1 Reply Latest reply on Jan 3, 2013 3:48 AM by Alex B Martin
    How to start, hot to get .prm or .dll or working plugin file from a VS 2008 generated .exp .lib .pdb
    Alex B Martin Level 1
      I download the SDK, load some sample project (e.g. SDK Exporter) in visual studio 2008 from a Windows 7 64bit workstation. No conversion ask. Build > Build Solution creates several files but none with the .dll or .prm extension. Resulting files are SDK_EXporter.XXX with extensions; .obj, .exp, .lib, .pdb, and 2 files named vc90.idb and vc90.pdb
      Im lost, I read several pages of the manual but none explains how to get a valid .prm or .dll file to test on the plugins dir so on premiere
      How can advance ¿??
      results from visual studio
      1>------ Operación Generar iniciada: proyecto: SDK_Exporter, configuración: Debug x64 ------
      1>Compilando...
      1>SDK_Exporter_Params.cpp
      1>SDK_Exporter.cpp
      1>SDK_Segment_Utils.cpp
      1>SDK_File.cpp
      1>Generando código...
      1>Compilando recursos...
      1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
      1>Copyright (C) Microsoft Corporation.  All rights reserved.
      1>Compilando manifiesto en los recursos...
      1>Vinculando...
      1>   Creando biblioteca .\Debug/SDK_File_Compiler.lib y objeto .\Debug/SDK_File_Compiler.exp
      1>Incrustando manifiesto...
      1>Creando archivo de información de examen...
      1>Utilidad de mantenimiento de información de examen de Microsoft Version 9.00.21022
      1>El registro de compilación se guardó en el "file://c:\premiere_pro_cs5.5_r1_sdk_win\premiere_pro_cs5.5_r1_sdk_win\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Debug\BuildLog.htm"
      1>SDK_Exporter - 0 errores, 0 advertencias
      ========== Generar: 1 correctos, 0 incorrectos, 0 actualizados, 0 omitidos ==========
        • 1. Re: How to start, hot to get .prm or .dll or working plugin file from a VS 2008 generated .exp .lib .pdb
          Project properties, change Configuration (on top) to Release and voila
          1>------ Operación Generar iniciada: proyecto: SDK_Exporter, configuración: Release x64 ------
          1>Vinculando...
          1>   Creando biblioteca C:\Program Files\Adobe\Common\Plug-ins\CS5.5\MediaCore\ExporterSDK.lib y objeto C:\Program Files\Adobe\Common\Plug-ins\CS5.5\MediaCore\ExporterSDK.exp
          1>El registro de compilación se guardó en el "file://c:\premiere_pro_cs5.5_r1_sdk_win\premiere_pro_cs5.5_r1_sdk_win\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\BuildLog.htm"
          IF I GO TO C:\Program Files\Adobe\Common\Plug-ins\CS5.5\MediaCore\
          I FOUND THE ExporterSDK.PRM file !!
          Note: remember to set Systen / User variables : ADD name : PREMSDKBUILDPATH   value: C:\Program Files\Adobe\Common\Plug-ins\CS5.5\MediaCore
