2 Replies Latest reply on Sep 13, 2013 11:39 PM by ebertx4
    Copy command is crashing
    nss_20041
      I donwloaded a epub formatted book. I viewed it in Adobe Digital Editions version 2.0.67532.
      Highlighted some text and pressed ctrl-c to copy. ADE application crashed.
      I restarted it. Highlighted text. Right click and Select copy. ADE crashed.
      This bug is easily reproducible.
      Please let me know if there is a workaround for this issue.
        • 1. Re: Copy command is crashing
          sjpt Level 4
          This is clearly a bug; it shouldn't crash.
          Does ctrl-C for copying do exactly the same?
          Check the properties of the book.  It may be that copying is not allowed.
          (On ADE 1.7.2 properties can be accessed using ctrl-i; probablythe same ADE2.0 as well).
          In that case, there is no easy (or legal) workaround.
          You could use a screen scraper such as http://sourceforge.net/projects/capture2text/?source=dlp
          While not strictly legal most people would be accept that as reasonable for small a small amount of text.
          ADE1.7.2 gives a clear 'Permissions set by the publisher of this item restrict copying' message
          when attempting to copy from a copy protected book.
          When you look at the info you should see something like
          • Allow viewing: on any device
          • Allow copying: not allowed
          • Allow printing: not allowed
          • 2. Re: Copy command is crashing
            ebertx4
            I had the same issue in Windows 7.  In my case, running Adobe Digital Editions as admin resolved the issue.
