0 Replies Latest reply on Jan 2, 2013 6:10 AM by shilpa25
    stop export to PDF after alert message;
    shilpa25 Level 1
      Hi forum,
      my task is:
      If i get alert message while pressing. CMD+E in indesign..... the alert message will display and say "your document has some problem"..
      and there after conforming alert message, the export to print should exit; (if the document doesn't get alert message, then export to pdf should work);
      so.. i assigned exit(); command between the something to find and alert and then export to pdf programme...
      var mydoc = app.activeDocument;
      var myerror=mydoc.stories.everyItem().paragraphs.everyItem().characters.everyItem().getElemen ts();
      for (i=0; i<myerrors.length; i++)
          myerror = myerrors[i];
           if (myerror.fillColor.colorValue.join() == "0,0,0,0"){
                   alert("doc has some problem please fix:");
      exit ();
      var myPresets = app.pdfExportPresets.everyItem().name;
      myPresets.unshift("- Select Preset - ");
      var myWin = new Window('dialog', 'PDF Export Presets');
      thanks..
      shil....
