1. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
Chipleh Jan 4, 2013 7:40 AM (in response to nikolaig)You need to reference scroller first, i.e.:
function removeScrollerF2(e:Event=null):void
//I'm guessing your scroller is on the root timeline, else, MovieClip(root) will need to be changed to the instance name of clip where your scroller is located
var scroller:Object = MovieClip(root).getChildByName("yourScroller'sInstanceName");
if(scroller){
hth,
~Chipleh
2. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 4, 2013 7:43 AM (in response to nikolaig)use:
dummy_mc.visible = false;
function removeScrollerF2(e:Event=null):void{
if(scroller){//prevents a problem if you were to use the same navigation code after the scroller is removed
scroller.removeEventListener(Event.ENTER_FRAME, moveScrollerThumbs);
scroller.parent.removeChild(scroller);
scroller=null; // if, when you want to re-create your scroller, it fails to be re-created, remove this line of code.
trace("dummy2_mc works on null");
dummy_mc.addEventListener(Event.REMOVED_FROM_STAGE,removeScrollerF2);
3. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 7:56 AM (in response to kglad)I still have the same error:
ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.
at flash.display::DisplayObjectContainer/removeChild()
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:404]
at flash.display::MovieClip/gotoAndPlay()
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/gotoFrame2()[acolyte51c_AppsPopUpsThumbs_f la.mainsite_mc_2::frame73:372]
Line refers to this:
scroller.parent.removeChild(scroller);I tried adding .parent one at a time and retest but it did not work either. I added up to five instances (scroller.parent.parent.parent.parent.parent.removeChild(scroller);
4. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 8:32 AM (in response to Chipleh)I implemented your code like this:
var scroller:Object = MovieClip(root).getChildByName("thisOne");
I get no more errors, but the scroller is still stays on the screen.
Maybe it helps - here is the code section where I construct the scroller:
//thumb scroller////////////////////////////////////////////////////////////////////////
//load xml
var xmlLoader:URLLoader = new URLLoader();
/////Parse XML
var xmlData:XML = new XML();
var xmlPath:String = "loadingAssets/appThumbnails/slideshow_image_scroller_ActiveTuts_mine/app_thmbs_imgs60x90 .xml";
xmlLoader.load(new URLRequest(xmlPath));
xmlLoader.addEventListener(Event.COMPLETE, LoadXML);
function LoadXML(e:Event):void {
xmlData = new XML(e.target.data);
buildScroller(xmlData.image); //rather than trace the xmlList, we send it to our buildScroller function
/////Build Scroller MovieClip to Contain Each Image
var scroller:MovieClip = new MovieClip();
var padding:Number = 5;//creating a var for padding to be used later on in easier calculations
//making the mask+boundaries
scroller.mask = maskRctngl;
var maskBorders:Number = 93;// distance from stage borders 88 px + padding 5 px
this.addChild(scroller);
scroller.y = 645;
scroller.x = maskBorders;
var thumbSmall:Number = 1;//setting up scale Tween on rollover
var thumbLarge:Number = 1.05;//setting up scale Tween on rollover
/////Parse XML
//build scroller from xml
function buildScroller(imageList:XMLList):void{
for (var item:uint = 0; item<imageList.length();item++) {
var thisOne:MovieClip = new MovieClip();
//outline
var thumbFadeOut:Number = .3;//setting Border Tweens//doesn't work with TweenMax transitions
var thumbFadeIn:Number = .7;//setting Border Tweens//doesn't work with TweenMax transitions
var blackBox:Sprite = new Sprite();
blackBox.graphics.beginFill(0xFFFFFF);
blackBox.graphics.drawRect(-1, -1, 62, 92);
blackBox.alpha = thumbFadeOut;//setting Border Tweens
thisOne.addChild(blackBox);
thisOne.blackBox = blackBox;//setting Border Tweens
thisOne.x = thisOne.myx = (60 + padding) *item;
thisOne.itemNum = item;
thisOne.title = imageList[item].attribute("title");
thisOne.link = imageList[item].attribute("url");
thisOne.src = imageList[item].attribute("src");
thisOne.alpha = 0;//makes all thumb images at alpha=0 before they are fully loaded
//Loading and Adding the Images
//image container
var thisThumb:MovieClip = new MovieClip();
//add image
var ldr:Loader = new Loader();
var urlReq:URLRequest = new URLRequest(thisOne.src);
ldr.load(urlReq);
//assign event listeners for Loader
ldr.contentLoaderInfo.addEventListener(Event.COMPLETE,completeHandler_AppPopUps);//tells us when the loading is complete
