7 Replies Latest reply on Jan 7, 2013 10:23 PM by Raja_Raju_Learner
    How to Create a multiefield in CQ with custom type?
    karthi557
      Please can anyone guide me to create a multiefield component with custom xtypes...
        • 1. Re: How to Create a multiefield in CQ with custom type?
          kasq Level 3
          Hi Katrthi,
          You need to create a custom widget (xtype) which will extend standard CQ.form.CompositeField class.
          Regards,
          kasq
          • 3. Re: How to Create a multiefield in CQ with custom type?
            karthi557 Level 1
            Hi Sham,
            Thank you for your reply.we tried this code ..its creating only the component but not showing the dialog....can u plz xplain in detail...
            Karthi Vadla
            • 4. Re: How to Create a multiefield in CQ with custom type?
              karthi557 Level 1
              Hi Kasq,
              I am very new to this topic. can you please explain how to create a custom widget and how it will extend standard CQ.form.CompositeField class.
              Regards
              Karthi
              • 5. Re: How to Create a multiefield in CQ with custom type?
                kasq Level 3
                Hi Karthi,
                Bellow you find some example code for custom multifield
                * @class CQ.wcm.QuestionsBlock
                * @extends CQ.form.CompositeField
                * The filter rule field lets the user select "include" or "exclude" and enter a regexp
                * @constructor
                * Creates a new QuestionsBlock.
                * @param {Object} config The config object
                CQ.wcm.QuestionsBlock = CQ.Ext.extend(CQ.form.CompositeField, {
                     * @private
                     * @type CQ.Ext.form.TextField
                    hiddenField: null,
                     * @private
                    questionsblocktitle: null,
                     * @private
                     * @type CQ.Ext.form.NumberField
                    questionsnumber: null,
                    constructor: function(config) {
                        var formCfg = {"trackLabels":true,"type":"form"};
                        config = config || { };
                        var defaults = {
                                "border": true,
                                "layout":  formCfg,
                                "padding": "7px",
                                "stateful": false,
                                "autoWidth": true,
                                "align": "left"
                        config = CQ.Util.applyDefaults(config, defaults);
                        CQ.wcm.QuestionsBlock.superclass.constructor.call(this, config);
                    // overriding CQ.Ext.Component#initComponent
                    initComponent: function() {
                        CQ.wcm.QuestionsBlock.superclass.initComponent.call(this);
                        this.hiddenField = new CQ.Ext.form.Hidden({
                            "name": this.name,
                            "stateful": false
                        this.add(this.hiddenField);
                        this.questionsblocktitle= new CQ.Ext.form.TextField({
                            "fieldLabel": "Question Block Title",
                            "allowBlank":false,
                            "stateful": false,
                            "mode": 'local',
                            "name": 'questionsblocktitle',
                            "width": '230px',
                            'labelStyle': 'width:120px;'
                        this.add(this.questionsblocktitle);
                        this.questionsnumber= new CQ.Ext.form.NumberField({
                            "fieldLabel": "Question Number",
                            "stateful": false,
                            "allowBlank":false,
                            "mode": 'local',
                            "name": 'questionsnumber',
                            'labelStyle': 'width:120px;',
                            "width": '230px'
                        this.add(this.questionsnumber);
                    // overriding CQ.form.CompositeField#setValue
                    setValue: function(value) {
                        var vArray = value.split(";");
                        this.questionsblocktitle.setValue(vArray[0]);
                        this.questionsnumber.setValue(vArray[1]);
                    // overriding CQ.form.CompositeField#getValue
                    getValue: function() {
                        return this.getRawValue();
                    // overriding CQ.form.CompositeField#getRawValue
                    getRawValue: function() {
                        var questionsblocktitle= this.questionsblocktitle.getValue();
                        var questionsnumber= this.questionsnumber.getValue();
                        var value = questionsblocktitle+ ";" + questionsnumber;
                        this.hiddenField.setValue(value);
                        return value;
                     * Loads the options of the selection if an optionsProvider is available.
                     * This method is usually called solely by {@link CQ.Dialog} after its
                     * content has been loaded.
                     * @param {String} path content path (optional)
                     * @private
                    processPath: function(path) {
                        var dialogPath = this.findParentByType("dialog").path;
                        this.doLayout();
                // register xtype
                CQ.Ext.reg('questionsblock', CQ.wcm.QuestionsBlock);
                Regards,
                kasq
                • 6. Re: How to Create a multiefield in CQ with custom type?
                  karthi557 Level 1
                  Thank you,
                  can u plz send the detailed document about this..becz  i am trying  this code but i am not getting the correct answr...am kindly xpctng the rply...its some wt little bit urgnt
                  • 7. Re: How to Create a multiefield in CQ with custom type?
                    Raja_Raju_Learner
                    Hi Karthi,
                    After creating the custom xtype, in your component dialog add a field("QuestionList") with xtype as multifield.
                    Then create a childnode for "QuestionList" with primaryType = cq:Widget and xtype = "questionsblock".
                    After this include your clientlib category("Questions") in your component.jsp. Here Questions is the category attribute value of the clientLibraryFolder.
                       if (WCMMode.fromRequest(request) != WCMMode.DISABLED) {
                        %><cq:includeClientLib categories="Questions"/><%
                    Note that it will include all your clienbtlib.
                    Hope this helps.
                    Reagrds,
                    Raja R
