29. Re: Can not figure out an error message
kglad Jan 2, 2013 9:13 PM (in response to nikolaig)uncomment the this.addChild(scroller), line and use these two trace statements above and below it:
trace(holderMovieClip.name);
30. Re: Can not figure out an error message
nikolaig Jan 3, 2013 8:26 AM (in response to kglad)When I use this set up I get errors in the pageB (which is frame 73)
On PageB my loader doesn't work as well as the test button which should bring user to section that contain holderMovieClip.
Here is what I get in the output panel
xml
at acolyte51b_AppsPopUpsThumbs_fla::mainsite_mc_2/frame73()[acolyte51b_AppsPopUpsThumbs_fla. mainsite_mc_2::frame73:37]
at appimgCollage5F_1levelIn_fla::MainTimeline/ButterflyGlow_PopUp()
if I only comment out the line
then I get a working loader, working test button as well.
I have the same error messages #1009 if I apply the trace statements only above or only below the line this.addChild(scroller);
31. Re: Can not figure out an error message
kglad Jan 3, 2013 9:07 AM (in response to nikolaig)if holderMovieClip is not already in a layer by itself, create a new layer and move holderMovieClip to that layer. that layer should have a keyframe at 72 where holderMovieClip first exists. there should be no keyframe at frame 73. retest.
32. Re: Can not figure out an error message
nikolaig Jan 3, 2013 9:51 AM (in response to kglad)holderMovieClip is on the layer by itself, no other items are on that layer.
That layer is has a singular keyframe at 72.
However there is a keyframe at frame 73 as this is where pageB begins and spans from frame 73 to 82.
I have my main time line segmented out into labeled sections to which I refer as pages.
How can I not have a key frame at 73 if this is a beginning of a new section?
I have a singular keyframe on 72, then there is no singular keyframe on 73 but a segment from 73 to 82. Is this OK?
Did you want me to have just a blank key frame at 73, i.e. a gap between these sections?
I retested the movie with this set up, which is located at pageB:
Here are the results from the output panel:
As before when I use this set up I get errors in the pageB (which starts at frame 73 and goes to frame 82)
frame73:37 refers to the first (upper)
trace(holderMovieClip.name); -
33. Re: Can not figure out an error message
kglad Jan 3, 2013 10:22 AM (in response to nikolaig)does the layer that contains holderMovieClip in frame 72 also have a non-keyframe at frame 73?
34. Re: Can not figure out an error message
nikolaig Jan 3, 2013 10:31 AM (in response to kglad)No, I removed all the frames (even thogh they were empty) after frame 72 on the layer which contains holderMovieClip. This way frame 73 starts empty (no frames) on the layer which contains holderMovieClip.
35. Re: Can not figure out an error message
kglad Jan 3, 2013 10:46 AM (in response to nikolaig)you need a frame 73 in holderMovieClip's layer otherwise, holderMovieClip doesn't exist on frame 73 (when your pageB code executes).
36. Re: Can not figure out an error message
nikolaig Jan 3, 2013 11:48 AM (in response to kglad)Wow, it works! (but creates a bug)
I now have holderMovieClip on frame 73. It has no other function as just to be present there, so I set its visible=false;
It works if I a user first goes to pageB and then navigates to frame 72 which contains holderMovieClip. This way there is nothing loaded in holderMovieClip and when a user goes to frame 72 there is an SWF Loader hosted in holderMovieClip which loads an swf file onto screen.
However it doesn't work if I first access frame 72 from pageA which loads an SWF file as well using SWF loader which is hosted in holderMovieClip. Then I navigate to pageB from frame 72 - suddenly I already have an SWF file which was previously loaded on frame72 from pageA. It doesn't go away because I now have holderMovieClip present on the screen on pageB.
How do I keep it on the screen, yet at the same time make sure that a previously loaded SWF file dissapears?
37. Re: Can not figure out an error message
kglad Jan 3, 2013 12:16 PM (in response to nikolaig)remove your swf loader from holderMovieClilp in frame 73.
38. Re: Can not figure out an error message
nikolaig Jan 3, 2013 1:55 PM (in response to kglad)There is no SWF Loader in holderMovieClip in frame 73.
SWF loader is being constructed via code on pageA and is being hosted in holderMovieClip.
Here is the code for SWF Loader on pageA:
var sourceVar_ProductsPopUps:String;//has to be specified only once for the rest of all the buttons so individual SWFs may be loaded into LoaderMax or UILoader
var loaderProductPopUps:SWFLoader;
if (loaderProductPopUps){
if(loaderProductPopUps.content){
loaderProductPopUps.unload();
loaderProductPopUps = new SWFLoader(sourceVar_ProductsPopUps, //the value of sourceVar_ProductsPopUps allows to load mulitple SWFs from the products page.
estimatedBytes:5000,
container:holderMovieClip,// more convinient and easier to manage if to place the LoaderMax into an empty mc (holderMovieClip)
onProgress:progressHandler,
onComplete:completeHandler,
alpha:1,
scaleMode:"none",
width:540,
height:730,//scales proportionally but I need to cut off the edges
crop:true,
autoPlay:false
function progressHandler(event:LoaderEvent):void{
progressBarPopUp_mc.gradientbar_appLoader_mcPopUp_mc.scaleX = loaderProductPopUps.progress;
function completeHandler(event:LoaderEvent):void{
var loadedImage:ContentDisplay = event.target.content;
TweenMax.to(progressBarPopUp_mc, 1.5, {alpha:0, scaleX:0.25, scaleY:0.25});
loaderProductPopUps.load(true);
39. Re: Can not figure out an error message
kglad Jan 3, 2013 9:11 PM (in response to nikolaig)when you exit from pageA, execute:
