3 Replies Latest reply on Jan 4, 2013 12:14 AM by BKBK
    IsQuery
    community help Level 1
        • 1. Re:  IsQuery
          mrs_temple
          IsQuery will return true even if there are zero records in the record count.
          • 2. Re:  IsQuery
            WolfShade Level 4
            Yes, all IsQuery does is check to see if the object is a query, or not (boolean).  Even if there are no records returned, a query is still a query.
            If you want to check to see if a query has more than 0 records in it, use <cfif queryName.recordCount gt 0></cfif>
            ^_^
            • 3. Re:  IsQuery
              BKBK Adobe Community Professional & MVP
              It is not the records which make a query a query. It is the two-dimenstional structure which ColdFusion creates to hold the records. To compare, an empty HTML table is still a a table.
              Use the test:
              if isQuery(myQuery) and myQuery.recordcount gt 0
