4 Replies Latest reply on Aug 20, 2017 1:45 AM by linhlz
    Adobe Premiere Pro CS6, how to import .FLV ?
    Gouca
      Hello,
      trying out Premiere as a software to edit gaming-videos that I download from www.twitch.tv. The files are .flv (Flash video) and at the basic Premiere Pro doesn't seem to support them, does Adobe have any official recommendation for a plug-in for FLVs / could you recommend a reliable one?
      Thanks in advance,
      Gouca
        • 1. Re: Adobe Premiere Pro CS6, how to import .FLV ?
          the_wine_snob Level 9
          Do you know what the CODEC inside the FLV is? MediaInfo should be able to provide that information.
          IIRC, as of abut CS 4 (maybe with one of the updates), PrPro has had native support for FLV's with the On2 VP6 CODEC. I do not believe that Sorenson Spark is supported.
          • 2. Re: Adobe Premiere Pro CS6, how to import .FLV ?
            xboy92
            I can't believe I actually managed to "fool" Premiere CS6.
            First, I tried to import a full HD flv which is about 1.6 GB. Then I read this thread, installed the On2 VP6, opened again Premiere, tried to import again the flv video, but still "Unsupported or damaged file" message.
            Then I had this brilliant idea that had also helped me in a similar situation:
            So here are the steps explained in a very easy and detailed description:
            1. Go to any folder, or "My computer"...
            2. If you are on Win 7 /Vista hit "ALT" on the keyboard and the "File, Edit, Tools.." toolbar will appear in the upper side of the window
            3. Click on "Tools" > "Folder Options" > "View"
            4. Under the "Advanced settings", there is a long list of options. Look for "Hide extention for known file types" and deselect it.
            5. Hit Apply and OK.
            Your video file should be now like: "videoname.flv"
            6. Right click on the file, select "Rename" and simply change the extension from ".flv" to ".avi", let's say.
            That's what I did and I tried importing again the video with the new extention to Premiere CS6.
            Oh, and afer that you might go back to the folder options and select again "Hide extention for known file types" if yout dont want to see the extentions for all your files.
            • 3. Re: Adobe Premiere Pro CS6, how to import .FLV ?
              Eduardo Filip
              Nice try, doesn't work anymore on CC 2017 eheh!
              • 4. Re: Adobe Premiere Pro CS6, how to import .FLV ?
                linhlz
                You need to convert them outside of PRE first (ideally to DV or HDV). You could try the free Handbrake transcoder.
                Cheers,