ldr.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, errorHandler_AppPopUps);//tells us if there are any typo errors when the loading is complete
thisThumb.addChild(ldr);
thisOne.addChild(thisThumb);
//create listeners for this thumb
thisOne.buttonMode = true;//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.CLICK, clickScrollerItem_AppPopUps);//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.MOUSE_OVER, overScrollerItem_AppPopUps);//traces the title when the mouse is over the bounding box in the Output Panel
thisOne.addEventListener(MouseEvent.MOUSE_OUT, outScrollerItem_AppPopUps);//traces the title when the mouse is out the bounding box in the Output Panel
//add item
scroller.addChild(thisOne);
scroller.addEventListener(Event.ENTER_FRAME, moveScrollerThumbs);//adding movement on mouse position
5. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
Chipleh Jan 4, 2013 8:50 AM (in response to nikolaig)//This will add the scroller to the root timeline
addChild(scroller);
//This will give the scroller an instance name of 'theScroller'
scroller.name = "theScroller"
//This will remove the instance of scroller
var scroller:Object = MovieClip(root).getChildByName('theScroller");
if(scroller)
6. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 10:17 AM (in response to Chipleh)I get errors, Probably I did not apply the code as you intended. Here is the hole line of code:
addChild(scroller);
var scroller:Object = MovieClip(root).getChildByName("theScroller");
here is the errror message I get:Symbol 'mainsite_mc', Layer 'AS3', Frame 73, Line 410 1118: Implicit coercion of a value with static type Object to a possibly unrelated type flash.display:DisplayObject. Line 410 refers to this: removeChild(scroller);
Please let me know if the lines:
addChild(scroller);
are supposed to be in another location in the code"
In the code section which constructs the scrolle (I have posted before) i noticed these lines (perhaps it shows the way the scroller is constructed):
7. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 4, 2013 10:34 AM (in response to nikolaig)then scroller is not added to the stage. use:
if(scroller.stage){
8. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 10:52 AM (in response to kglad)does not work.
My entire code is this:
//scroller.name = "theScroller"
I got rid of the line addChild(scroller);
With the line //scroller.name = "theScroller" I get no errors but the scroller is still on the pages when I navigate out.
If I uncomment the line scroller.name = "theScroller" then I get this error message:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:401]
frame73:401 is this: scroller.name = "theScroller" -
9. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 4, 2013 11:28 AM (in response to nikolaig)you didn't use the code i suggested. again, use:
if(scroller.stage){
10. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 1:47 PM (in response to kglad)Here is the entire code (which is located on the same frames as the xml image thumb scroller):
if(scroller.stage){
I got rid off:
addChild(scroller);
I still get the same error:
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:400]
frame73:400 is this line: scroller.parent.removeChild(scroller); -
11. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 4, 2013 4:47 PM (in response to nikolaig)is all your code attached to the same timeline including your pageB code?
12. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 4, 2013 7:18 PM (in response to kglad)yes, all my code in on the same main timeline in the pageB section.
13. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 4, 2013 11:00 PM (in response to nikolaig)what do you mean by pageB section?
14. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 5, 2013 5:41 AM (in response to kglad)I segmented my time line into labeled sections separated by key frames. Each section is at about 10 frames so I can read what the label says and know where I am on the time line. The labeled section with the xml constructed image thumb scroller is located on frames 73 to 82. I refered to this section as pageB in my previous post about troubled "holderMovieClip" for SWF Loader you have helped me a day before.
All the code for the constructing an xml loaded image thumb scroller and the code we are working on right now is located on the main time line on the pageB section, i.e. on the section from frames 73 to 82. There are now individual key frames between 73-82.
