1 Reply Latest reply on Jan 14, 2013 1:43 PM by Kzer-Za
    Table component uses outdated attributes
    Kzer-Za Level 1
      The text editor's table plugin [The table component] uses outdated markup for centering items vertically in a table cell:
      It renders: <td valign="middle">
      instead of using the modern:
      <td style="vertical-align:middle">
      This breaks the layout. I need to find out how to update the table plugin for the text editor.
      Anyone knows how to fix this?
      Thanks in advance,
      David
        • 1. Re: Table component uses outdated attributes
          Kzer-Za Level 1
          I got a patch from Adobe support:
          You can do this change in [1] around line 672. You can change it to [3].
          Note that isIE is declared in [2] around line 67. You can remove the setAttribute all together if you want to use style attribute for all browsers.
          [1] /libs/cq/ui/widgets/source/widgets/form/rte/commands/Table.js
          [2] /libs/cq/ui/widgets/source/ext/source/ext-core/src/core/Ext.js
          [3]
          if (config.valign) {
                      if (config.valign != noneConfig) {
          com.setAttribute(dom, "valign", config.valign);
                          if (!CQ.Ext.isIE){
          dom.style.verticalAlign = config.valign;
                      } else {
          com.removeAttribute(dom, "valign");
                          if (!CQ.Ext.isIE){
          dom.style.verticalAlign = "";
          Regards,
            Pierre Chamoun
