• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
About ExtendScript Toolkit support
Explorer ,
Jan 03, 2013 Jan 03, 2013
This question was posted in response to the following article: http://help.adobe.com/en_US/robohelp/robohtml/WS98613C7C-EF5B-48e9-A91A-D2AABB882687.html
Views
868
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
I get "Invalid option usage: x" when running this in RH10 -
"C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML/RHCL.exe" -x"C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML\presets\scripts\Output Generator with Glossary Restyling.jsx" -lWebHelp -oC:\[path] C:\[path].xpj
Votes
Translate
Translate
Report
Report
New Here ,
Also, will running this automatically change the output from the default "expanded text" to "popup text"? That is what I am trying to accomplish. I thought by doing it once locally from Tools > Scripts that it would "set" the SSL and output type but no luck. Thank you, in advance, for any help you can offer.
Votes
Translate
Translate
Report
Report
LEGEND ,
What are you trying to accomplish? You seem to mix up two concepts:
1. Calling the rhc tool for generating via batch.
2. Calling RoboHelp.exe to execute a script.
If you want to generate and call a script, have the script generate the output for you.
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Jan 04, 2013 Jan 04, 2013
Sorry, I see how I might have confused you. I tested the script by running
it inside RH to see what it does. I liked it the output. So the next step
is to test with command line build, which is what we do for production. I
wanted to test the command line locally so that is what I sent in my post.
I don't understand 1) the error message or 2) how to tell it I want
"popup" as the dialog box gives me the choice when I run it locally.
I hope this makes more sense.
Thank you,
Susan
On Fri, Jan 4, 2013 at 12:51 AM, Willam van Weelden <
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 08, 2013 Jan 08, 2013
I understand what you are trying to accomplish. The problem is that the rhcl does not support scripts as far as I know.
The solution is to amend the call to call RoboHelp.exe with the script as a parameter (the help tells you the correct syntax). You then let the script handle creating the output and instead of rhcl.exe.
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for your reply, Willam. The bottom of this page
http://help.adobe.com/en_US/robohelp/robohtml/WS98613C7C-EF5B-48e9-A91A-D2AABB882687.htmlindicates
there is a call: Robohtml.exe
-x
This is the syntax that is not working for. I may have to give and call RH
directly.
Thank you,
Susan Darling
On Tue, Jan 8, 2013 at 1:31 PM, Willam van Weelden <forums_noreply@adobe.com
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 14, 2013 Jan 14, 2013
LATEST
Exactly how do you call RH? Do you use a path for the script and are you in the correct folder of RH?
Try the following: In a batch file, first go to the installation directory and then call Robohtml.exe.
C:
cd "Program Files\RoboHelp\Robohtml"
Robohtml.exe -x myscript.jsx
Greet,
Willam
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
