3 Replies Latest reply on Jan 3, 2013 10:05 AM by the_wine_snob
    PE-11: Help with Key-frame Changes (parm does not change)
      I have been attempting to use keyframes to cause a type of fade at the end of the last clip in the video.  Sadly, it doesn't happen.
      First, I verify that I am working on the proper parameter.  If I move the clip's orange parameter line up and down, I can see the expected change occur in the monitor window.  I have not yet added the key-frame markers.
      I then add a key-frame marker several seconds from the end of the video clip and then another at the end (which is also the end of the video).  Then, I adjust the slope of the orange line (dramatically) for the last several seconds between the two markers just added.
      The action that I would expect to happen at the end (at the slope) does not happen when I scrub.  Even after doing a render, the expected change (at the slope) does not happen.  I have experiment with opacity (fade to black), fade to white, and gamma changes.
      The above was performed on a 64-bit Windows 7 OS on a fast laptop with 17" screen, 8 GB memory, and two high-speed disk drives.
      Can someone please suggest what I am missing?
      Thanks ... Reed
        • 1. Re: PE-11: Help with Key-frame Changes (parm does not change)
          the_wine_snob Level 9
          I personally find that Keyframes are most easily managed in the Effect Control Panel, rather than work with the "rubberbands" for the Effects in the Timeline.
          In the Effects Control Panel, one has control over the Fixed Effects, like Opacity, and any added Effects.
          Does that not work for you? If you Select the Clip/Title, then go to Edit Effects, you should then be in the Effects Control Panel.
          • 2. Re: PE-11: Help with Key-frame Changes (parm does not change)
            ReedWhite Level 1
            Bill, I just discovered the cause of the problem -- apparently a bug.
            I neglected to mention that I had set some time-remapping at the end of the clip as well.  If the time-mapping tool is engaged for a clip, then the key-frames changes do not work.  I removed the time-mapping, and the key-frames changes started working as they should.
            I tested this on both Windows and Mac.  Both versions have the same defect.
            • 3. Re: PE-11: Help with Key-frame Changes (parm does not change)
              Interesting observation.
              One possible workflow, that comes to my mind, would be to do the Time Re-mapping, and the Keyframing separately. Say, apply the Keyframing, as needed, then Export/Share that Clip (can be limited by the WAB, Work Area Bar), then Import that resulting file back into the Project for the Time Re-mapping. One could also do the order of application of Effects in reverse too.
              If one is doing an Export/Share to an intermediate file, for later editing, then this article might be useful: http://forums.adobe.com/message/4556586#4556586
              Good luck, and thank you for sharing your findings - that was a new one to me.
