1 Reply Latest reply on Jan 4, 2013 3:48 PM by gkaiseril
    Date Field in Adobe Acrobat X
    ToniChaffin Level 1
      I have a form that users fill in. One of the fields on this form is a date. Through the properties I have set the date format of dd/mm/yyyy. What I was hoping to be able to do next is, get it to auto populate. So when the field onFocus it executes something similar to the now() you can use in MS Access etc.
      Is there a way of getting it to add the system date automatically if so, how?
      Many thanks in anticipation of a speedy helpful response
      Kindest Regards
      Toni
        • 1. Re: Date Field in Adobe Acrobat X
          Do you want  the date fields to populate when the form is opened or from a user entry?
          You can get the system date object with the script "new Date()". You format the date object with the "util.printd()" method. So if you want to populate a field, "StartDate" when the PDF is opened, you can use a document level script or page open script of:
          // get the current date's date object
          var oDate = new Date();
          // set the field value
          this.getField("StartDate").value = util.printd("mm/dd/yyyy", oDate);
          Once you have the date object you can increment the date object using the "getDate()" and "setDate()" methods.
          // next day
          oDate.setDate(oDate.getDate() + 1);
          // format and set vlaue
          this.getField("StartDatePlus1").value = util.printd("mm/dd/yyyy", oDate);
          // next day
          this.getField("StartDatePlus2").value = util.printd("mm/dd/yyyy", oDate);
