1. Re: Audition 3 and the activation service
SteveG(AudioMasters) Mar 3, 2013 4:12 AM (in response to SteveG(AudioMasters))Thanks to KenWF for providing more information about this from AuditionBugs.
In some instances, where attempts are made to re-establish Audition 3 on the same drive that it was previously on, it won't re-install because the drive deactivation didn't happen, as the activation server doesn't exist any more. If this happens to you, you will have to perform your own deactivation in the registry - details follow: (I suggest printing this out, rather than working from the screen.)
"The activation method used in Audition 3 introduced problems when drives were cloned. Fortunately, Adobe has moved away from this method sincethen, but for these situations with the older releases, here are the stepsfor a full manual removal:
These steps should wipe almost all traces of Audition from the system andallow it to be reinstalled. If you're on a 64-bit Vista or Windows 7system, some of the folder names may be different, for instance""C:\Program Files (x32)\" instead of just "C:\Program Files\".
Delete folders:
C:\Program Files\Adobe\Adobe Audition 3.0\
C:\WINDOWS\Installer\{53C141BA-4F9E-43FB-B4F9-0C01BB716FA8}
Delete these Registry groups:
HKEY_CLASSES_ROOT\Installer\Features\4CF9FE68902F02547B1E7CFFE0BEFDFFHKEY_CLASSES_ROOT\Ins taller\Features\AB141C35E9F4BF344B9FC010BB17F68A
HKEY_CLASSES_ROOT\Installer\Products\AB141C35E9F4BF344B9FC010BB17F68A
HKEY_CURRENT_USER\Software\Adobe\Audition\3.0\
HKEY_LOCAL_MACHINE\Software\Adobe\Audition\3.0\
HKEY_LOCAL_MACHINE\Software\Installer\Features\4CF9FE68902F02547B1E7CF FE0BEFDFF
HKEY_LOCAL_MACHINE\Software\Installer\Features\AB141C35E9F4BF344B9FC01 0BB17F68A
HKEY_LOCAL_MACHINE\Software\Installer\Products\4CF9FE68902F02547B1E7CF FE0BEFDFF
HKEY_LOCAL_MACHINE\Software\Installer\Products\AB141C35E9F4BF344B9FC01 0BB17F68A
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer \UserData\S-1-5-18\Products\4CF9FE68902F02547B1E7CFFE0BEFDFF
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer \UserData\S-1-5-18\Products\AB141C35E9F4BF344B9FC010BB17F68A
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall \{53C141BA-4F9E-43FB-B4F9-0C01BB716FA8}
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall \Adobe Audition 3.0
2. Re: Audition 3 and the activation service
SteveG(AudioMasters) Mar 6, 2014 2:09 AM (in response to SteveG(AudioMasters))It occured to me when looking at the instructions above that no mention has been made of the Documents and Settings Application Data folder, which you also may want to delete (although not necessarily, if you are doing a reinstall). Its location on XP machines is:
C:\Documents and settings\{yourusername}\Application Data\Adobe\Audition
Although on later OS versions, you will have to look in Roaming data to find it.
