9 Replies Latest reply on Jan 8, 2013 1:12 PM by clovos83
    Buttons for web slideshow.
    clovos83
      Hey Guys,
      I'm trying to make a slideshow similar to what is provided through the Adobe Edge showcase sample files. Particularly the designer spotlight animation.
      I want to get my buttons working so that when I click one it goes to that particular slide. I have copied and modified the code to work in that way but for some reason I can't get my animations to play when I click buttons-only the first button plays the first animation. Whenever I click the other button, it behaves as if it's playing the whole animation until it reaches the point of where it needs to play from the timeline.
      I can post code to show you an example.
      Here's what I have inside of the stage code:
      // insert code to be run when the composition is fully loaded here
      this.circleBtnSymbol = sym.getSymbol('buttn_1');
      // turn "on" first circle btn
      this.circleBtnSymbol.stop('on');
      // global vars
      this.activePanel = 4;
      this.prevPanel = 1;
      this.panelCount = 4;
      this.panelObject;// panel
      this.circleBtnSymbol;// circle btn
      this.arrowBtnSymbol;// arrow btn
      sym.getSymbol('buttn_1').stop('on');
      // called internally only
      this.changePanel = function()
                //-- change panel
                this.stop('slide'+this.activePanel);
                this.panelObject = sym.getSymbol('slide'+this.activePanel);
                this.panelObject.play(0);
                //-- set states of circle btn
                // deactivate all btns
                var i=1;
                for( i=1; i<=this.panelCount; i++ )
                          this.circleBtnSymbol = sym.getSymbol('buttn_'+i);
                          this.circleBtnSymbol.stop('off');
                // set active btn
                this.circleBtnSymbol = sym.getSymbol('buttn_'+this.activePanel);
                //console.log('this.activePanel = '+this.activePanel);
      this.onClickCircleBtn = function( arg )
                //console.log('onClickCircleBtn');
                if( arg != this.activePanel )
                          this.activePanel = arg;
                          this.changePanel();
      and here's an example of the code I have for button2 :
      mouseover-
      // insert code for mouse enter here
      this.circleBtnSymbol = sym.getSymbol('buttn_2');
      mouseout-
      // insert code for mouse leave here
      if( this.activePanel != 2 )
      click-
      this.onClickCircleBtn( 2 );
      All of the code seems to be set but I'm still not getting it to play exactly the way it should from the timeline.
      Can anyone help me with this?