(each section is assigned unique names. For example the labeled section I refer to as "pageB" is actually named "appPopUps". All those label names make sense to me, but I figured "pageB" would be easier to use to resolve this code issue)
15. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 5, 2013 7:46 AM (in response to nikolaig)actually, in this and all future posts in this and other flash threads, it will much less confusing to simply refer to frame numbers or you must make it clear you're using frame labels. using pageB sounds like a movieclip name.
what does the following trace reveal:
if(scroller.stage){
trace(scroller.parent.name, scroller.name);
trace(scroller.parent.getChildByName(scroller.name).name);
16. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 5, 2013 8:09 AM (in response to kglad)when I navigate out of frames 73-82 (where the xml scroller and trace code is located) then on the labeled section I havigate to I have the following:
instance2 instance579
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:423]
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/onClick_ContactUs_btn()[acolyte51c_AppsPop UpsThumbs_fla.mainsite_mc_2::frame1:1044]
line 73:423 refers to:
17. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 5, 2013 8:25 AM (in response to nikolaig)what does the following trace reveal:
if(scroller.stage){
for(var i:int=0;i<scroller.parent.numChildren;i++){
trace(scroller.parent.getChildAt(i).name);
18. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 5, 2013 8:55 AM (in response to kglad)instance2 instance579
instance3
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:425]
frame73:425 refers to:
19. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 5, 2013 9:06 AM (in response to nikolaig)what does the following trace reveal:
if(scroller.stage){
trace(i, scroller.parent.getChildAt(i));
20. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 5, 2013 9:18 AM (in response to kglad)instance2 instance579
0 [object Shape]
1 null
2 null
3 null
4 null
5 null
6 null
7 null
8 null
9 [object MovieClip]
10 [object Shape]
11 [object MovieClip]
12 [object MovieClip]
13 [object MovieClip]
at acolyte51c_AppsPopUpsThumbs_fla::mainsite_mc_2/removeScrollerF2()[acolyte51c_AppsPopUpsTh umbs_fla.mainsite_mc_2::frame73:431]
line 431 refers to :
I have to step out for a few hours, thank you. I will test the site again after I come back.
Best Regards
21. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 5, 2013 9:26 AM (in response to nikolaig)that is quite a mess you have there. i don't think i've ever seen anything like that.
upload your fla to a server and post a link.
22. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 9:36 AM (in response to kglad)Thanks for taking a look at my file. My flash site uses a lot of loaded swf files which are used in navigation as well. So I ended up compiling a folder with all depended files. It came down to be a 615MB file if I include all videos which are used on the site.
This file is called "stage three A.zip". Videos are not used for navigation, so perhaps it will be easier to download a version without them.
Then I made a smaller file without all the videos "stage three B.zip" which is at 118MB.
You can access it in two ways.
1. Go to http://ngrinchenko.com/flashFiles/
Password: flashHelp2013
Please choose iether a complete version or a smaller version without the videos : "stage three B.zip"
2. Using an FTP application
Hostname: ngrinchenko.com
Username: kglad
(if you will be promted for a folder use flashFiles, but it should not be requested)
Thank you for your help. I greatly welcome your critique. However I understand that most probably I have a lot of mistakes there and it will be impossible to address most of them. But I would appreciate if you could point out anything you can to make the site better. Perhaps I have some major messes which would be possible to address?
You will notice that the site is 90% animated with greensock tween engine. I am in the process of removing the last flash based tweens.
Once you download the file please click on "newTest.fla"
Once you download the file please let me know I would like to take it off the server.
Thank you.
23. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 10:17 AM (in response to nikolaig)you can take it off the server.
what needs to be done to trigger the error?
24. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 10:39 AM (in response to kglad)Forgot about it.
When the site opens and you see how the collage of images animates on the screen into place, please click on any of them. It will bring you to the screen whith the clicked image bigger version and an image thumb scroller at the bottom of the screen. If you click on any of the smaller thumb nails then you are still in the same labeled section and no error happens. If you click on any of the main navigation buttons on top or any of the small products pictures (which light up on roll over) on the right of the large image then you navigate out of this labeled section. This is when the error happens, when a user leaves the labeled section with the xml loaded image thumb scroller. The scroller still stays on the screeen and all the errrors happen.
25. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 12:21 PM (in response to nikolaig)on mainsite_mc frame 73:
replace line 38:
with
dummy_mc.addChild(scroller);
and replace the code from 407+ with:
//dummy_mc.visible = false; <- remove the graphics from the stage of dummy_mc
26. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 1:05 PM (in response to kglad)There is no scroller on the bottom of the screen in the labeled section "appPopUps", in the frames 73-82 when I test the site.
Otherwice I get no errors and can navigate out of the page.
Does the scroller appear on your screen?
27. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 1:20 PM (in response to nikolaig)yes. did you comment out the dummy_mc.visible = false line?
28. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 3:29 PM (in response to kglad)Yes, I removed the graphics as well. dummy_mc is now just a dot 1px X 1px on the top right corner.
The only code for removing the scroller is this:
I commented out previous code:
/*dummy_mc.visible = false;
if(scroller.stage){
Should some parts of it be implemented in what you specified?
29. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 6:36 PM (in response to nikolaig)dummy_mc should be at 0,0
30. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 7:13 PM (in response to kglad)Wow, mind melting for me - this is works!!!
So if dummy_mc is not at 0,0 coordinates and has no graphics in it - this set up will not work?
Thanks a lot for your help!!!
P.S. Since you have looked at my file, is it possible to mention what were my major errors?
31. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 7:55 PM (in response to nikolaig)dummy_mc can have graphics but you don't want to see them and if you assign its visible property to false then its children will also be invisible. because i had you add scroller to dummy_mc, you want the children to be visible.
dummy_mc can be at a location other than 0,0. but again, because scroller is a child it will be shifted in position (unless you offset it).
and, i couldn't find the cause of the problem. there are quite a few problems with your setup that makes debugging time-consuming so i looked for a work-around rather than actually fixing the problem.
i didn't think it was possible that this could lead to ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller:
and i still understand how that could happen.
32. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 6, 2013 8:04 PM (in response to kglad)thank you for your time and explanation.
Is it possible to outline what are the problems with my set up so I can avoid them in the future?
33. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 6, 2013 9:00 PM (in response to nikolaig)you're welcome.
in a nutshell, there should be minimal code on timelines or, at most, code in one frame/one timeline.
34. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 7, 2013 7:42 AM (in response to kglad)Meaning that the code should be referenced as an external class?
Or all of the code should be on the first frame of my time line?
Presently all my code on one main timeline but sectioned out for each labeled section. I.e. whatever actions happen in the frames 1-10 I would put the code which makes it happen, whatever actions happen in frames 11-20 I would put code to make it happen. Is it acceptable?
35. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 7, 2013 7:51 AM (in response to nikolaig)using class files would be best.
but if you use timeline code (beyond stop,play and goto) it should be limited to one frame.
36. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 7, 2013 8:07 AM (in response to kglad)thanks for all your help
37. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 7, 2013 12:25 PM (in response to nikolaig)you're welcome.
38. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
nikolaig Jan 12, 2013 8:56 AM (in response to kglad)I found a new bug with the scroller, which I can not figure out how to fix it or why it happens. Scroller does not work completely if I were to access it from a different labeled section.
If you still have my files, please go to products and click on of the images - larger pop up window will appear on the screen, click on one of the images at the bottom of the pop up window. It will bring you to the labeled section with the scroller. If scroller accessed this way then somehow the middle of the screen becomes unclickable for the scroller items, i.e. I can click only at the two most left and right images. As well as only extreme most right hand row of the buttons on the bigger image pop is working. It is as if swath is in the middle of the screen which doesn't allow for clicks. I think it might correspond to the "function moveScrollerThumb" set limitations of left and right areas where scroller starts to speed up, but it is a guess.
Just a reminder. The way the scroller works in a normal way is if you go to applications page and then click on one of the images.
39. Re: Can not get rid of xml loaded image scroller when navigate out of the page.
kglad Jan 12, 2013 2:48 PM (in response to nikolaig)i think you may run into numerous problems just because your setup is problematic.
