0 Replies Latest reply on Nov 22, 2007 2:13 PM by JanvanC
    order of behaviours on multiples sprites
      When I add more than one behaviour to a sprite, the behaviours are attached to the sprite in the correct order (the same order as in which I add them.) However, when I make a selection of multiple sprites, and then add the behaviours, director has its own mind about the order, there is no way I can influence this.
      I have a case where the order of the behaviours is important, and they have to be attached to 200 sprites, a lot of work when I have to do it one by one. I could try attaching the behaviours dynamicly, but before I go that way I would like to know if someone ever stumbled into the same problem and knows a solution for it.
